fresh water tank cleaning
terraplane
City/Region: chesapeake bay
C-Dory Model: R-25 Tug
Vessel Name: BANJO
Photos: Sally's Sister
PostPosted: Sat Jan 06, 2007 1:36 pm    Post subject: fresh water tank cleaning Reply with quote
I use my freshwater tank for cooking water, face washing, doing dishes...not for drinking..but it is getting funky in there...
How do you guys clean this tank?
terraplane
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Sat Jan 06, 2007 1:46 pm    Post subject: Reply with quote
I cleaned my water tank less than a year ago. Some have posted that they use a few tablespoons to 1/4 cup of clorox. I used hydrogen peroxide because my home RO water system says to us it.
What I found is that the hose from the tank to the foot pump had a layer of brown gunk on the inside. I think this is a normal development when ever you have water sitting in a hose. I replaced the hose but suspect the brown stuff is back.
I don't think it is toxic and I use the tank water for many of the same things including brushing teeth. I carry additional drinking water. Before I go on a trip I drain the tank and put in fresh water.
Steve
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Jan 06, 2007 1:58 pm    Post subject: Reply with quote
I always pump the system down when I am not using it...then add some chorox ..... before I fill it again....I add several gallons of water and drain that... Been doing that since the boat was new and I always have clean safe water... sometimes smells a bit of clorine...but that does not bother me...it's not bad and I know it's safe water..
Joel
SEA3PO
Chester
City/Region: home
Photos: Chester
PostPosted: Sat Jan 06, 2007 2:56 pm    Post subject: Reply with quote
I winterized the water system with a bottle of vodka. It won't freeze, kills the cooters, and won't poison the end user. Hopefully it won't damage the pump, I guess time will tell.
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Jan 06, 2007 3:15 pm    Post subject: Reply with quote
I've been winterized like that a time or two...
Joel
SEA3PO
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sat Jan 06, 2007 3:20 pm    Post subject: Reply with quote
The easiest way on a 22 is to pick up a piece of tubing that will slip over the faucet and hang it out the window below the hull. Then pump the pump and get a flow going. It will then syphon on its own. I use a 1/2 tsp of bleach per gallon of water in the tank and fill it entirely, pump water through the faucet several times over 5-10 minutes to bring the bleach in contact with the entire system and then syphon it out. Also pour a splash into the level tube. Bleach only needs several minutes of dwell time to sanitize.
I do this twice a year. You may want to do it more often in a warmer climate.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
PostPosted: Sat Jan 06, 2007 4:25 pm    Post subject: Reply with quote
I tried that once and all I got was a king sized headache... Shocked And it didn't damage my pump either.... cooters? I don't have any that I know of... Disgust
Oh wait, maybe you mean put it in the tank?? Rolling Eyes
PostPosted: Sat Jan 06, 2007 6:50 pm    Post subject: Reply with quote
There are those in warmer climates that do that. Add some orange juice - Screwdriver. Add some peach schnapps - Fuzzy Navel. Add cranberry and pineapple juice - Sex on the Beach.
Apparently it doesn't have anything to do with winterizing, but someone does get tanked.
Now, to get back on the subject again... after you've put a small amount of bleach in the water tank, run the boat around so that it mixes well. Pump it through and out of the system. If you still have that "bleachy" smell, put a bit of baking soda in the water. In warmer climates, we sanitize the tank once every couple months or so if it isn't being used regularly.
http://captnjim.blogspot.com/
El and Bill
City/Region: Lakewood, CO
Vessel Name: Halcyon
Photos: Halcyon
PostPosted: Sun Jan 07, 2007 11:41 am    Post subject: Reply with quote
The bleach, siphon over the side, and freshen with baking soda is the technique we use. However, we must confess ... since we drink our tank water (that might explain some things, eh?) we also dump in a bottle of cheap vodka every so often (also explains some things, you're thinking?). Makes good antifreeze and really zips up the morning coffee ...
PostPosted: Sun Jan 07, 2007 1:07 pm    Post subject: Reply with quote
El and BilI-
I think I'll just pump the water over the side, flush it out with some water and bleach mixture, and then refill the whole tank with vodka!
Might as well cut to the chase, so to speak!
See ya' in Seattle!
Joe
seahooked
City/Region: Redmond
Photos: SeaHooked
PostPosted: Sun Jan 07, 2007 1:23 pm    Post subject: Reply with quote
[quote="JamesTXSD"]
Jim,
How much baking soda is a 'bit'. As soon as winter's over, I'll need to get the pink stuff out of my water system for the first time.
Chris Brown
Redmond, WA
2006 CD-25 Cruiser "SeaHooked" 2006-2012
PostPosted: Sun Jan 07, 2007 2:52 pm    Post subject: Reply with quote
Hi Chris,
After years of living in the frozen northland and frequent winterizing of RVs, here's how we handled the UNwinterizing: Assuming you don't have a hot water heater full of the pink stuff, fill the fresh water tank (add a couple tablespoons of bleach; really, it doesn't take much), and run water out of all the faucets until the water doesn't look foamy. Fill the tank again; if you smell the bleach in the water, mix a couple tablespoons of baking soda in water and add that to the tank. Run some more water. That's it. With the smaller water tank in our 25, I put about a capful of bleach in the water when we're sanitizing it.
If the hot water heater has the pink stuff in it, it will take a lot more flushing to clean it. It's best to drain it and add water with the drain open.
I've never tried the vodka technique... I'm guessing you don't have to go so easy with the amount you add with that. Wink
seahooked
Photos: SeaHooked
PostPosted: Sun Jan 07, 2007 3:38 pm    Post subject: Reply with quote
Thanks Jim,
Your details will be very helpful come spring.
patrick and linda
City/Region: somerset
State or Province: KY
C-Dory Year: 1986
Vessel Name: "Fan-A-Sea"
Photos: Misty Seas
PostPosted: Mon Jan 08, 2007 12:13 pm    Post subject: Reply with quote
hi david, (anna leigh)
it's always the simple solutions that are hardest to discover!
great idea, can't tell you how much time i've waisted pumping the foot pump to empty the fresh water holding tank.
thanks for sharing this tip!
pat
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Mon Jan 08, 2007 2:20 pm    Post subject: Reply with quote
Don't feel alone Capt..... we'all did that foot pumping thing until we heard about the hose out the window trick.
Joel
SEA3PO
Page generation time: 0.0468s (PHP: 68% - SQL: 32%) - SQL queries: 28 - GZIP disabled - Debug on
