Here is a dumb one, Sole's in 22 cockpits...
Donald Tyson
Photos: Thistle
PostPosted: Sun May 04, 2025 1:53 pm    Post subject: Here is a dumb one, Sole's in 22 cockpits... Reply with quote
Has anyone tried using their 22 without the floors in the cockpit? Would it be too wet afoot without the two floor pieces?
PostPosted: Sun May 04, 2025 2:14 pm    Post subject: Reply with quote
For many years the 22 came without removable or fixed cockpit floor of fiberglass. In that case, I used foam padding and / or the Vinyl loop pool mat material from American Floor mats. I have also used Dri Deck tiles under the vinyl loop or just dry deck alone. It is fine, and there can be small amounts of water, depending on what you are doing and teh weather (Ie rain without a cover over the cockpit. My 1993 22 did not have floors, the 2006 had removable floors; more recent boats have fixed floors. .
Donald Tyson
Photos: Thistle
PostPosted: Sun May 04, 2025 4:44 pm    Post subject: Reply with quote
To gain a couple inches of headroom I might try it. Bob, the carpet is a nice touch too.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sun May 04, 2025 5:11 pm    Post subject: Reply with quote
We used Dri-Dek to keep our feet (somewhat) dry. It gets soft in warm weather, but it mostly works.
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
PostPosted: Sun May 04, 2025 7:49 pm    Post subject: Reply with quote
I have dri-deck in Hammerhead and don’t care for it. I want to make some floorboards but the truth is the dri-deck may end up being good enough that other things are higher priority. The worst thing about it is it can slip out from under foot when you are leaning against the gunnel nearly causing a MOB situation.
Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sun May 04, 2025 9:27 pm    Post subject: Reply with quote
Donald,
My 2000, 22 did not have the raised deck. My buddy’s boat stored at my dock, was a few years newer and had the removable raised deck. My aft deck was not flat and was shaped to the contour of the hull.
Pros: the 2000 model rarely had water on the deck and had a simple non skid surface. There was never mold on the deck and it was simple to maintain.
Con: the surface was not absolutely flat.
The newer 22
Pros: it was flat and had a better looking non skid surface.
Con: it added weight aft and had water and mold underneath, most of the time.
Steve Baum
Homeport of Portsmouth, VA
Donald Tyson
Photos: Thistle
PostPosted: Mon May 05, 2025 10:28 am    Post subject: Reply with quote
Thanks Everyone,
My thought was to remove the floor in warm summer weather when the Bimini is up and the put them back in cooler weather when the Bimini is not up so much.
PostPosted: Mon May 05, 2025 11:20 am    Post subject: Reply with quote
The way I used Dry deck is that it is was cut to fit so it would not move when under foot. The vinyl loop mat or foam also helped to prevent any movement of the DriDeck.
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Mon May 05, 2025 12:55 pm    Post subject: Reply with quote
I rarely use the floor board on my 22, I kept a small rubber carpet by the cabin door in the cockpit since that is where the water will pool up, that work just fine for me. Main raison for me was weight saving and easier to keep clean.
Stephan
Donald Tyson
Photos: Thistle
PostPosted: Sun May 11, 2025 9:03 am    Post subject: Reply with quote
Yes, ultimately that is probably what we will do as it is the most effective and economical.
PostPosted: Sun May 11, 2025 6:03 pm    Post subject: Reply with quote
My 22 has the flat floor. I put Ikea tiles in the cockpit. I used the wood tiles for a few years. These tiles required varnishing the wood. This year I'm replacing them with the all plastic tiles. Not sure how this will work on the sloped floor.
Cost about US$100 to do at the time.
https://www.ikea.com/us/en/p/runnen-decking-outdoor-acacia-60518486/
https://www.ikea.com/us/en/p/runnen-decking-outdoor-beige-90476734/#content
Hellsranger
City/Region: Bellingham
C-Dory Year: 1991
Vessel Name: Golden Heart
Photos: Golden Heart
PostPosted: Tue May 13, 2025 2:23 pm    Post subject: 22' cockpit floor Reply with quote
My 1991, 22'cruiser has no raised floor and drydeck tiles cut to fit over the gelcoat floor.
One advantage of the drydeck floor mat is ease of removal. I can simply roll it up and toss it out on the dock to rinse off fish blood or mud from crab or shrimp pots that routinely finds its way under the mat, then rinse the mat and pop it back in. No stinky cockpit. I do have a mooring cover to keep the rain out.
What's so funny bout
peace, love and understanding?
Donald Tyson
Photos: Thistle
PostPosted: Wed May 14, 2025 7:49 am    Post subject: Reply with quote
Sobol that is a handsome solution. How often does it need removal/cleaning?
Why do you have Leesburg on your transom if you're really from MI? The Potomac is so shallow and rocky up that way Wink
Donald Tyson
Photos: Thistle
PostPosted: Wed May 14, 2025 7:55 am    Post subject: Re: 22' cockpit floor Reply with quote
This sounds interesting. A mat? I've only seen the squares. Do you have a web address?
Hellsranger
C-Dory Year: 1991
PostPosted: Wed May 14, 2025 9:50 pm    Post subject: reply to thistle Reply with quote
Thistle-
It is the squares. but they lock together into a mat that can be rolled up and removed easily, and just as easily re installed after hosing off.
Page generation time: 0.0521s (PHP: 70% - SQL: 30%) - SQL queries: 32 - GZIP disabled - Debug on
