ACR Battery Selector Switch - WHY???
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Thu Feb 08, 2007 8:19 am    Post subject: ACR Battery Selector Switch - WHY??? Reply with quote
I don't have an ACR, and after monitoring the threads related to this item, reviewing product literature, and learning how they work, am wondering why I would consider getting one.
I understand that if something comes with the boat, there is the natural inclination to use it. I also understand the desire to make everything automatic. That having been said, what is the battery charging problem on C-Dory 22 type boats that makes this device, and it's many associated problems, worth having?
At the risk of revealing how simplistic I am when it comes to charging batteries while underway, here's what I do. I have two identical wet cell (starting) batteries. One is designated "starting", and is on the 1 position on the manual selector switch. The other is designated "house", and is on the 2 position. In the morning, I put the selector switch on 1, start the motor, power up the electronics, run the windlass, and am underway. I let the 1 battery charge for a while, to replace the draw from starting the motor and windlass. I then turn the selector switch to 2, and let the house recharge for the balance of the day. At night, I leave the selector switch on 2, and run interior lights, wallas and fans as needed, anchor light, and the gps with anchor drag and low battery alarms set. In the morning, I note the battery volts on each setting, and begin all over again.
Sometimes, I forget to switch over to 1 in the morning, and start the motor on the house battery, which has been in use as noted overnight. This isn't the best thing to do to a wet cell battery, but the motor always turns over with a crisp crank, and starts right up.
When the boat is on the trailer, it's connected to the 110 v powered on-board charger 24/7. I've used the batteries in this way for three years. The starting is at 100%, and the house is at about 90%. I'll replace them both before going to the Bahamas, but otherwise, would see if they have another season in them.
Absent massive loading of the house battery, starting out with batteries which are not fully charged, or consistently overlooking a fairly simple switching procedure, I'm wondering what problem would be solved by introducing an ACR into this equation.
2003 CD22 Cruiser with Honda 90
Jeff Brigner
State or Province: TN
Vessel Name: C-Pearl
Photos: C-Pearl
PostPosted: Thu Feb 08, 2007 9:00 am    Post subject: battery switch Reply with quote
I, by no means have the knowledge to answer any questions about electrical on a boat but will share what I read in a boating magazine. You are always suppose to switch to the both position while underway for the benefit of the motors charging system. I'm sure I can't find the article to tell you which one it was because, I have an automatic magazine dispenser at my home that dispenses of magazines as soon as they get left where they are not suppose to be. Laughing
PostPosted: Thu Feb 08, 2007 9:45 am    Post subject: Reply with quote
Alma's Only-
I'm much in the "same boat' with you on battery usage theory, but I do know that these battery isolators, combiners, automatic switches, multiple bank chargers, and battery monitoring systems are intended to allow:
1. Isolation of house and starting batteriess, including starting batteries from each other in twin engine applications.
2. Allow the use of specialized starting, deep cycle marine, combination, and various other types on the same boat.
3. Keep at least one battery in reserve for staring purposes.
4. Isolate voltage sensitive electronics from starting circuits which introduce voltage spikes into the electrical system.
5. Allow selective prioritized charging of batteries by any of the the motors, generator, or shore power.
6. Sell more fancy electronics with very expensive "black boxes" that defy understanding by the mortal souls who pay exorbitant prices for them. Smile Or at least it seems that way at times!
Nonetheless, the resulting difficult to understand types of electrical and battery charging systems do make for a lot of confusion and consternation.
Basically, I'll have to say that I'm with you on this one!
I simply have two batteries in the back of the boat near the transom, and another two up under the forward dinette seat. Each pair has a "Off/1/both/2" switch, and all four are group 27 deep cycle batteries rated at either 105 or 115 amp--hrs.
I run the boat always with these four batteries in parallel, essentially one big battery!
Because I don't use sensitive electronics on an inland lake (I do have GPS, RADAR, 2 fishfinders, radios, etc., though), the voltage spike issue is never a problem.
Although I do run a engine mounted electric trolling motor on the anti-ventilation plate of the Yamaha 90, I can always sense when it's time to start up the motor or the generator (Honda eu1000) to charge.
The only problem I can see with this set up is that the load on the motor's alternator might be quite high when first re-charging, but no probems so far.
I like not having separate battery types, chargineg needs, complex wiring, multiple switches, and black boxes.
Essentially this system solves the problem of multiple battery types, differential charging, etc., by making the battery so big you can't harm it! It also works because it is simple, or as they say....... KISS......or something like that! Works for me!
