Help: Replacing steering wheel
Roamad
City/Region: Sacramento
C-Dory Year: 1988
C-Dory Model: 22 Classic
Vessel Name: Fika
Photos: Roamad
PostPosted: Fri Oct 25, 2024 4:07 pm    Post subject: Help: Replacing steering wheel Reply with quote
I want to replace the steering wheel on my ‘83 C-Dory and have a few questions:
- Does my C-Dory have a standard 3/4” tapered steering shaft?
- What sort of steering wheel puller should I use to replace the old wheel?
- Any other tips for removing the old wheel?
I’ve done this job a few times on other boats (and cars) and it’s always difficult. With the current (original) steering wheel, I don’t see a lot of working room for a puller, so I’m sure it will be fun. For one thing, there’s almost no gap between the back of the wheel and the panel it’s mounted to. So…all tips are appreciated!
Here’s what I’m dealing with:
[/img]
Now: 1983 22’ C-Dory Classic, 2001 Honda 90hp
Then: 1988 16’ C-Dory Angler, 2008 Mercury 60hp
Tom Hruby
City/Region: Lacey
C-Dory Year: 2024
Vessel Name: WATT NOW
Photos: WATT NOW
PostPosted: Fri Oct 25, 2024 4:22 pm    Post subject: Reply with quote
I found an interesting you-tube video that might help you. In addition to what the video suggests, I recommend you also soak the shaft with WD-40, or preheat the wheel around the shaft with a hot gun (hair dryer). That will cause the metal to expand and help loosen the joint. Don't heat the wheel if you use the WD-40 since the latter is highly flammable.
https://www.youtube.com/watch?v=iDWDp06ap9k
WCF
City/Region: Central
PostPosted: Fri Oct 25, 2024 7:56 pm    Post subject: Reply with quote
-Yes, 3/4 tapered with a key.
- Any puller that work well with your wheel.
- Have a plan for what you will do if you cannot remove the wheel. On my 22 attempting to remove the wheel destroyed the wheel. No amount of hammering, torch or magic sprays would remove it. The puller eventually destroyed the (plastic) wheel. Even when the steering mechanism was removed from the boat, I was still not able to remove the remnants of the steering wheel hub from the shaft. Would not recommend trying to remove a stuck wheel the day before you want to take the boat out. Smile
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Fri Oct 25, 2024 8:16 pm    Post subject: Reply with quote
Thanks for the replies. So @WCF, what did you ultimately do when you were unable to remove your wheel???
WCF
PostPosted: Fri Oct 25, 2024 8:23 pm    Post subject: Reply with quote
Ordered a Baystar hydraulic steering setup.
A very expensive way to install a new wheel Smile I am glad it happened, the upgrade was well worth it. I needed the push to do it.
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Fri Oct 25, 2024 8:56 pm    Post subject: Reply with quote
Yikes, Ok, well I hope I’m not forced to go that route.
So @WCF, since you destroyed your original wheel, can you share a bit about how it was constructed? And did it look anything like mine in the photo above? Just wondering if you can suggest any internal metal skeleton that would be best to pry against with a puller. Or is it entirely plastic?
WCF
PostPosted: Fri Oct 25, 2024 9:18 pm    Post subject: Reply with quote
It did not look exactly the same, but similar. Mine was entirely plastic except for the hub which was metal and had fused onto the shaft. This is why the puller eventually wrecked the wheel; the arms of the puller had nothing solid to work against.
Also for the record, I only tried the puller after I tried the normal hitting the edge of the wheel, heat, potions, prayers, etc.
I am not saying you will have the same problem! I have removed steering wheels from ancient cars and had them fall off in my lap in seconds. Smile
PostPosted: Fri Oct 25, 2024 9:55 pm    Post subject: Reply with quote
My boat has a metal destroyer type wheel. I have tried a couple of times to get it off with no luck. I tried to use an auto type wheel puller, but there are no tapped holes for securing the puller to the wheel. A pulley or bearing puller might work. Since I have hydraulic steering I am reluctant to use a lot of force when pulling or banging on it because I don't want to damage the pump unit the wheel is attached to.
PostPosted: Sat Oct 26, 2024 12:16 am    Post subject: Reply with quote
Three pronged wheel puller. I would put PB blaster on the shaft first around the nut. Do take Tom's suggestion: no torch with WD 40 spray--WD 40 is one of the most common solvents which cases boat fires and human burns. You can heat the hub with a heat gun (still take fire precautions, since there is an open glowing element.). Also shrink the shaft with liquid nitrogen. (Dr ice works well enough).
I would suggest upgrading the steering at this time anyway. The hydraulic is that much better, and you can use a better autopilot if that is in the cards.
Let us know how all of this goes.
drbridge
Vessel Name: Susan Marie
Photos: Susan Marie
PostPosted: Sat Oct 26, 2024 12:40 pm    Post subject: Reply with quote
An auto mechanic friend of mine showed me a trick years ago that has worked on every steering wheel I have ever removed, including my C-Dory. The PB blaster is a good idea, although I prefer Aero-Kroil penatrent.
Loosen the steering wheel retaining nut a few turns but do not remove it. Grasp the wheel firmly with both hands and pull hard while flexing the wheel back and forth. If it does not come at first rotate wheel 1/4 turn and repeat. If it still does not come rotate wheel back to original position and repeat, etc. etc. When the wheel pops loose the nut will stop it from coming all the way off and putting you on your Butt. This has always worked for me and easy enough to try.
Doug & Susan
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Sat Oct 26, 2024 1:17 pm    Post subject: Reply with quote
You have a lot of good pointer above, but I just wanted to add that whatever lubricant you use, Ido like BP Blaster for that kind of situation, give it time to work its way deep in. Little tapping on the shaft with a ball pen hammer to create vibration will help, I will recommend to do this several time over the course of a couple days, or until it come loose.
Stephan
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Sat Oct 26, 2024 4:43 pm    Post subject: Reply with quote
Thanks for all the tips.
@WCF my wheel appears to be just like yours was: all plastic except for the hub itself. So this concerns me. Nothing solid for a puller to grab onto.
I’ll let y’all know how it goes.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Mon Oct 28, 2024 12:10 am    Post subject: Reply with quote
Thumbs Up Thumbs Up Thumbs Up
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Tue Nov 05, 2024 4:13 pm    Post subject: Reply with quote
Well I was able to get the old wheel off today. Surprisingly easy for a 40-yr-old boat! I didn’t even need a puller. But I did apply all the tricks y’all suggested. A bit of wiggling and then pulling one side at a time seemed to do the trick. The hardest part was getting the nut off as they didn’t give me a lot of surface area for a socket to grab onto. But the right tool combo finally did it. Much relief!!!
Page generation time: 0.0329s (PHP: 76% - SQL: 24%) - SQL queries: 27 - GZIP disabled - Debug on
