Reflections on Flat Tires
PostPosted: Sun Feb 04, 2007 9:59 am    Post subject: Reflections on Flat Tires Reply with quote
Ever have a flat tire on your trailer? I just did, a nail through the sucker, fortunately it was in my driveway and not halfway across the country...but here is what I learned from this experience. First, the lug wrench in the Expedition is too shallow to fit over the trailer lug nuts. OK, a bunch of scrounging around in the garage, finally came up with a suitable lug wrench. Second, the lug nuts were almost like they were welded on. Some more scrounging to find the Liquid Wrench and a sledge hammer to whack the end of the lug wrench to get them loose. Third, didn't have a suitable jack in the Expedition, yet more scrounging to find a 4 ton bottle jack in the basement. Finally, the bottle jack needed about a foot of blocks to get ithe trailer up high enough for the tire to clear the ground. Now, if that flat tire happened on the road, I wouldn't have had any of the stuff I needed, plus we don't have a spare mounted on the trailer like we used to with the 22. So this, plus all the stuff about trailer bearings, brakes and other things about which I know nothing, has got me worried about leaving my driveway again... Sad Sad
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Sun Feb 04, 2007 10:17 am    Post subject: Reply with quote
OK Pat... calm down. You have to feel like you have won a battle brother. Enjoy a nice train. Now, you have two things to take care of...
#1: Check all your insurance policies, clubs, organizations, and find out about tow insurance/tire replacements. Some things are just best hired out. No pulled muscles, busted fingers, or other body parts out of whack??? Good Job!
#2: Just realize, that either you, or some handy friend who might be more mechanically inclined than you are, might also do the at least annual maintenance on your trailer while he is doing his.....or.... just bring in a mini-keg of train to a nice local mechanic.... and have it done. Salt water bad...fresh water not a lot better.
Well....OK,,, I use pulled pork and ribs instead of a mini-keg.
Thumbs Up
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sun Feb 04, 2007 12:13 pm    Post subject: Reply with quote
Just take Crabby Lou. You don't even need the Expedition, you can pull it with the Subaru.
MartyP
PostPosted: Sun Feb 04, 2007 12:17 pm    Post subject: Reply with quote
...and you and Austin can lift it up while Patty changes the tire.
I carry a long handle ratchet, extension and socket in the truck for the lugs. I have never tried the Dodge jack, but looked at it and figured it will work. It not, I'll figure out something alongside the road.
dotnmarty
Photos: Lizzie
PostPosted: Sun Feb 04, 2007 12:19 pm    Post subject: Reply with quote
Mike, you're a funny guy. heh, heh
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Sun Feb 04, 2007 12:38 pm    Post subject: Reply with quote
Anti-seize is your friend...every lug nut I ever install, gets a coating.
Just a tiny dab on the lug is all it takes - makes a huge difference, especially on the trailer. Between the surge brake heat and the salt water, those nuts will get frozen up in no time without it...
Plenty of choices out there - I've had a can of this stuff for about 5 years, and I've hardly put a dent in it.
Tux Will, C-Brat Nerd Tux
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Feb 04, 2007 12:47 pm    Post subject: Reply with quote
Absolutely Bill, I use the same brand but in the tube, works great, and I also check the lug tightness about twice a year or before every long trip for sure.
Hey, just thinking, would that be better to use on the prop shaft than marine lube, or would it wash off too easily. Hmmm.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Sun Feb 04, 2007 12:57 pm    Post subject: Reply with quote
There is actually suspended particles of metal (copper, aluminum, who knows what else) in the stuff and I wonder if they might react in the salt water. We use a high-content copper anitseize compound in the pulp mill and it works great in all the bad stuff there, but I would be leery of keeping it underwater. Plus, I don't have to buy the shafts and props at the mill.
I do agree with putting it on the lugs, though. Works great.
Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Feb 04, 2007 1:01 pm    Post subject: Reply with quote
I hear ya Mike, a little too expensive to go experimenting with the props/shafts using something that wasn't made for that use. The marine grease seems to be adequate as long as you don't let it go too long between pulling the props.
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sun Feb 04, 2007 1:03 pm    Post subject: Reply with quote
That product contains aluminium, copper and graphite.
All three can cause electrolysis in salt water. I would stick to what the manufacture recommends for prop shafts. Graphite based grease also can cause corrosion on SS shafts.
Larry H
A C-Brat since Nov 1, 2003
teflonmom
City/Region: Red Lion
Vessel Name: Snickers AUG 08
PostPosted: Sun Feb 04, 2007 1:55 pm    Post subject: Flat tires Reply with quote
Sorry to say I have some experience in this field. I will give you the benefit of my experience.
Number one after you have lubed the lug nuts. Join BOAT US and their Trailering Club. It only costs $10.00 a year over your basic membership. This could be the best ten bucks you ever will spend. The 800 number gets you help when you are far from home and would not have a clue who to call. On one trip to FL we used the service twice. Both service companies were very helpful and got us going as quick as possible.
After that trip we have always carried a good jack and lots of wooden blocks, a good spare, and a grease gun to refill the hubs after a long run.
Pat & Fred Messerly
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Sun Feb 04, 2007 2:10 pm    Post subject: Reply with quote
Pat,
Another thing to check: sometime the spare tire is bolted to the carrier with a different size nut than your lug nuts. I found this out the hard way with a flat on a different trailer. I now carry a long breaker bar and sockets for my truck tires, trailer tires and the spare tire carrier.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
Alasgun
Guest
PostPosted: Sun Feb 04, 2007 2:14 pm    Post subject: Reflections on flat tires Reply with quote
Karma says: quit rooting for Seattle and you will not have flat tires! Rolling Eyes
Mike on Huda Thunkit
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sun Feb 04, 2007 2:27 pm    Post subject: Reply with quote
A little late to be rooting for Seattle I think. Only about 3 hours left before the great commercials start. I wish the breaks for the game were shorter!
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Sun Feb 04, 2007 3:05 pm    Post subject: Reply with quote
Pat,
Quit listening to all the above advice! Go out, purchase a Dodge Diesel, hitch it to your boat trailer and drag it anytime, anywhere you want ....who cares if your surge brakes seize up or your tires are flat (they're only flat on the bottom), the Dodge Diesel, will "git 'er done"! Wink
Dave S.
"Sea Shift"
C-Brat #16
Page generation time: 0.0469s (PHP: 66% - SQL: 34%) - SQL queries: 27 - GZIP disabled - Debug on
