Big dave
Joined: 20 Aug 2005 Posts: 268 City/Region: Vancouver
Vessel Name: Raven Dancer
Photos: Raven Dancer
Posted: Mon Sep 04, 2023 5:24 pm Post subject: Chart plotter |
Does anyone know if an external antenna is required on the new chart plotter’s/fish finders ? It seems none of the new plotters come with an external antenna. Do the new ones just receive signals through the roof of a C-Dory ?
Raven Dancer |
srbaum
Joined: 30 Aug 2010 Posts: 908 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Mon Sep 04, 2023 5:52 pm Post subject: |
Dave,
New chartplottters have built in GPS antennas, so the newer technology has precluded the need. My older Raymarine has a cabin top GPS antenna, where as my last several Garmin's have not had one nor needed one.
I have chart plotters on my other boats as well and none of them have external antenna. _________________ Steve Baum
Homeport of Portsmouth, VA
itiming
Joined: 28 Apr 2020 Posts: 53 City/Region: Iron River
Vessel Name: Obsession
Photos: Obsession
Posted: Mon Sep 04, 2023 7:44 pm Post subject: |
If you have radar, a heading sensor improves the radar overlay screen's use. Installation is usually done via a NEMA 2000 network between the MFD and the heading sensor. The boat's orientation then shows correctly and the radar overlays accurately over the chart. _________________ Chuck Olson
Obsession 2008, 22 Cruiser, Twin Honda 40hp
[/img]http://www.c-brats.com/albums/album3157/C_Dory_ObsessionLacLaBelle.thumb.jpeg[img] |
Joined: 27 Oct 2012 Posts: 3564 City/Region: SW Michigan
Posted: Mon Sep 04, 2023 9:02 pm Post subject: |
The last two chartplotters I had incorporated internal GPS. They could also use NMEA GPS from the appropriate sensor. The internal GPS seemed to work fine with the chartplotter mounted on the CD22 helm. Since I already had a NMEA GPS receiver (roof mounted) on the network I used that. |
Flashyfish
C-Dory Model: 19 Angler
Vessel Name: Kraken
Posted: Tue Sep 05, 2023 10:37 am Post subject: |
I have two of the Simrad Go9 chartplotters with internal GPS antennas. They function perfectly and have had zero problems with losing satellite contact.
Proven very reliable when navigating during fog or darkness in combination with radar.
I might upgrade at some point and add the electronic compass sensor. |
Joined: 02 Nov 2003 Posts: 21380 City/Region: Pensacola
Posted: Tue Sep 05, 2023 3:12 pm Post subject: |
Many of the earlier GPS had external antennas. Newer technology, both on the transmitting end (satellites) and the MFD with more sensitive receivers, along with the "Selective Availability" turned off, makes the GPS more accurate. Many now can use the "Galileo" "The EU system; "Glonass" the Russian System; and "BeiDou" Chinese system. Also the refresh rate has come down to 10 hz. Also there is the Real Time Kinematics, such as Point one, which gives accuracy in the cm range.
All of these will work in vehicles and thru normal house roofs etc, let alone the fiberglass layer of a C Dory. _________________ Bob Austin