P.S.: Four new group 27 deep cycle marine batteries @$60 each are a lot cheaper than an elaborate system you don't fully understand or know how to control.
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Thu Feb 08, 2007 10:52 am    Post subject: Reply with quote
An ACR is just an automatic battery switch. You don't need it. It's nice to have.
They are not terribly expensive (~$65) nor difficult to add.
My own experience with the 1,2 1+2 setups is that it is relatively easy to forget
to move the switch. I'd rather not have to worry about it, and since I was making
major changes to the wiring* anyhow, it was a good time to add it. And honestly,
I like to play with stuff like this. It's fun. I like flipping the switch on the helm that overtrides the relay from 'auto' to 'off' and hearing the relay click off (the relay was
closed because the battery charger is on and voltage is high). Hopefully, when
I start the boat, the ACR will work properly. I would suggest getting the remote
switch and/or LED so you have some idea if the relay is working correctly.
If you are happy with your manual switch, then I wouldn't go to the trouble of
adding one of these.
Hey, lots of people have very expensive plotters on their boats. I was looking
at the cost of some of this stuff recently. I'll stick with the lower cost units
for now. Heck, before I got the Garmin 188C with the boat, I had a Garmin GPS-12, a
small handheld with no charts or anything.
Mike
*The boat did not have a charger, and there was not enough wire going
forward either. Any time I trimmed the motor, the GPs kicking out a lower
voltage alarm. That should not happen.
C-Pelican
City/Region: SoCal
C-Dory Year: 1992
Vessel Name: C Pelican
Photos: C-Pelican
PostPosted: Thu Feb 08, 2007 10:56 am    Post subject: Reply with quote
Interesting thread. As a new boater with no battery switch at all, but two batteries and one stand alone for "just in case" I always wondered about the need for a battery switch or some of the electronics I always read of here. I look forward to learning, as I have learned so much already from this site, of the advantages and disadvantages of switches and such.
Jeff
C-Sick
City/Region: Renton
C-Dory Model: R-25 Tug
Vessel Name: Gratitude
Photos: C-Sick
PostPosted: Thu Feb 08, 2007 11:27 am    Post subject: Yet Another Set Up Reply with quote
I have a 2003 22 -Cruiser - twin 40s. I have two batteries which are completely isolated from one another. Originally I had a 1, 2, or both switch until I discovered a thread on this site that indicated that the both component could cause harm to the honda charging system. The factory then isolated the batteries and left the orignal wiring (unhooked) to use as jumper cables in the event one battery goes dead. The house is run off the starboard battery.
Any comments are to potential downfall in this systems?
My hunch is I will be replacing the batteries this year. I keep them 24/7 on a charger when not in use and I have to keep a close eye on the water levels.
C-Sick
In A Bad Way
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Thu Feb 08, 2007 2:23 pm    Post subject: Reply with quote
For those who use the 1-both-2 switch there is a simple way to remember to switch from the house battery to the starting battery.
Make a tag or card that says "Switch to start battery" and attach the tag to the key or place the card in front of the tach when switching to the house battery.
This 'memory jogger' can also be used for things like overhead clearance when towing. Or for the drain plug!! LOL
Larry H
A C-Brat since Nov 1, 2003
Jeff Brigner
Photos: C-Pearl
PostPosted: Thu Feb 08, 2007 2:46 pm    Post subject: mental notes Reply with quote
Hey Larry...How about the one to flush Laughing
Falco
City/Region: Flagstaff
Photos: Bucking Coho
PostPosted: Thu Feb 08, 2007 3:30 pm    Post subject: Reply with quote
For $65 an ACR is a good investment - even if your memory about switching battery banks is perfect. Here's why: the primary advantage of an ACR is it works to maintain optimal charges in BOTH batteries in as short a period of time as possible. This is important because an undercharged battery sulfates and battery life is reduced. When the cranking battery is charged, the ACR switches to charge the house battery and visa versa. There is no delay in maintaining the "perfect" charge in both batteries; the charging system operates at maximum efficiency.
Note as well that switching a selector switch from one or the other single settings (on a partially discharged battery) to "both" will immediately draw down the second battery - another needless discharge. This will happen even if the system is actively charging.
Discharge level and frequency varies so it will affect batteries differently. Adding an ACR is easier than trying to figure this out. Presumably an APC extends battery life. Assuming a marine combo crank/deep cycle costs $65 (an Interstate group 24) and you have 2 ($130) and you save 15% of your battery life with an ACR, you save $19.50 per battery switch out - a payback period of 3.3 years.
