Molded insert replacements for cockpit of 25"
Schuster
City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
PostPosted: Sat Jan 27, 2024 11:28 am    Post subject: Molded insert replacements for cockpit of 25" Reply with quote
I have a 2007 25' and have decided that I would like to replace the cockpit bulkhead plastic molded inserts that are use for rod holders, deck brush etc. Does anyone know where I can order these from?
(Sea Witch)
25' Cruiser
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sat Jan 27, 2024 2:59 pm    Post subject: Reply with quote
Dave,
Can you post a photo?
Steve Baum
Homeport of Portsmouth, VA
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Sat Jan 27, 2024 5:06 pm    Post subject: Reply with quote
I wonder if the inserts you have are the same as what is installed in new
25 Cruisers? I would check with the factory.
Here are couple possibilities:
https://www.greatlakesskipper.com/boat-parts/boat-doors-hatches-port-windows/storage-boxes/l/parts-brand:north-american-plastics?amp%3Bp=2%2F%2F
https://www.tradeinn.com/waveinn/en/nuova-rade-utility-storage-case-side-mount-with-glass-holder-right/1223770/p?utm_source=google_products&utm_medium=merchant&id_producte=1251702&country=us&gad_source=1&gclid=CjwKCAiA8NKtBhBtEiwAq5aX2FwjV8B_xwtFmxk3c-9dCD7XsX5Z7VsRsD_6OLHEBIzRbm50xqITdRoCz5oQAvD_BwE&gclsrc=aw.ds
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
Salmon Fisher
PostPosted: Sat Jan 27, 2024 5:46 pm    Post subject: Reply with quote
On this page is what Colby Smith did to repair his.
http://www.c-brats.com/viewtopic.php?t=244&postdays=0&postorder=asc&start=4140
PostPosted: Sat Jan 27, 2024 10:20 pm    Post subject: Reply with quote
I repaired one, but one was too bad, so I purchased new. Went through NMI, Tom at the time, although I don't beleive he is still there. I think they were like $250 or so. Colby
Schuster
Photos: Sea Witch
PostPosted: Sun Jan 28, 2024 10:27 am    Post subject: Reply with quote
Thanks for the replies everyone. Steve I am unable to post a picture of the insert at this time, but the picture in Colby's post is as near as I can remember identical. I'm not sure of the measurements at this time either. Colby, I will check with NMI and hopefully come up with a solution. Patrick thank you for reply, very helpful but I guess I will need to get some measurements before I go any further. Hoping to get this done before May 1.
Salmon Fisher
PostPosted: Sun Jan 28, 2024 3:27 pm    Post subject: Reply with quote
Maybe this one will fit.
https://www.greatlakesskipper.com/sailfish-boat-coaming-storage-bin-51-2049-30-06-wa-w-net-ivory
Schuster
Photos: Sea Witch
PostPosted: Mon Jan 29, 2024 11:28 am    Post subject: Reply with quote
Thanks Patrick, I saw that one and it looks pretty close. The netting on that could be changed to put in the hard front retainer wall from the original inserts. I'll have to check the measurements for opening on the existing set up. That is where I store my 15lb downrigger weights when not in use so need something substantial.
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Mon Jan 29, 2024 4:23 pm    Post subject: Reply with quote
I modified mine on my 22 so they could carry a little more and a little more weight.
Jody Kidd
KE7WNG
Northern, Utah
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Mon Jan 29, 2024 5:20 pm    Post subject: Reply with quote
Jody, looks nice. I bet it holds lots of fishing items or whatever you want to put in there. Nice job!
I also like that electric plug for your Scotty Downrigger. Can you give us a name and part number for that plug. I don't like the original Scotty round plug as it tends to lose contact or not make contact easily unless you wiggle the connection just right. I have a friend who also has the same issue with his Scotty Downrigger. I know saltwater is the enemy with electrical connections but I need to try something different. Gary
Gary F
jkidd
PostPosted: Mon Jan 29, 2024 8:31 pm    Post subject: Reply with quote
It's a 50 amp Anderson connector you can get them off Amazon or Cabelas.
Schuster
Photos: Sea Witch
PostPosted: Mon Jan 29, 2024 9:36 pm    Post subject: Reply with quote
Thanks Jody, that looks very similar to mine. I've got the faceplate but not the bottom plate or the dividers.
DayBreak
C-Dory Year: 2018
Photos: DayBreak
PostPosted: Mon Jan 29, 2024 9:45 pm    Post subject: Reply with quote
[quote="jkidd] It's a 50 amp Anderson connector you can get them off Amazon or Cabelas.[/quote]
👍 Thanks Jody
Page generation time: 0.0289s (PHP: 70% - SQL: 30%) - SQL queries: 26 - GZIP disabled - Debug on
