Transom table
Jandera
City/Region: Vancouver
PostPosted: Wed Feb 26, 2025 7:43 pm    Post subject: Transom table Reply with quote
I was at the boat show the other day.... and I went to the C Dory exhibit. On the back of the of one of the boats there was a bar that had a table attached to it. And I was wondering if anybody knew where I can get one for my boat?
Please see link to photo
https://photos.app.goo.gl/ki5t1n8mKBxAfksW8
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Wed Feb 26, 2025 10:44 pm    Post subject: Reply with quote
Burnewiin makes that table, a company in White Salmon in Washington State, see the link below:
https://burnewiin.com/collections/tables-cutting-boards?gad_source=1&gclid=CjwKCAiAlPu9BhAjEiwA5NDSAwkV7lrZtrqTdB2ULA8IKH2WXHEmJWLbKLyeHdQ0Ky14_fVZ-VfY0BoCMwwQAvD_BwE
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
PostPosted: Wed Feb 26, 2025 10:45 pm    Post subject: Reply with quote
There is a name on the back of the table you pictured. That is "Burnewin". Do a Google search, and you will find their website. That will give you a way to purchase what you want.
The bar is custom made-and there are all sorts of ways to put a bar across the C Dory splashwell. Either have one fabricated ($$$) or use your ingenuity and come up with a way to do it cheap.
shad
Vessel Name: C-Squatch
Photos: C-Squatch
PostPosted: Thu Feb 27, 2025 11:34 am    Post subject: Reply with quote
Like you, I've been considering rigging up a table and have been researching the options. I have two Burnewiin stainless gunwale mounts, and they're pricey but nice. I use the gunwale mounts for multi-function rod, downrigger, and crap pot puller holders.
A slightly more budget friendly table option might be a Magma table attached to the Burnewiin mounts and bases.
https://magmaproducts.com/collections/all-fillet-tables
https://burnewiin.com/products/tb5730-table-legs-pair
https://burnewiin.com/products/gm300-mount
https://burnewiin.com/products/rk300-rail-mounting-kit
Vs.
https://burnewiin.com/products/cb5315-cutting-board
ricka
City/Region: Yreka
C-Dory Year: 2020
Photos: ricka
PostPosted: Thu Feb 27, 2025 12:25 pm    Post subject: cockpit table Reply with quote
We installed the large Burnewin Table on the TomCat between the stern railings and even added a dingy motor mount to it. They are built very well, worth the money.
There are pics of on page two of our album.
previuos vessels
1976 ORION TRIHULL 15
1984 BOSTON WHALER 17 MONTAUK
1996 BOSTON WHALER 21 CONQUEST
2006 BOSTON WHALER 17 MONTAUK
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Thu Feb 27, 2025 6:05 pm    Post subject: Reply with quote
Burnewinn - expensive but worth the investment. I made a temporary kayak rack for use with it when cruising.
http://www.c-brats.com/albums/album2856/Dingy_rack.jpg
Gary F
Moxieabs
City/Region: Cape Neddick
State or Province: ME
Vessel Name: Widget
Photos: Widget
PostPosted: Thu Feb 27, 2025 9:11 pm    Post subject: Reply with quote
For a much less expensive transom table check out photo #13 in Widget's album.
Moxieabs on WIDGET
Jandera
PostPosted: Sat Mar 01, 2025 11:31 am    Post subject: Reply with quote
I'm going to start looking around but it's the bar that I think is going to be most useful. Then I'll be able to clamp anything I want on it. I was hoping that something would have been made already. Thanks for the tips!.
shad
Photos: C-Squatch
PostPosted: Sat Mar 01, 2025 11:52 am    Post subject: Reply with quote
Some C-Brats have pieced together a rail using off-the-shelf components. I just bought some railing sections and fittings from LFS / Go2Marine to build a roof/kayak rack, and the tubing is fairly sturdy.
https://www.go2marine.com/shop-all-categories/maintenance-and-hardware/boat-hardware/deck-hardware/handrails-and-rail-fittings
At a glance, the following components might work depending on your use case:
Tubing: https://www.go2marine.com/Stainless-Steel-Tube-7-8-and-1-Diameter-Sold-by-the-Foot
Hinges: https://www.go2marine.com/sea-dog-top-mount-deck-hinges-stainless-steel-90-degrees
Tubing Ends: https://www.go2marine.com/Sea-Dog-Top-Fittings-Stainless-Steel-1-4-Pin
If you go that route, make sure you get the by-the-foot Morse Industries tubing. The Taco tubing is flimsy in comparison.
Page generation time: 0.0371s (PHP: 56% - SQL: 44%) - SQL queries: 22 - GZIP disabled - Debug on
