fivolks
Joined: 01 Jul 2006 Posts: 2 City/Region: San Juan Islands
Posted: Sun Jul 02, 2006 8:20 pm Post subject: Fuel Tanks in 19' Angler |
Thanks in advance for helping me with my question!
I am looking at the 19' Angler and read on the C-Dory site that "A 40 gallon fuel system is standard". I have a few questions:
1. Is this a one tank system or a two tank system?
2. Has this system remained consistent in past years? I am looking for a late model C-dory 19 (2000+).
3. Does the fuel system on the 19' allow for fuel to be directly pumped into the tank(s) without being removed from the boat? |
Posted: Sun Jul 02, 2006 10:21 pm Post subject: |
This is a 2 tank system. 20 gals on each side. I don't know exactly how long these tanks have been used but it started way before 2000. You do not need to remove the tanks to fill. There are fill ports - one for each tank - on the top gunnels. By the way - if you are capable of lifting a 20 or (especially) a 40 gal tank filled with gasoline, you're MUCH stronger than the average guy and I definitely should not tease you about that aspect of your post ! _________________ Roger on Meant to be |
fivolks
Posted: Mon Jul 03, 2006 12:21 pm Post subject: |
Thanks - just wanted to make sure I had it right and it wasn't some kind of crazy multi-tank system. The six gallon tanks on my current boat are heavy enough - no way I could lift anything more! |