Don't underestimate the value of an ACR in automatically isolating the cranking battery during starting and ill effects on electronics. (BTW this has nothing to do with sea or fresh water.) How quickly a $65 ACR might pay off if a $165 VHF or even $3000 all in one system is fried!
Besides, it's cool technology. Guess I better get one.
Jeff Brigner
Photos: C-Pearl
PostPosted: Thu Feb 08, 2007 3:40 pm    Post subject: ACR Reply with quote
Now you did it ! I guess I better get in line. Hey Marc, you reading this thread?
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Thu Feb 08, 2007 7:04 pm    Post subject: Reply with quote
C-Sick,
I have the same setup just a year older. I also have two batteries each wired to each motor and independent. Since the "House" battery is a function of which one I have selected I see no advantage to an ACR in our case. A technique I use on my boat when cruising and especially when doing a lot of fishing(trolling on one engine for extended periods), is keep the battery switch on position 1 for odd days and position 2 on even days. Even this might be hard to keep track of if not for my digital watch. I have gotten four full seasons out of two group 24 batteries using this method. Works for me.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Thu Feb 08, 2007 9:58 pm    Post subject: Reply with quote
Many people seem to have onboard chargers and I am considering one. I also like to keep things simple.
How do you power the charger? - Plug charger directly into an extension cord. Or is it wired into a shore power system that gets plugged in?
I don't like the thought of carrying one of the large 30amp yellow dock cords. But I also don't want to have an electrical hazard by not having a grounded, reverse polarity indicating, circuit breakered, full up system.
Is there a simple/safe compromise?
Steve
PostPosted: Thu Feb 08, 2007 10:18 pm    Post subject: Reply with quote
I certainly cannot argue with the points Alma's Only makes. If best practices are followed then the system is best without any fancy stuff.
I guess the most accurate way for me to answer would be to say I like having the ACR for the same reason I like the feature on my truck that shuts off the headlights 30 seconds after I forget to. The only purpose my fully functional Off-1-2-Both switch serves is to disconnect the motor from the battery when leaving it sit for a while in the water or on the trailer.
I do recall that Les does not like using the things. I think his thoughts are more for maintaining optimum battery condition. But with Costco just down the street, I replace the batts at 2 years and get a few bucks back on the three year warranty.
Dreamer
Photos: Dreamer
PostPosted: Thu Feb 08, 2007 10:31 pm    Post subject: Reply with quote
Steve, When your boat, family and marina's safety are involved, don't compromise!
Alma's Only, The Blue Sea's ACRs are a valuable tool on boats with twin engines. Dreamer has 2 Optima AGM engine start batteries. Once they are fully charged, the ACRs conect them to two Lifeline 275 amp-hour house batteries. Actually, each engine, start battery and house battery are in a separate charging system. While at anchor or at a marina, the selector switch is turned to ALL. This gives a 550 amp hour house bank to use or charge if shore power is available. The next morning, Batt 1 or 2 is selected to be the house/electronics battery of the day.(Batt 1 on odd numbered days, Batt 2 on even days)
The charging output on the Honda 150s is not what one would hope for but it does the job. The wiring includes manual paralleling of the batteries for emergency starting. (see photo album) All the Blue Sea equipment is top notch in my book and I don't worry about it failing underway. This may seem somewhat complicated but it about as simple as I could get on a twin engined boat with moderate to heavy electrical demands.
Dreamer- Sold 25 Feb. 2013
PostPosted: Fri Feb 09, 2007 12:01 am    Post subject: Reply with quote
As Noted by Jeff, C Pelican (which we used to own) has two batteries always connected in parallel, plus an "extra" battery which is isolated--and not hooked up. We never had the need for a switch or an ARC.
For the simple and low battery draw on the 22, I would think that an ARC is overkill. We moniter battery voltage. With the 22, we just checked it with a hand held digital volt meter. With The 255, we have two ARC's, lots of electronics, an inverter, refigeration'/freezer, and 5 batteries--a much different situation. We could do the same with a good battery switch (Make before break). The ARC does isolate the electronics during start, low voltage and spikes which might occur during this time.
We do have a simple volt meter (Ok I got a really good deal on a Link 1000 so we now track amps)--and I check battery voltages as we are running. If an ARC was not working--or I didn't switch over the batteries I would pick that up within 15 minutes of leaving the dock/anchorage. I moniter battery voltages during running every 30 minutes or so--plus at anchor every 6 hours give or take.
Page generation time: 0.0828s (PHP: 53% - SQL: 47%) - SQL queries: 28 - GZIP disabled - Debug on
