Ted Osborne
Joined: 29 Dec 2004 Posts: 109 City/Region: Des Moines, WA
C-Dory Model: 24 Tomcat
Vessel Name: Tabbycat
Posted: Fri Sep 01, 2006 11:25 am Post subject: |
A product that I have had excellent results with is Spot-X. It comes in a powder and you mix a little water to make a paste like and put it on the window and scrub it around and use a towel to take off. _________________ Ted & Donna |
B~C
Vessel Name: Blue~C
Photos: Blue~C
Posted: Fri Sep 08, 2006 1:29 am Post subject: |
I like that Bar Keep stuff but I ran across the Spot- X and gave it a try. It worked to well, I can't tell if the durn windows are open or closed now, they're so clean. It says on the box not to use on painted sufaces but I had to try it on the Hondas. It did a fine job of cleaning of the deposits on the leg.
thanks for the tip _________________ Ken
1999 22' boaterhome |
Ozark Boater
Joined: 21 Mar 2006 Posts: 6 City/Region: Warrenville
State or Province: IL
Posted: Fri Sep 08, 2006 2:29 pm Post subject: |
One other thing that works for cleaning water spots and paint over-spray from glass is 000 steel wool. Move the steel wool in a back and forth motion and not in circles. Make certain there isn't any other residue (i.e. sand, dirt, etc.) and don't use any thing more coarse than 000. It works well. If you are nervous about trying this, test a small spot first.
Another trick we used in the body shop for removing wiper streaks from the windshield was epoxy thinner. Put some on a cotton rag (an old T-shirt works well) and clean the glass surface as you would with a glass cleaner. When moistening the rag, do it away from the boat so that you don't drip any on the surface. Follow the first step by cleaning with a glass cleaner.
A few words of caution here. Don't drip or spray it on any other surfaces and stay away from painted window frames or rubber trim or it may remove paint. This stuff is very flammable, so don't smoke while trying this. _________________ Jim
Boston Whaler 170 Montauk
C-Dory 25 Wanna Be
________________________
Nomad 25 Houseboat, Seaward 25 Sailboat, Boston Whaler Harpoon 4.6 Sailboat |
Chubby Bunny
C-Dory Year: 1998
Vessel Name: Jenny G
Photos: Jenny G
Posted: Sun Oct 08, 2006 11:52 pm Post subject: water stains on windows |
Everybody, I've basically finished this project and wanted to comment on several methods:
(1) Windex, 409 Glass, et al. Useless.
(2) Vinegar and water. Useless.
(3) Scraper blade. This removed a nice layer of junk but did cause noticable scratches. Having had this work 100% of the time I've done it at home to remove paint, I would not recommmend it in a marine environment to remove calcium/salt.
(4) "A-Maz" from the local Ace Hardware. This product is supposed to be rubbed on, then sit on the windows for awhile. I found that this did remove a nice bit of the stains but hit a point of diminishing returns.
(5) Bar Keeper's Friend. I had tried one coat before the A-Maz and didn't see any change. HOWEVER, having the time this morning to apply four or five coats with only moderate elbow grease, this removed 99% of the stains.
Conclusion: Bar Keeper's Friend is the technique to pursue if you have the time & patience to work through multiple scrubbings. Sea Wolf Joe, I think you were the first to mention this, so thanks for the advice!!!
Regards, _________________ Chubby Bunny |
C-Val
Joined: 15 Sep 2012 Posts: 296 City/Region: White Rock
C-Dory Year: 1988
Vessel Name: Seaduced
Photos: C-Val
Posted: Tue May 29, 2018 10:01 pm Post subject: |
Hi All
Just working thru this issue now - windows are so filled with salt spots can hardly see in the sun!
I rubbed window with bar keepers friend as suggested but haven’t noticed any change as of yet (Arm is tired!)
Do you think it would be ok to put the cream on wool pad on my drill to do a more thorough rubbing off of salt spots? We are talking serious baked on salt. Looks like hasn’t been cleaned since the 80’s!
