Buck
Vessel Name: greeniron
Photos: Greeniron
Posted: Mon May 10, 2004 7:07 pm Post subject: Lights; |
The all-around white light shines on the front deck and rail, really messes up night vision. What has anyone done to correct this problem...Buck. |
kingfisher
Joined: 28 Jan 2004 Posts: 21 City/Region: Gig Harbor, WA
Vessel Name: Misbehavin
Posted: Mon May 10, 2004 7:58 pm Post subject: |
Hey Buck,
I have heard about guys using that 2" foam insulation for pipes that comes in 6-8' lengths,you can pick up at most hardware stores, and putting it on the rails for night running. You may want to give that a try.
David
Misbehavin |
Posted: Mon May 10, 2004 9:47 pm Post subject: |
Buck-The problem you're having is the exact reason for mounting spot lights on the front of the bow pulpit instead of the cabin top.
Why not make a round flat metal "shield" of about a foot diameter with a hole in the middle for the shaft and mount it right under the white "steaming" light? I don't think it would be illegal as long as the light can be seen by other boats, and it would stop the light from shinning down on your deck and bow pulpit and blinding you. Just a passing thouht, but I think it would work, perhaps with some refinement to the shape and/or size of the shield. Make one out of cardboard and experiment with it. Cheaper than stainless to work out the exact shape details on! Joe. _________________ Sea Wolf, C-Brat #31
Chuck S
Joined: 01 Nov 2003 Posts: 309 City/Region: Cleveland
State or Province: OH
Vessel Name: Amelia Anne
Photos: Amelia Anne
Posted: Tue May 11, 2004 8:58 am Post subject: |
And there are special all round white lights made with this feature in them. I've seen LED models which should last decades if you don't drop them overboard.
-- Chuck |
Mr. Fisherman
Vessel Name: Sea Lion
Photos: Sea Lion
Posted: Tue May 11, 2004 9:06 am Post subject: |
The Anchor light does not have to be on while underway.
The steaming light in the rear as mentioned should be sufficent.
Unless you are anchoring there should be no need to fight the glare from the anchor light.
Correct me if I am wrong.... _________________
Live to Fish
Fish to Live |
Sawdust
Joined: 01 Nov 2003 Posts: 1400 City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
Posted: Tue May 11, 2004 11:54 am Post subject: |
Generally, power-driven vessels must display a masthead light, sidelights and a sternlight. Smaller vessels (less than 39.4 ft.) may display an all-round white light in lieu of the masthead light and sternlight.
The masthead light should show an unbroken light over a 225-degree arc (to 22.5 degrees abaft the beam on either side).
The stern light shows an unbroken light over a 135-degree arc... from dead astern to 67.5 degrees on each side of the vessels centerline.
HTH,
Dusty _________________ 1984 22 Classic |
