Stuffing Box
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time
davehogue555
City/Region: Cibolo
State or Province: TX
C-Dory Model: R-21 Tug
Vessel Name: Soulmate
Photos: Soulmate
PostPosted: Mon Mar 05, 2007 9:36 am    Post subject: Stuffing Box Reply with quote
Thanks to the administrators of C-Brats for this forum and thanks Ranger Jeff for participating. It's a good feeling to know that even as far as I am from the factory and any Ranger dealer I can still get official info on my new Soulmate........well, she's not new, but new to me. Ranger Jeff, is there a written procedure on changing the packing in the stuffing box? Diameter of packing material? I bought my R21 with 50 hours on her and have no idea of the status of the packing. It "leaks" a gallon or so an hour which I think is too much, but maybe not.
Thanks for your help.
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Mon Mar 05, 2007 11:04 am    Post subject: Reply with quote
That's too much, no matter what kind of box you have. If it is a flax filled, take up a turn to tighten the stuffing material. It shouldn't leak a gallon in a week or two.
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Mon Mar 05, 2007 12:45 pm    Post subject: Reply with quote
Dave, Here is a good write up on Stuffing Box Servicing...
http://www.boatus.com/boattech/Casey/StuffingBox.htm
It is the same one I sent to you by e-mail.
Mike Taylor
330-936-1030
lloyds
PostPosted: Mon Mar 05, 2007 1:21 pm    Post subject: Reply with quote
I had never heard of the Drip-Less packing material until now, sounds pretty cool. I used to use a FMC stuffing box. FMC used these in the vegetable processing industry. They are a graphite ring in a special housing. They require virtually no care, just burp them when you put them in the water. I put about 5000 hours on one and didn't do anything but give it a periodic inspection. They were especially good in restricted areas where the Lasdrop and others were too big to fit.
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Mon Mar 05, 2007 1:54 pm    Post subject: Reply with quote
Dave...You bet that is too much.....way too much !!!
I doubt my packing box leaks a cup full in an entire season...4 months in the water... I don't have a Ranger tug, mine is a Sea Horse tug.... your packing nut is too loose...you can really reef down on those suckers...don't be afraid of it... all your doing is compressing the packing....and it lasts for years and years...probably 5 or 6 at least.. heck it is the same packing I use on the water pump on my Model A Ford and that lasts years...
I use a teflon type packing that I buy from West Marine...its a string like material...but don't use it like a string... what you do is cut the material and make rings of it then install the rings so the cuts never line up...
You tighten it up until the drips stop....and leave it...if you notice more drips take another 1/2 turn on it...and so on...until the drips just stop...won't hurt anything...your just compressing the packing.
I also have some lead coated packing that I have used on the old car for 30 years... but I think the teflon packing is so much better...and nicer to work with... it's easy.
I should be in Texas in a couple of weeks...riding cross country on my motorcycle... if ya need I will stop and show ya how it's done...
Joel
SEA3PO
Ranger Jeff
Ranger Tugs Factory Rep
City/Region: Kent
Photos: Ranger Factory Album
PostPosted: Mon Mar 05, 2007 2:02 pm    Post subject: stuffing box Reply with quote
Hello Dave,
Congratulations on your new boat. The stuffing box on the 2005 R21 is under the battery. It would be pretty unusual to need to change the packing material with just 50 hours on the boat. There is a lock nut on the front of the box that will need to be loosened. The packing nut can then typically be turned by hand. adjusting the packing nut should be done in 1/4 turn increments. The packing material is 1/4 by 1/4.
Ranger Jeff
Jeff Messmer
V.P Sales and Marketing
Ranger Tugs
25802 Pacific Highway South
Kent, WA 98032
Office 253 839 5213
Cell 206 940 0571
e-mail jeffmessmer@rangertugs.com
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Mon Mar 05, 2007 2:28 pm    Post subject: Reply with quote
Hiya Ranger Jeff.... It sure is good to see ya on da site... Yes I agree with you, packing material should not leak... and lasts forever if adjusted properly... We sure don't want to loose track of you, at C-Dory you were one of the "Good Guys" that made the boat so special....
I have a Sea Horse 21 tug... much like the Ranger, maybe a bit wider but along the same lines.... it originally came with a Yanmar 2 cylinder and I replaced it with a Yanmar 3 cylinder 30hp diesel... great boats...
Joel
SEA3PO
KEA (the tug)
teflonmom
City/Region: Red Lion
Vessel Name: Snickers AUG 08
PostPosted: Mon Mar 05, 2007 7:19 pm    Post subject: Stuffing Box Reply with quote
Happy Tugging,
Jeff'a message gave you the needed info to purchase packing material. It is not expensive so get some from your boat store. I too like the teflon type after I repacked my Monk it lasted for over two years and was still OK when I sold her.
