hrbucher
Vessel Name: RIGI
Photos: RIGI
Posted: Fri Oct 27, 2006 5:30 pm Post subject: Radar Mount |
I own a C-dory 25 with the radar bow factory installed. To mont the radar is it advisable to install with down tilt to compensate for bow up. If so what is the recommended down tilt?
Thanks Hans _________________ Hans R Bucher |
Posted: Fri Oct 27, 2006 5:54 pm Post subject: |
The vertical radar beam subtends an angle of ~30 deg (at the 3 dB points.) That's 15 deg. below the horizon. I wouldn't worry about it or just mount it with 5 deg. tilt up.
Not knowing where you're mounting the radar, I hope it's not on a aft mounted radar arch, or the beam is going through you every time the radar goes through a scan. On the other hand the pulse (chirp) is of small duration. Try to mount it in the front of the cabin top. That's why Journey On's radar arch is in front and as high as I could get it. According to Judy, I've lost enough brain cells already.
Boris |
tpbrady
Joined: 08 Feb 2005 Posts: 891 City/Region: Anchorage
Vessel Name: Bidarka II
Photos: Bidarka
Posted: Fri Oct 27, 2006 8:54 pm Post subject: |
Boris,
You got me thinking about my Furuno 1623 on a rear mounted arch. The vertical beam width is 25 degrees. Just looking at it from the side, it looks like that runs it right through the windlass on my CD22. If it was mounted on the front it would be going through my head on the stern. I am sure that would be the same on the 25.
That said, I don't think the power out on most smaller radar's is great enough to worry about either inside the cabin or in the cockpit regardless of the installation location. I draw the line on working on the roof with a dinghy or kayak with the radar on. Most of the time mine is off (standby) unless I'm running. _________________ Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981- |
Little Catelyn
Joined: 23 Feb 2005 Posts: 115 City/Region: Anacortes
Vessel Name: Little Catelyn
Photos: Little Catelyn
Posted: Fri Oct 27, 2006 9:26 pm Post subject: |
Well this is interesting... When our boat was on order I used the drawings on the C-dory site and added a radar arch to scale. Seems to me that the rear-cabin location offers just enough forward while providing a clear area aft. Hopefully this will prove to be a non-issue with the smaller radars we are using -- but, definitely worthy of consideration.
Corwin |
Joined: 02 Nov 2003 Posts: 21358 City/Region: Pensacola
Posted: Fri Oct 27, 2006 10:48 pm Post subject: |
The usual "Wedge" is 3 to 5 degrees. As noted the vertical beam width is 25 to 30 degrees-but you like to have it as near the horizontal as possiable. Also remember what attitude you will be running the boat in limited visability (probably not on planing mode--but either a displacement or semidisplacement). _________________ Bob Austin
SeaSpray
Joined: 12 Mar 2004 Posts: 1009 City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
Posted: Sat Oct 28, 2006 12:16 am Post subject: |
Just a thought. Would one of the microwave leak detectors be able to detect the radar beam if it were comming through the cabin?
Steve |
Posted: Sat Oct 28, 2006 12:59 am Post subject: |
I cannot answer if the microwave detector will detect it or not. We mount our radar directly over head of the helm station--Marie has a pacemaker (for 25 years)--so we are very much aware of unshielded microwave radiation--no probelm with the radar. My thought is that the radar arch is high enough above the passanger's head, that they will not be in the beam. Remember this is a total beam of 30 degrees, 15 above and 15 below the plane of the radar's axis.
I certainly do not advocate anyone putting their head or gonads in the radar beam!--Although it is generally felt that it is reasonably "safe"--you see all of these folks with radar on the flying bridge, or on a mast right behind their heads--not a good idea--but they seem to get away with it. |
DaveS
Joined: 01 Nov 2003 Posts: 3204 City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
Posted: Sat Oct 28, 2006 1:32 am Post subject: |
thataway wrote: |
But then, we don't know what they're thinking.....  _________________ Dave S.
"Sea Shift"
C-Brat #16 |
Sneaks
Joined: 06 Jun 2004 Posts: 2020 City/Region: San Diego (Encinitas)
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
Posted: Sat Oct 28, 2006 11:06 am Post subject: |
journey on wrote: | The vertical radar beam subtends an angle of ~30 deg (at the 3 dB points.) That's 15 deg. below the horizon. I wouldn't worry about it or just mount it with 5 deg. tilt up.
Boris |
thataway wrote: |
General comments:
My C-22 always runs best with it's nose in the air. That is to say a significant up angle on the bow. I purchased a radar mount with a built in 7 degree tilt downward, which puts the center of the beam a lot closer to level while cruising, and (IMHO) slightly lessens any radiation in the cockpit area, but that's an unintended benefit. Typically it's average power that one worries about, and good grief, I doubt if the average power output of any of our radars is over 25 watts! If CRS hasn't failed me, microwave power attenuates VERY quickly as a function of distance, so the "danger" if any truly exists might come from sticking your head (or your jewels) inside the radome itself!
With that said, I had a particularly interesting bout with cancer about 20 years ago. The MD's involved asked that I closely review my military activities some 20 years before that because it usually stemmed from over exposure to radar and, in general, that type of cancer manifests some 20 years or so after exposure, much like skin cancer and overexposure to the sun. As a Navy tech specializing in Radar and submarine navigation systems, sure enough, I remembered working on a submarine radar at one time and, due to poor tagging procedures and a simple mistake, my face had gotten very warm as I stood leaning over a disconnected waveguide leading to the antenna with the radar transmitting. Probably 5 minutes exposure to a pretty powerful radar at extremely close range.
