New Lazarette Covers
Goto page Previous  1, 2, 3 ... 10, 11, 12
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Thu Jul 20, 2023 1:45 pm    Post subject: Reply with quote
Butyl rubber tape, white. I buy a roll of tape that is about 3/4” wide by 1/8” thick. Zero leaks and I use it for almost everything topside. Just put in a new anchor windless on my 26. The windless and the anchor locker door have been bedded with butyl rubber. Some fool previously used silicone caulk and didn’t take the time to seal the balsa core. The core of the anchor locker door area and the windless are now sealed with epoxy.
Tech tip: when working on a specific area doing bedding or epoxy work, tape a plastic grocery bag next to your work area to place all of your waste in. Working on a hatch or fitting, place blue painters tape around the perimeter of the object. If using epoxy use good quality duct tape below the work area (epoxy doesn’t stick to the tape as long as you remove it, before the epoxy fully cures). Bed your hatch or whatever with butyl rubber tape. Bolt the item down, carefully score the item with a putty knife edge, remove the blue tape and you are done.
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Thu Jul 20, 2023 2:00 pm    Post subject: Reply with quote
MOOSE wrote:
After these long years, I finally decided to replace our Lazarette hatches, so I ordered two of the Imtra 40155 mediums. What did you folks use as a sealant when installing the new ones?
Thanks.
3M 4000 or 4200.
PostPosted: Thu Jul 20, 2023 3:01 pm    Post subject: Reply with quote
This!
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Thu Jul 20, 2023 5:01 pm    Post subject: Reply with quote
Thank you for your responses. Is this something an auto parts store would have? Pickings are rather slim here for shopping.
PostPosted: Thu Jul 20, 2023 8:38 pm    Post subject: Reply with quote
Amazon is you friend here.
https://www.amazon.com/s?k=Butyl+rubber+tape%2C+white&crid=1S3IRNK6MPKIR&sprefix=butyl+rubber+tape%2C+white%2Caps%2C106&ref=nb_sb_noss_2
PostPosted: Thu Jul 20, 2023 10:53 pm    Post subject: Reply with quote
Thanks.
Boat life, Life Seal, is a hybrid urethane/silicone, and specifically used with plastics installed on fiberglass.
MOOSE
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Fri Jul 21, 2023 8:43 am    Post subject: Reply with quote
Thanks, Bob; that looks like a good alternative. I sure look forward to finally getting hatches that don’t leak.
Page 12 of 12
Page generation time: 0.0292s (PHP: 70% - SQL: 30%) - SQL queries: 20 - GZIP disabled - Debug on
