Stuffing Box
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Sat Mar 10, 2007 11:29 pm    Post subject: Reply with quote
Alok wrote:
Dave:
I have never used dripless packing, so I cannot comment on that.
I don't think there is any such thing as dripless packing. There are
mechanical shaft seals that can be installed in place of a stuffing
box that are dripless. I used to have a boat with PSS shaft seals.
They worked pretty well. I need to install them because the previous
owner had tightened the packing down to the point where the
shafts were heavily scored and leaked quite a bit. The PSS happened
to sit on the shaft in a different location and so were able to get a
good seal.
Mike
kimshack
City/Region: Mill Creek
C-Dory Model: R-21 EC Tug
Vessel Name: KIMSHACK
Photos: Kimshack
PostPosted: Tue Mar 20, 2007 8:00 pm    Post subject: Reply with quote
After getting my boat back last Saturday after 9 weeks, I discovered that the stuffing box leaks at about 2 drops per second. I've read this post throughly, in addition to the link which was presented earlier, but still need some help in trying to fix this.
I spoke with John, and he stated that the smaller nut in the rear is the lock nut, and I would need to loosen that then finger tighten the bigger nut which contains the flax.
I tried to loosen the lock nut, tried both clockwise and counterclockwise, using a pack nut wrench which I just picked up yesterday. It wouldn't budge. Besides being in a location which is very difficult to get to, therefore I couldn't apply alot of pressure, in addition to the fact that I didn't want to put too much torque on it and break something.
So, I wanted to get your expertise.
Which nut is the locknut?
Which direction do I turn the lock nut, as I'm facing the stern? Clockwise? Counterclockwise
Which direction should the nut with the flax be turned to tighten?
Here is the link to the stuffing box. I've got it listed in my album.
http://www.c-brats.com/modules.php?set_albumName=album357&op=modload&name=gallery&file=index&include=view_album.php
kimshack
Photos: Kimshack
PostPosted: Tue Mar 20, 2007 8:02 pm    Post subject: Reply with quote
The top of the picture goes to the prop, and the bottom goes to the motor.
davehogue555
City/Region: Cibolo
State or Province: TX
C-Dory Model: R-21 Tug
Vessel Name: Soulmate
Photos: Soulmate
PostPosted: Tue Mar 20, 2007 9:38 pm    Post subject: Reply with quote
Kimshack.........I haven't tackled mine yet, so I'm not the right person to answer your questions. Maybe Ranger Jeff will give us some info. What in the world did you have done to Kimshack that took 9 weeks Question Sounds expensive Exclamation
PostPosted: Tue Mar 20, 2007 11:14 pm    Post subject: Reply with quote
I had a sailboat with packing. Tried adjusting it, either too tight or too loose, and there always was water in the bilge. When I hauled it to paint the bottom, I installed a PSS Shaft Seal. Its a carbon/stainless rotating joint, loaded by the bellows used to seal the shaft. It's also used on rocket engines on the propellant pumps. That was the end of the problem, and I kept the boat for another 10 years. They only cost ~250 bucks, and with what they get for a boat these days, and the pain in the rear stuffing boxes are, I don't understand why the factory doesn't use them.
Install it yourself next time the boat is on a trailer. It's easy to put on, and well worth the effort. In addition, you'll have a dry bilge.
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Tue Mar 20, 2007 11:25 pm    Post subject: Reply with quote
kimshack - looking at your photo, it appears that turning the nut to the right will loosen it. It would be easier to tell from a photo, if it is taken more from a top angle, instead of the angel of your photo.
________
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time All times are GMT - 5 Hours
Page generation time: 0.0316s (PHP: 59% - SQL: 41%) - SQL queries: 19 - GZIP disabled - Debug on
