Moving battery bank to galley
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Thu Nov 07, 2024 2:52 pm    Post subject: Reply with quote
This a great informational thread. I am seriously thinking of putting LiFePO4 in my 25 Cruiser. I would be installing 2 100 ah batteries or a single 230 ah.
What would be helpful, to me at least, is a wiring diagram that includes:
-Fuses and where they should be located
-Fuse amperage at each location
-Wire gauge for all runs
-Where DC-DC charger should be located
-Where charger/inverter should be located
-Anything else I may have forgotten
This may be available somewhere on C-Brats as someone may have already designed a "typical" system and posted their results.
Thanks in advance!
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
Edward J
City/Region: Poulsbo
Vessel Name: Catfish
PostPosted: Fri Nov 08, 2024 11:13 am    Post subject: Reply with quote
I had two house and starter batteries moved to the floor at the helm seat, this really improved the drainage in the cockpit and also performance improved by getting up on plane faster. I took out the hot water tank and the switches are in the cabinet below the helm seat. I also added a Victron Multiplus charger / inverter below the front floor access panel below the helm panel. It was a lot of work but well worth it.
Ed Jonson 2008 Tomcat
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Fri Nov 08, 2024 12:13 pm    Post subject: Reply with quote
Ed, did you move your start batteries inside the cabin? If so, did you notice any effects?
Stephan
PostPosted: Fri Nov 08, 2024 2:46 pm    Post subject: Reply with quote
Thanks in advance!
There is no "this is the only way". A lot depends on what else is installed and where. We had removed our 6 gallon water heater under the aft dinette seat, and put the Bosch 2.5 gallon behind the sink under the galley. However we wanted the space for some specific pots and pans under that seat. We had a pull out refrigerator under the forward seat.
So we put the two Li batteries under the V Berth on the Port side, along with the large fuse to the inverter, the switch on / off, the shunt to monitor the battery and a 30 amp fuse to the DC to DC charger which is next to the engine start battery All of the foam had been removed, and there are no leaks. We put the inverter on the Stb side, along with two computer fans, with a snap disc thermostat set at 100* to force ventilate the inverter--one under the helm by foot rest, and one (suction) under the aft facing surface between the V berths. I ran 2/0 from the battery switch to the Victron Multiplus 2000/50 (charger)/80 (boost). This also has a transfer switch, and is hard wired. A 30 amp fuse was placed right by the DC To DC charger on the #8 wire running to the Ii battery.
Edward J
PostPosted: Sat Nov 09, 2024 4:43 pm    Post subject: Reply with quote
Stephan, when i moved the batteries forward i saw nice improvement in my Tomcat performance, up on plane much faster and cockpit able to be better at self bailing. My boat came with 5 batteries in the aft locker plus unknown to me when i purchased my Tomcat the outboards were mounted to high. I also repowered so with combined with moving batteries its a different boat from the original. Ed
C-Wolfe
Photos: C-Wolfe
PostPosted: Sat Nov 09, 2024 5:05 pm    Post subject: Reply with quote
Edward J wrote:
Stephan, when i moved the batteries forward i saw nice improvement in my Tomcat performance, up on plane much faster and cockpit able to be better at self bailing. My boat came with 5 batteries in the aft locker plus unknown to me when i purchased my Tomcat the outboards were mounted to high. I also repowered so with combined with moving batteries it’s a different boat from the original. Ed
A big reason for moving my battery is to improve the cockpit self bailing, and the reduced weight aft will help on plane also. I’ve added a kicker , about #90 much further aft, so I would like to move near twice that weight forward. I’m moving 2 group 31 AGM at -#65-70 each and I might move the 2 start group 27. That will move #240 forward. That should help with the engine trim also.
What was your previous power and what did you instal?
PostPosted: Sat Nov 09, 2024 9:18 pm    Post subject: Reply with quote
If you move the start batteries, you will have to provide heavy cables which may mitigate the weight and also are expensive. It might even "pay" to go to all Li Fe PO4 batteries, Start and house weight wise. My 255 remained self bailing. But I only put the 3.5 hp outboard in the center for very slow speed trolling.
There are many ways to change the weight distribution in the TC 255. There is all of the area under the V Berth, and one side where the water tank is not present forward (unless you have 2 water tanks, which C Dory would not do when I bought mine.)
Edward J
PostPosted: Sun Nov 10, 2024 11:57 am    Post subject: Reply with quote
Stephan I repowered with Mercury 150's with stainless steel props from 2008 honda 135's with aluminum props. Main reason i repowered the honda's were not very reliable in one motor would quit from over heating even after replacing all thermostats. So i have two house and two starter batteries under the floor at the helm seat, had to cut new opening. Ed
C-Wolfe
Photos: C-Wolfe
PostPosted: Sun Dec 29, 2024 8:55 pm    Post subject: Reply with quote
I had a couple days to think about my project and that is where I’m at, it can all change but as of now...
I will retired my start battery and use my AGM gr31 (previously use as house bank) as my start batteries, I purchased 2 LiTime 100 AH for my house bank and also 2 Victron TR smart DC/DC 12-12-18.
