Wallas stove replacement options
Goto page 1, 2, 3  Next
PNWNEWM
City/Region: Portland
PostPosted: Thu Apr 20, 2023 8:15 pm    Post subject: Wallas stove replacement options Reply with quote
Hey all. I am looking at a boat which has the stove missing. I don't have a lot of faith that it will be tracked down. I'm wondering what options are out there for a replacement that isn't $3,000 or if the Wallas Nordic DT is the end all stove and I just bite the bullet and buy that. Thanks in advance!
Ryan
PostPosted: Thu Apr 20, 2023 8:19 pm    Post subject: Reply with quote
I do a fair amount of cold weather boating, so I have a Webasto diesel heater, and it works great. As far as a cooking stove, we use a small portable one burner Butane stove. Does the job quite well. The boat came with a alcohol/electric KISS stove. I removed that and put a butcher block (7/8" solid oak board) in it's place. We can use the butane stove there, or anywhere we desire. The Webasto is going to run close to $2000 with everything. There are Chinese knockoffs for a lot less, but considering you have a flame inside the burner can, I decided to stick with the Webasto in this case. Colby
WCF
City/Region: Central
PostPosted: Thu Apr 20, 2023 8:58 pm    Post subject: Reply with quote
I know this opinion might get me kicked out of C-Brats: The Wallas stovetop and 1300 forced air heater that I had were both more hassle than they were worth. I spent more time trying to fix them than use them.
I shelled out some extra $$ for a "good" name brand Chinese diesel heater, and that also had several issues and got kicked off the boat.
I now use a camping style stove and a Dickinson Propane fireplace. There's not much that can go wrong with the Dickinson, and you can leave it for a month or a year without thinking about it, and it's still going to work. Old fuel is also not an issue. Also looks good!
Again, not going to make any friends here with this statement, but: I would consider the missing stove a blessing! Very Happy
chipwagon
City/Region: Victoria
Vessel Name: Sam 'n Leo
Photos: Sam 'n Leo
PostPosted: Thu Apr 20, 2023 9:51 pm    Post subject: Reply with quote
I totally agree that the Wallas stove is more trouble than it's worth. I have also spent more hours troubleshooting the thing over the years than I have generating any actual heat out of it. I was astounded to find out the thing is a $4500 option on new boats. Wow!
I was interested in this thread from 7 years ago http://www.c-brats.com/viewtopic.php?p=295254&sid=53db974113096756fc8430af370c3ede, timflan had a nice inexpensive idea to fill the counter cut out. I'm going to be researching heater replacements, will look into the Dickinson propane.
-Blair
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Thu Apr 20, 2023 11:11 pm    Post subject: Reply with quote
Coming up on six years with our Wallas Nordic DT stove. No problems ever with the unit and we are very satisfied with its use.
We operate the unit minimum once a month for 15 minutes and use red dye farm diesel.
Gary F
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Thu Apr 20, 2023 11:41 pm    Post subject: Reply with quote
We had a lot of problems with the original Wallas. A real love/hate relationship. It quit during several of our extended cruises, then on our 2012 extended SE Alaska cruise, I had to replace it or do without early in a three month cruise. Ended up replacing while on the cruise with a 85 model. That was 11 years ago & it’s been virtually trouble free since. 2012 was a very cold wet spring/summer in SE Alaska & we ended up running it for 784 hours in just the last 2 months of that cruise. That’s an average of running it for 13 hours a day for 60 days. I believe, from listening to others who have one, like Gary, the latest heater cooktop model, the Nordic DT is as good or better than any of the other options now, but the price like most everything else hard to take. One of my sons has one in his rvtrailer & his only complaint is with trailer being a small more for off road design, even on low heat it often overheats, the small inside trailer space.
Catman
C-Dory Year: 2017
Photos: Bambina
PostPosted: Fri Apr 21, 2023 2:34 am    Post subject: Reply with quote
My Nordic DT is a year older than Gary's and has been equally reliable. I love the thing, which I use about 10 months of the year for cooking and/or heating. Sometimes I use my one burner butane stove for quick stuff like steaming vegetables or boiling water. But the Wallas has been flawless.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Fri Apr 21, 2023 3:39 am    Post subject: Reply with quote
I have the exact same setup as Colby. I love the flexibility of the butane stove. The forced air heat can't be beat (for one thing the heat exits the system at floor level). Removing the stove creates a lot more counter space in the galley.
Frankly, if a boat doesn't already have a stove & heat system, going portable stove and diesel heat is the only ( Wink ) way to go....at least in cooler climates.
P.S. I offer one proviso. The butane stove uses those paint-can sized butane cylinders. If you want to boil a couple of quarts of water to cook crab or pasta etc, I find it wasteful to do that on the butane stove. So I have a relatively small inexpensive Coleman one burner 10,000 BTU burner head for that. It uses the ubiquitous 1 pound propane cylinders (which doubles as the stove's base) which I refill myself from a 5 gallon tank so fuel cost is ignorable. (I normally use the Coleman in the cockpit since usually there is a lot of steam involved.)
