Motor Position
Big dave
City/Region: Vancouver
Vessel Name: Raven Dancer
Photos: Raven Dancer
PostPosted: Mon Apr 17, 2006 2:38 pm    Post subject: Motor Position Reply with quote
I was down at the marina the other day having lunch in Raven Dancer, while eating I was reading my C-Dory manual and the manual for my 4 cycle Yamaha motor, In the C-Dory book it says the motor should be stored in the raised position, I thought that was rather odd so I looked up in the Yamaha manual and it said keep it in the normal running position and then they told a bunch of reasons to do so.
I went with the advise of the Yamaha manual and then took a walk around the marina looking at boats with outboards (most were 2 cycles) and found that it was about 50 / 50 half tilted up out of the water and the other half in the water.
So I was just wondering what the Brats are doing and why, or does it really even matter ?
Thanks.........Big Dave.
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Mon Apr 17, 2006 2:45 pm    Post subject: Reply with quote
In fresh water I don't know what difference it would make. In salt water I raise the motor out of the water when I am anchored or docked. Would rather not have the electrolysis working on it. Or am I showing my lack of knowledge here and there is plenty of electrolysis working in fresh water also?
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
Sawdust
City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
PostPosted: Mon Apr 17, 2006 3:53 pm    Post subject: Reply with quote
Remember that if the temp. is freezing - water in the lower unit can freeze and rupture the housing. (BTDT). I leave my outboards in the water if there is any possibility of freezing weather. Otherwise out of the water to reduce all the bad stuff.
Dusty
1984 22 Classic
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Mon Apr 17, 2006 10:51 pm    Post subject: Reply with quote
Hmmm... I always thought that the electrolysis required oxygen to work. So by raising the motor out of the water you are actually making it worse rather than better. I know that the metal that only occasionally got splashed by my reef tank would corrode much faster than the stuff fully submerged all the time. Am I way off base here?
Gary Johnson
KB7NFG
Sealife
City/Region: Woodland Hills
Vessel Name: SeaLife
Photos: SeaLife
PostPosted: Mon Apr 17, 2006 11:13 pm    Post subject: Reply with quote
I don't think it make a world of difference. Even in the raised position, the motor bracket still touches the water, and that's all you need for electrolisis. But if your zincs are in good condition, and your grounding wire between the motor bracket and lower unit is intact, you should be well enough protected in either position. Personally, I leave them down when ever I'm out overnight and moored. I prefer not to have the salt water drain and possibly build up a salt residue. Plus, they are less vunerable to being hit from behind.
Mike - Sealife
doc
City/Region: Auke Bay
C-Dory Year: 2017
Vessel Name: Bella Rey
Photos: C-Alaska
PostPosted: Tue Apr 18, 2006 12:13 am    Post subject: Reply with quote
Ditto me on leaving the motor in the water if there is any chance of freeze. Otherwise I will lift it up unless the parking is tight at the docks. After spending a good part of the past winter in the water, I have no broken housings to replace.
Steve and Colleen Torrence
Juneau, Alaska
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Tue Apr 18, 2006 1:21 am    Post subject: Reply with quote
Leaving the motor down too long in salt water can result in a growth of barancles, mussels, tube worms, and other stuff.
It's bad enough if it only grows on the outside, but the critters will grow inside water passages, case drains, & exhaust housings.
Larry H
A C-Brat since Nov 1, 2003
Sawdust
Photos: C-Salt
PostPosted: Tue Apr 18, 2006 11:04 am    Post subject: Reply with quote
Danged if you do and danged if you don't, eh Larry? Laughing
At least if you crack the housing you can get at the ugly critters inside when you replace it! Because I must keep my boat in the salt chuck I put up with this all the time. Down when it freezes, and up at all other times -- and worry.
Hey, get your .... over here and share a cuppa.
Dusty
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Tue Apr 18, 2006 1:06 pm    Post subject: Reply with quote
Dusty,
I would love to join you for a cuppa......as soon as I complete my work in So Cal and get back to paradise!
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Tue Apr 18, 2006 2:59 pm    Post subject: Reply with quote
Don't like letting nice props attract folks who would rather remove props than buy their own....so I generally go props and lower unit down in the water. Then, use it very often and keep the kritters ran out and the gunk blown off of the unit. But, this is fresh water up here. I think if it were salt water, I'd just lower the deduction and raise the props to keep the unit out of the salt water. Interesting point about the motor mount portion being in the water most of the time anyway.... Sort of makes you want to put clean and re-paint the motor mounts on the bi-annual maintenance checklist if ya leave her in the water.
Page generation time: 0.0262s (PHP: 76% - SQL: 24%) - SQL queries: 23 - GZIP disabled - Debug on