My start batteries and switches will be inside the hanging locker (Port Side as you enter the cabin), that will add 8-10 ft of wiring to the engines. I currently have enough 4AWG tinned wire for the whole project but I might need to get something bigger for that leg. The alternator is fuse at 90 amp but the starter is not fuse at all, I will add a terminal fuse at the battery, I have no idea what size to use, I can test load from the starter in the spring but I’d like to have it more or less figured out before then, I welcome any wisdom here.
For the house bank, I’m still debating on the location. Either behind the fridge, plenty of room for batteries and charger, only 5-6 ft between start and house bank, but I’m a bit concern about heat building up in there with both charger and fridge working simultaneously. other options are inside the galley or under the berth, that will bring the house batteries much closer to the bulk of my electrical wiring, and also more option for the main switch and breaker.
My skill at drawing electrical schematic are not very good, you guys can make fun of me all you want, but hopefully its good enough you can make sense of it. I’m still working on where to insert fuse and/or breaker, I welcome any advice on this as well as any other part of my project.
As always, I really appreciate all the wisdom that is share here, Thanks.
WCF
City/Region: Central
PostPosted: Tue Dec 31, 2024 8:06 pm    Post subject: Reply with quote
As Thataway wrote a while ago, there is no "right way" or perfect way of designing this.
I am not an EE nor do I hold any ABYC certification.
A few notes though, mostly in the form of more questions:
Why move the start batteries?
MRBF on a start battery: Most people obviously do not run fuses on the start circuit. I do think it is a good idea in theory. I would base the rating on whatever your outboard's starters are rated at + a margin of error, or the current carrying capacity of the wire, whichever is higher.
You don't show it, but MBRFs on the LiFePo4 batteries is also a good idea. I know there is some debate on this, but I use them with LiFePo4 w/ built in BMS.
You don't show any of the wire gauges, which would provide more context for what you are planning. 60A is quite light to run the entire boat, especially if you have a windlass. I believe my windlass is on a 50A breaker on it's own, but perhaps you are leaving the windlass connected to the start batteries? I also assume you have no intent of adding an inverter or inverter/charger?
Also not sure how your kicker is wired into your 1-2-both switch? I'm also not sure what your intention is with the way the switch is drawn. Might just be my misunderstanding of the drawing. Smile
Finally, for wiring simplicity, I would personally only run one DC-DC charger, and I would put the two LiFe4Po batteries on a similar 1-2 switch so they can be isolated and disconnected (suggested by ABYC.)
C-Wolfe
Photos: C-Wolfe
PostPosted: Tue Dec 31, 2024 10:58 pm    Post subject: Reply with quote
For many reason but here’s a few, I have a lot of corrosion in the wiring and switches, enough to create issues so engines won’t start. I had a very similar scenario on my 22 (14 YO at the time) any wiring inside the cabin is/was still in like new condition. I’m aiming for a do it right, do it once. The marine inspector recommended to address the drip around the batteries. It’s, coming from the hatch mostly maybe a cup or two per rainy day, enough to keep things damp. I also would like to move weight forward, and increase the available storage in the cockpit.
Because it will be a longer run, I would feel better if it was protected, I have not found a reliable answer on the starter draw, I can test this in the spring.
It’s not very clear on my drawing but I do have MBRF on each of the LiFePo4, then to the main breaker.
You don't show any of the wire gauges, which would provide more context for what you are planning. 60A is quite light to run the entire boat, especially if you have a windlass. I believe my windlass is on a 50A breaker on its own, but perhaps you are leaving the windlass connected to the start batteries? I also assume you have no intent of adding an inverter or inverter/charger?
For the bulk of this, I will be using 4AWG, probably bigger for the leg to the engines starter. The 60A breaker will have the house load minus the windlass and line hauler. No plan to add an inverter.
I will be using a BEP cluster switch. A port and starboard on/off switch and a 1/2/both/off switch. That allow me to jump start one battery with the other, have one engine charge either or both batteries. I’ll have the kicker to the common terminal, can use either battery to start it or have the kicker charge either start with or separate of the house bank. Hope that make more sense.
I really like the idea of the 1-2 switch, thanks, I will add this to my plan. The reason behind having 2 dc/dc charger is that each alternator is putting a charge on the house bank.
C-Wolfe
Photos: C-Wolfe
PostPosted: Tue Dec 31, 2024 11:01 pm    Post subject: Reply with quote
Hers is my engine battery cluster switch. It might help make more sense of my drawing/explanation.
WCF
PostPosted: Wed Jan 01, 2025 1:30 pm    Post subject: Reply with quote
All makes sense, seems like you have it under control Cool
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Jan 12, 2025 11:27 am    Post subject: Reply with quote
C-Wolfe wrote:
With a quick search, doesn’t look like I can get those LiTime ship to Alaska. It’s too bad because they look like a very good deal right now. Bob, I’m curious to know what your test shows.
WCF, how long have you been using those? What are your thoughts on it?
Check into a FREIGHT FORWARDER?
Ship to forwarder in seattle area then barge it to the port!
Pretty reasonable. Gear shed in Homer does/did this in the past!
Give them a call? Thumbs Up
C-Wolfe
Photos: C-Wolfe
PostPosted: Mon Jan 13, 2025 12:56 pm    Post subject: Reply with quote
That’s how I got my LiFePo battery, thank you for making me aware of this. Pretty easy process.
Page 2 of 3
Page generation time: 0.0514s (PHP: 69% - SQL: 31%) - SQL queries: 28 - GZIP disabled - Debug on
