New trim tab indicator coming out.
flapbreaker
City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
PostPosted: Thu Nov 23, 2006 12:25 am    Post subject: New trim tab indicator coming out. Reply with quote
Stumbled across some info on another site regarding a new trim tab indicator product from Bennett that should be out by the end of the year. I'm pretty excited about it since their current indicator would require yet another hole or more dash space. Looks like they finally are releasing something that can replace the current switches.
The Electronic Control Display is a new and unique product. The wiring from the control on the dashboard back to the pump is single cable. The system includes Bennett’s Patented Auto Tab Retractor (Tabs up at ignition key off). No power connection is required at the helm, positive and negative power is fed at the pump simplifying installation and adding flexibility in mounting.
PostPosted: Thu Nov 23, 2006 2:22 am    Post subject: Reply with quote
This looks very similar to the Lenco LED/auto retract tab switch I upraded on the Rinker 270 we had prior to the Tom Cat--on those tabs (not as good as the Bennets) these switches were really handy. It made consistancy of trip in various conditions easy to obtain.
Happpy turkey day!
PostPosted: Thu Nov 23, 2006 2:33 am    Post subject: Reply with quote
flapbreaker-
Is this trim control/indicator retrofittable to older Bennet trim tab systems, or just usable on the new models?
flapbreaker
PostPosted: Thu Nov 23, 2006 11:02 am    Post subject: Reply with quote
Sea wolf, I'm not sure. I guess I was assuming it would fit all of theirs since their current "add on" indicator does. Here is a link to the discussion. You can actually ask the bennett rep since he's been the one providing information.
PostPosted: Thu Nov 23, 2006 11:48 am    Post subject: Reply with quote
flapbreaker-
Thanks for the link!
From the discussion, it sounds like the top part of the actuators (rams) must also be replaced, as there are sensors for the new system that are located there. Note the two illustrations below:
flapbreaker
PostPosted: Thu Nov 23, 2006 12:56 pm    Post subject: Reply with quote
You might be right about needing new tops but when I reviewed the installation instructions for their tpi2000 sensors you just modify them by adding a sensor so I was assuming the same process would be applied in their new unit. It will be interesting to see the cost and installation procedure for these when they become available.
PostPosted: Thu Nov 23, 2006 2:03 pm    Post subject: Reply with quote
flapbreaker-
Yup, there's quite a bit of uncertainty about these puppies as of yet!
They're supposed to have firm prices,etc., for the boat shows in January.
That deadline draws near!
Guess we'll have to just stay tuned!
Happy Thanksgiving!
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Thu Nov 23, 2006 10:58 pm    Post subject: Reply with quote
Looks like the Lenco we have on our boat. Complete with the auto-retract.
Mike
Page generation time: 0.0424s (PHP: 60% - SQL: 40%) - SQL queries: 21 - GZIP disabled - Debug on