So danger exists, for sure. How much from a recreational radar? In my opinion less than that from a cell phone pasted to your ear. Less than that from occasionally carrying extra gas cans on board and several orders of magnitude less than the dangers presented in just getting a C-Dory to the launch ramp.... |
Sneaks
Vessel Name: C-Brat
Posted: Sat Oct 28, 2006 11:42 am Post subject: |
Added note: Our illustrious Ancient Mariner, Dusty, should by all accounts be glowing in the dark by now from both reflected and direct radar exposure throughout his military career and recreational boating pastimes. Carrier radars have unwanted side lobes in every direction that in themselves, are many times more powerful than the average Raymarine 2-4kw system, and they often reflect right into the bridge area, not to mention the aircraft (and their pilots) get painted pretty well while launching and landing. He seems to be immune to Old Timer Disease, and his son, concieved during his career seems to have better than normal genes, so I can only comment that long term exposure may have some benefits as well.... _________________ Mary & Don Anderson
Brat #483
"C-Brat" 1993 C-16 angler/50 hp |
Byrdman
Joined: 06 Nov 2003 Posts: 3329 City/Region: Cumberland River, Clarksville,
Photos: FreeByrd and C-Byrd
Posted: Sat Oct 28, 2006 12:04 pm Post subject: |
OK, just how hard would it be to rig up something like NASCAR has to change the "wedge" on the car set up.. Hummm... Crank it up if yer going to be cruising at speed for some time.... crank it down if yer going to be going slow due to fog of just that is what ya want to do.... poke'r about mid-way if your are jumping about the area at different speeds.
Surely this is not a new idea.
Now having said that... if you have a CD22 ya need to take a look at the radar set up on Terry from NY boat "Last Dance." Simple set up...and a "wedge-y" thing might not need much fix-en to pull it off. _________________ Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
Never Deny Yourself The Pleasure of Helping Others. |
Sawdust
Joined: 01 Nov 2003 Posts: 1400 City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
Posted: Sat Oct 28, 2006 12:26 pm Post subject: |
Thanks, Don!
I needed the reminder - yep, I do glow in the dark. When I was with the Atomic Energy Commish my badge went off scale so many times they wanted to recycle me
I can't believe the small amounts of energy from our little 2-4 KW units can be harmful unless you were to sit on the gadget for a few days... but I sure don't know. There have been a jillion studies on this, but I'm no longer in the loop so clueless in Oak Harbor I be.
I like the aft location for the radar arch on the CD - although I've usually had the radar mounted forward - and if there is another C-Salt it will have the aft arch. Good place to stow fishing rods. Fish? Gotta go.
Dusty |
Sneaks
Vessel Name: C-Brat
Posted: Sat Oct 28, 2006 7:26 pm Post subject: |
Byrdman wrote: | OK, just how hard would it be to rig up something like NASCAR has to change the "wedge" on the car set up.. |
I bow to Pat the wedgie expert, but still think it would be overkill. Wedgie, no wedgie, fast or slow, rain or shine, for safety use the critical area within a mile still gets way more "paint power" than we will ever need on a 22 ft. or 25 ft. boat with a radome not over 12 ft. above the waterline. If I get run down by some fast boat, it ain't gonna be because my radar didn't "see" it - it'll be because I was a damn fool and either didn't know how to operate my radar or got mesmerised by the GPS bells and whistles and didn't keep one eye on the radar and the other out the windshield. |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1514 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Sat Oct 28, 2006 11:35 pm Post subject: |
Jan'05 I asked Raymarine's technical support team re potential hazard of mounting the radome too close to the top of people's heads (mine primarily!) in the cabin. I have since mounted it on a 6" Power Tower simply because it's sturdier now that I have a large backing plate under it. Their answer might be useful to this discussion.
Question:
Customer (Steve S) 01/12/2005 02:40 AM
I own an SL72+ unit with the 24nm, 18" radome/antenna. The performance is excellent and has most likely saved me from at least 1 high-speed, head-on collision in the fog over the 2 yrs I've been using it in So. Calif.
My question is radiation or electromagnetic danger from this unit (while ON). I've read your FAQ and the manual thoroughly. I temporarily set the radome directly on the cabin roof where I wanted it then measured distances from my head at the helm to the radome edge (passengers are further away). The plane of the base of the antenna is approx 13 inches above the top of my head while I'm seated. The straight distance from the outside edge of the antenna to the closest point on my head is about 30 inches. The manual recommends 36 inches or more. Should I purchase a 6" Scanstrut and mount higher for better protection?
Thanks.
Response:
Question Reference #050112-000003
Product Type: Radar
Sub-Product: Closed Radome Antennas
Type of Question: Installation Advice
Date Created: 01/12/2005 02:40 AM
Last Updated: 01/14/2005 07:29 AM
Product model name: SL72+
The radar of today are frequency driven rather than the older ones which are power driven and those are the ones that may cause problems. The only thing that you should be concerned about is if you or a passenger has a pacemaker, other than that the radar you have will not harm you.
Paul Ganong
Technical Support Specialist
Rayamrine Inc.
http://www.raymarine.com _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
Byrdman
Posted: Sun Oct 29, 2006 9:38 am Post subject: |
Hey Sneaks... Did you get the part about the pacemaker??
Dusty: Man...I thought you glowed at night just because of that big ol smile!!
Looking forward to seeing my left side friends in Jan.
Good talk here.,., with or without wedgies... NASCAR in Atlanta today... Watch for the wedge action. |