I was told that a little dripping while you are running helps to keep things cool so adjust accordingly. If you keep your boat in the water over the winter and not using her just take a turn and stop the dripping. Be sure to loosen the gland on the spring. The advise about cutting circles was right on.
Have Fun!
Pat & Fred Messerly
PostPosted: Mon Mar 05, 2007 7:29 pm    Post subject: Reply with quote
When cutting the circles, we make the cut oblique with a razor at 45 degrees. Usually three rings of packing are correct--and stager the rings.
I also like the teflon impregnated gortex packing, and put in moderate amount of teflon grease as I pack. Doing this I had my stuffing boxes so that they were virtually leak free and yet ran cool. Definately a gallon an hour is way too much.
It will be hard to check to see if the rings were put in correctly (not spiraled) at this point. I probably would put in some teflon grease (Syntef) and then tighten the nut on the shaft until there is no leakage. Check the shaft when running. It should be slightly warm to the hand, but not hot. If it is hot, then you may need to repack.
davehogue555
City/Region: Cibolo
Photos: Soulmate
PostPosted: Tue Mar 06, 2007 8:29 am    Post subject: Reply with quote
Thanks to all for the info, I think I'm going to repack it just so I can learn how and have a known starting point on the wear and adjustment.
Joel, what part of Texas are you crossing? There's a saying about motoring across Texas........."The sun has riz and the sun has set, and here I is...........in Texas yet." Stop by, if you're down this way.
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Tue Mar 06, 2007 11:41 am    Post subject: Reply with quote
If you crank down too hard, you can prevent all water from coming through. With
normal non-teflon packing, at least, you can score the shaft with dry packing.
Once you score the shaft, it will not stop leaking. At that point, you can either
resurface the shaft or put in a dripless. A dripless will only work if it happens
to attach in a location that is not scored.
Mike
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Tue Mar 06, 2007 1:20 pm    Post subject: Reply with quote
I was thinking....I assumed that you were talking about your rudder packing box...and not your shaft seal.... I use the teflon packing material on my rudder box, but changed to the Packless Sealing System for my shaft seal....it uses a carbon ring and a spring to keep tension on the sealing surface....and works super... but it's kinda expensive...$220 ...it's one of those things you set and forget... I see it every time I fill my tanks as my fuel gauge is close to it, but never have seen a drip ....probably been on there for 8 to 10 years... never touched it... fairly easy to install...I bought mine from West Marine.
I will be riding through Texas about the 20th...(hopefully) on Interstate 10
if you will be home I will give ya a call...we can do lunch....
Joel
SEA3PO
davehogue555
City/Region: Cibolo
Photos: Soulmate
PostPosted: Sat Mar 10, 2007 10:56 am    Post subject: Reply with quote
Joel,
I'm just a couple of miles north of I-10, 20th or after would be good, let me know when you're passing thru.......210-535-0365
Alok
City/Region: League City
Photos: Top Cat
PostPosted: Sat Mar 10, 2007 4:50 pm    Post subject: Reply with quote
Dave:
As Jeff has noted, you should not have to change the stuffing at 50 hours.
1. Make sure that your engine alignment is correct and that your engine is seated firmly. An engine that is even slightly mis-aligned or is vibrating from being loose will cause the stuffing box to drip like crazy. Don't ask me how I know.
2. If your stuffing box is anything like the one I had in my trawler: hand-tighten the first nut and then back the second nut TIGHT against it, otherwise the first nut can work loose when you are under way. You do not want this to happen unless you want to find out how good your bilge pump is.
3. With standard packing, the stuffing box should drip a little bit while the shaft is turning- perhaps 1 drop a minute. This shows that the stuffing is not too tight. If it is not dripping at all, you run the risk of having the stuffing too tight and scoring the shaft. I have never used dripless packing, so I cannot comment on that.
After adjusting the stuffing box I used to leave a small pan under it. As long as I had a little water in the pan, I knew that the packing was correct.
Alok
C-Dory Tomcat (Topcat) sold January 2012
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Mar 10, 2007 8:14 pm    Post subject: Reply with quote
There are 36,500 drops in a quart....so a small drip now and then should not hurt much...
Joel
SEA3PO
Kea (the tug)
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time All times are GMT - 5 Hours
Page generation time: 0.0418s (PHP: 65% - SQL: 35%) - SQL queries: 28 - GZIP disabled - Debug on
