HuntnFish925
Vessel Name: Cora J
Posted: Wed May 14, 2025 6:44 pm Post subject: New Suzuki 90 seems way too loud |
Hello all,
Long time lurker, and finally made an account. We recently re-powered our 2002 22 Cruiser with a 2023 Suzuki 90DFA. It has a 15 pitch aluminum 3 blade prop. We love the motor. Starts with barely a turn of the key, has plenty of power, and looks great on the boat. Previously, the boat was outfit with twin Yamaha 40hp.
We have one issue. The noise! The noise increase over twin 40hp is incredible. The motor seems SO much louder. It was even more so evident on our last trip. We went out fishing in some pretty rough seas. On our way back to port, we could only motor at about 9-12 mph. This put the motor right around 3200-3900 rpm. The harmonic noise and motor noise was unbearable. It seems like it turned the whole boat into an instrument and the vibration thought the entire boat was very loud. 2 people on the boat used kleenex in their ears as ear plugs and sat and covered their ears with their hands as it was almost unbearable. The trip back to port was about an hour. The noise from the boat was horrible.
So Im wondering if this is normal? Mind you, I used a Suzuki dealer that I was NOT happy with their install. They did a horrible job. Which I didnt know until after the purchase and install obviously. Im wondering if this was something that was messed up during install? Our twin 40's never made this much noise, or caused such a loud harmonic noise though the whole boat like this.
I know a lot of people have this motor. I love the motor. Just want to try and figure out a way to make trips, especially in the 3000-4000 rpm range, at least tolerable. |
Posted: Wed May 14, 2025 9:27 pm Post subject: |
Any chance you have a damaged prop or drive shaft? |
Joined: 02 Nov 2003 Posts: 21607 City/Region: Pensacola
Posted: Wed May 14, 2025 9:50 pm Post subject: |
That is not "normal"--we have a 140 Suzuki on my 18' Caracal Cat, and it is a quiet engine as they go. I am not sure what could cause that issue. However some resonate frequency is possible. Did you check out the transom? Two 40's and to a single, would have more holes in the transom. _________________ Bob Austin
HuntnFish925
Vessel Name: Cora J
Posted: Wed May 14, 2025 11:41 pm Post subject: |
Definitely not a damaged prop or shaft. The prop is still brand new looking, not a single scratch. The motor has only been in fresh water a few times and the ocean a few times. It has been like this since we got the new motor.
The holes in the transom were "filled" by the shop. They had wooden dowels plugged into them, and new glass was put over the back of the transom. You cant even tell there were twins on there before from the outside.
Im just worried it was something about the way the outboard was actually mounted. They completely screwed up all my wiring that wasn't outboard related (long story). So it wouldn't surprise me if they did something wrong on the mounting.
The motor makes EVERY panel on the boat vibrate, not like a violent shake, but a high frequency resonance. Especially between 2900-4000 RPM. |
tsturm
Joined: 01 Nov 2003 Posts: 1180 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Wed May 14, 2025 11:56 pm Post subject: |
HuntnFish925 wrote: | Definitely not a damaged prop or shaft. The prop is still brand new looking, not a single scratch. The motor has only been in fresh water a few times and the ocean a few times. It has been like this since we got the new motor.
Find a REAL DEALER, Suzuki's do not vibrate normally!
Have a bad / cracked spark plug?
My DF175 has 3000 trouble free hrs. Quiet as can be
Trim/tilt stuck all the way down? |
Joefairbanks
Vessel Name: Sjøhest
Photos: C-Darling
Posted: Thu May 15, 2025 11:26 am Post subject: |
Just throwing this out there-
Have you checked the bolts going through the transom that they used to bolt the new motor on? Check for tightness, as I can imagine a loose bolt or two would make vibrations like crazy.
Maybe check while you're there to see if they sealed anything when they redrilled for the new motor.
Just a suggestion... _________________ -Ken
2006 CC23 Sjøhest
1991 CD16 Angler C-Darling Sold 2025 |
kcohen4
Joined: 26 Oct 2020 Posts: 50 City/Region: WILLIAMSBURG
Vessel Name: Annie M.
Photos: Annie M
Posted: Thu May 15, 2025 12:52 pm Post subject: Noise |
Years ago I had same problem. I was trying different props with different pitch. I don't remember exactly which one caused the problem but when I changed the pitch of the prop the noise went back to normal _________________ 2004 16 Cruiser with 2019 50 Yamaha
1984 Grand Banks 36
1984 Boston Whaler 13
1982 CC Landfall 38
1979 Catalina 27 |
Xtraplus18
Joined: 14 Jan 2022 Posts: 63 City/Region: Battle abound
Vessel Name: C-Handler
Photos: C-Handler
Posted: Thu May 15, 2025 3:27 pm Post subject: |
My 2017 115HP Suzuki make little noise underway. I would check the prop or maybe the shaft internally may be slightly bent. Manufacturing defect?
These are very good engines. I see more and more in my area.
If you are in Oregon John from Sportscraft Marine or Blackhawk Marine might be able to help out. _________________ Ed,
2005 22’ Cruiser
C-Handler
1986 Wooldridge Xtraplus 18.5’
2016-2025 sold 02/26/2025 |
BigSwede
State or Province: MN
Vessel Name: Coddiwomple
Posted: Thu May 15, 2025 10:51 pm Post subject: |
Even a 2-stroke wouldn't be that loud... can't be normal. |
HuntnFish925
Vessel Name: Cora J
Posted: Sat May 17, 2025 3:21 pm Post subject: |
Joefairbanks wrote: | Just throwing this out there-
Just a suggestion... |
Im not very well educated on how outboards are mounted. Is there anything other than a through bolt that mounts the outboard? Any type of elastomer or material that is supposed to "deaden" the vibration from the motor?
Looking at the motor mount, its bolted through the transom, but the top of the mount is not resting on the top of the transom. Meaning if it was a tiller type that was resting on the top of the transom, this one is lifted off the transom by about 2 inches. Not sure why they mounted it like that. Unless thats normal. I can try and add pictures on here.
The noise of the actual motor seems appropriate, but the vibration of the boat seems way too much. Even on a cold start, when the motor starts, its vibrating from the start.
I do have another Suzuki dealer around here that is a bit further from my home, but it might be worth heading over there to have them check it out. |
Joefairbanks
Photos: C-Darling
Posted: Sat May 17, 2025 4:14 pm Post subject: |
Not having the top of the mount resting on top of the transom is fairly normal. The height of motor can be adjusted as needed, up or down. There should be 4 bolts mounting it to your transom, and nothing else. Most people use some type of marine sealant/light adhesive between the bracket and the transom. Also, the bolts should be sealed as well.
At least that is what I have seen. I’m sure someone with more experience and knowledge than I will also chime in here. |
Tug
Joined: 22 Jun 2007 Posts: 996 City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
Posted: Sat May 17, 2025 4:44 pm Post subject: |
I just did a quick search ,one cause may be that the impellor housing has corroded or cracked. This may cause a knocking noise as the impellor spins, replacing the impellor housing should fix it. ?? |
zuktaylor
Posted: Sun Jun 08, 2025 2:30 pm Post subject: |
Theres a little plastic plug on the back of the engine beside the tell tale hole, see if the plug has popped out, lost mine on a DF90 and was way louder at idle and cruise, replaced and glued a replacement plug in and good to go. Worth a look |