Sandy McKean
Purchased Tosca in 2014
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Fri Apr 21, 2023 9:32 am    Post subject: Reply with quote
Hi Ryan,
Another FL resident bought the former Noro-Lim, removed the working undercounter Wallas heater and sold it to us for $200.
After our exploratory Sept 2022 cruise from Ketchikan to Bellingham on the David B, we decided we preferred the Inside Passage of BC over Alaska and wouldn’t want to give up the undercounter space as mostly warm-weather cruisers.
https://www.blogger.com/blog/post/edit/5301133412174992135/5813142584862437187
We like a two burner $25 Coleman propane stove in the cockpit when anchoring out.
You (or anyone else) can have the Wallas heater for $200 plus shipping. I don’t have a dog in this fight, but I suspect this might be your best option even if it turns out you need help from Scan Marine. PM me if interested. We plan on leaving April 26 for an ‘all of FL coasts’ Loop Segment.
Cheers,
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150
PostPosted: Fri Apr 21, 2023 2:34 pm    Post subject: Reply with quote
My boat came with Kenyon butane stove built into my galley. It worked fine until the seals went and it became unsafe to use. Since seal kits are no longer available for that stove, I removed it and made a hardwood top for the counter where it went. Now I use portable butane stoves. I have two, a large one and a small one. I can use one or the other or both as is suitable for the cooking job at hand. I can also use the stoves in the cockpit or ashore as desired.
It depends on what you are looking for. Are you cooking, heating the boat, or both? The best solution depends on how you answer that question.
PostPosted: Fri Apr 21, 2023 3:16 pm    Post subject: Reply with quote
When we bought our 27fter It had neither a heater or a cook top. We decided on a espar heater system and I installed it my self. Easy to do and works great. Now that you can get them on amazon for half of what I paid. My good friend alex but one in his 3oft bay liner and loves it. cost 200 buck and has a remote that mine does not.
For cook top my wife and i both love the Origo alcohol stove. Its simple it works and its stupid proof. It just works every time. You can get fuel at any hardware store or large grocery store. Kmart or walmart or any place like that. Susan cook a lot of food on it. CraB, shrimp, fish, pasta noodles. fried chicken etc.. we do not eat a lot of sandwiches or camping food. Its egg sausage and harsh browns for breakfast every day. All that on a two burner stove top. best thing we did was to NOT put another wallas in the boat. Had on in the 22 and it was a constant problem after the first year.
PNWNEWM
PostPosted: Fri Apr 21, 2023 3:21 pm    Post subject: Great insights Reply with quote
Thank you all. What are folks that are using propane, butane, alcohol stoves doing about ventilation? Do you just keep windows and/or door open when cooking?
As for the stand alone heaters, are those easy to attach to the current exhaust port on the boat? Thanks!
PostPosted: Fri Apr 21, 2023 3:42 pm    Post subject: Reply with quote
another great thing about the espar style heater is they remove moister from the cabin. There are two air intakes. One for air you will heat and one for the burner. If you draw the burner air from the floor of the cab and not from the out side as the instructions say to, You will pick up all the moisture in the cab and burn it off and exhaust it to the our side. This really helps lower the humitiy/moisture in the cabin of the boat. We can dry towels in front of the hot air outlet at the table by hanging then from the table. more then enough heat with just the one out let.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Fri Apr 21, 2023 3:47 pm    Post subject: Reply with quote
Like I said, if I'm going to create a lot of steam, I cook in the cockpit (I just set the stove up on top of my cooler). If I'm inside, I have lots open; unless it's cold, then I crack windows a few inches near the galley (I do this for steam, I have never worried about CO2 etc...although a CO monitor is a must but mostly for engine fumes not stove).
What do you mean by "stand alone heater"? Something like a Heater Buddy? "Exhaust port"....what's that?
WCF
PostPosted: Fri Apr 21, 2023 3:58 pm    Post subject: Reply with quote
We use the single-burner propane camping stove outside the boat whenever possible, mostly for the smell and moisture. We do a lot of boat-in camping where there are docks, picnic tables and shelters. If inside the cabin, I crack a window.
It is important to understand the risks of propane and ignition sources. In addition to common sense and always sniff-testing the connections, I use a Propane and CO2 monitor/alarm. I also disconnect the disposable cans when not in use and keep them in a lazarette that I vented overboard.
For HEAT, I would be sure to use a system that takes combustion air from the outside and sends the exhaust outside.
The Chinese diesel heater that I had did not connect to the existing wallas exhaust fitting. The wallas fittings are both intake and exhaust where the knockoff stuff has separate intake and exhaust. A stainless swan-neck exhaust for the Chinese heaters are readily available and inexpensive, but mine was slightly smaller than the Wallas and required a plate to cover the old hole. One of many pains in going away from the Wallas stuff.
If you're not handy, a used or new Walls stovetop might be the easiest and fastest solution!
Page 1 of 3
Page generation time: 0.0476s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