What are your thoughts?
Thanks _________________ Writing a sea story with my C-Dory !
1982 22' Classic Popeye
1981 22' Classic Bad Boy Brutus
1988 22' Angler |
gulfcoast john
Joined: 14 Dec 2012 Posts: 990 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Tue May 29, 2018 10:11 pm Post subject: |
Bob Austin clued us in on the best tx: Amaze plus their poly sponges at any Ace Hardware, or Amazon. great on shower doors, too! Takes some elbow grease, but so does any alternative!
Then, Rain-x spray regularly.
Thanks again Bob for all your insights!
Best,
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150 |
Joined: 02 Nov 2003 Posts: 20848 City/Region: Pensacola
Posted: Tue May 29, 2018 11:06 pm Post subject: |
As John notes, we have found "Amaz" is a product one of our local glass companies put us onto. It is what they use for commercial cleaning of difficult stains.
I don't see any negative with the power buffer, but don't get it too hot...I have never tried the Amaz with a power buffer, but why not?
With Rainx (on glass only), the salt water will bead up and often you don't need the windshield wipers. It also makes other materials easier to get off. _________________ Bob Austin
C-Val
C-Dory Year: 1988
Photos: C-Val
Posted: Wed May 30, 2018 12:47 am Post subject: |
Thank you so much!
Will buy some Amaz tomorrow and give it a try! |
haliman
C-Dory Model: 19 Angler
Posted: Wed May 30, 2018 10:27 am Post subject: |
Barkeepers Friend is a great product and can get in a spray or powder form. Great for removing rust also. And it's cheap. |
Posted: Wed May 30, 2018 11:53 am Post subject: |
Yes, Barkeeper's friend is a great product--its principle ingredient is Tri Sodium Phosphate, (which is even cheaper). It is mostly for removing rust and similar stains. Not all that good for getting salt water stains off glass. |
Joined: 30 Sep 2006 Posts: 4656 City/Region: Lake Stevens via Honolulu
Posted: Wed May 30, 2018 2:54 pm Post subject: Re: Water stains on windows |
oldgrowth wrote: | sailor-d wrote: |
scrape with a razor blade (the ones with a rigid side) held at a low angle. |
I have used sailor-d's method and find it works better than anything else. |
Wet the glass prior and keep it wet as you scrape. Make sure the razor blade is NEW and SHARP. _________________ "We can go over there...behind the 'little one'....."
Joined: 27 Oct 2012 Posts: 3385 City/Region: SW Michigan
Posted: Wed May 30, 2018 7:35 pm Post subject: |
Wouldn't Salt-Away either straight or diluted a bit with water do the job too? If it's good enough for your engine, it'll probably do the windows. |
Posted: Wed May 30, 2018 8:33 pm Post subject: |
Salt-Away, contains sulfamic acid, and some Tri Sodium Phosphate, perhaps some anti corrosion ingredient. It used to list the sulfamic acid in the MSDS, but now only mentions the TSP. Claims non toxic to humans, except for slight eye and skin irritation. Generally it is thought to be about as effective as white vinegar.
Amaz is even more secretive--except there is a small amount of several organic compounds. One can will last a long time!
I think keeping RainX on the windshield is a lot less work than getting salt off if it drys and bakes on.... |
tsturm
Joined: 01 Nov 2003 Posts: 1135 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Sun Jul 01, 2018 1:08 am Post subject: |
thataway wrote: | As John notes, we have found "Amaz" is a product one of our local glass companies put us onto. It is what they use for commercial cleaning of difficult stains.
With Rainx (on glass only), the salt water will bead up and often you don't need the windshield wipers. It also makes other materials easier to get off. |
Bob, THANK YOU for the A-Maz tip!!. I ordered a can last week, tried it today, WORKED PERFECT! Buff it on with the little scotchbrite type pad they send with it & buff it off with a terry towel. I have tried all the other B/S, vinegar, steel wool, bar keepers etc. (other than the razorblade) & have had no luck.
Thanks again!!!
