Installing Radar - Degree of dip?
Wanderer
City/Region: Annapolis, MD; The Villages, FL
State or Province: MD
Vessel Name: Wanderer
Photos: Wanderer
PostPosted: Mon Mar 13, 2006 3:13 pm    Post subject: Installing Radar - Degree of dip? Reply with quote
What angle do you think the water line makes with the water when a CD 22 is on a plane?
The Raymarine I've just bought scans in a horiz plane +/- 12.5 vertical degrees. I want to introduce a dip in the radar when at rest so that on a plane the sweep is horiz.
The 5 inch high mounting bracket has holes to attach to cabin top 5 inches square. So, I have to solve this equation:
x = inches to raise rear to achieve desired angle of dip over 5 inches
y = angle of dip in degrees
x = 5 tan(y)
So, another way to ask the question is what is y?
What have some others done?
Does the bow pulpit show up on the radar when tilted down, say 10 degrees?
George and Penny
Come travel with us: http://2Wander.com
PostPosted: Mon Mar 13, 2006 3:23 pm    Post subject: Reply with quote
George, a lot depends on how you've got your engines set and how you load the boat. Mine has a few degrees down tilt, see pix
and is not adjustable. You get some shims with the dome (I think) that you can put under the aft mounting bolts to give you some tilt if the mount doesn't have a built in tilt. Mine does.
charlie
Wanderer
Photos: Wanderer
PostPosted: Mon Mar 13, 2006 3:35 pm    Post subject: Reply with quote
Thanks Charlie.
If I can get out tomorrow with a level and a ruler I can get the tangent of the angle when on a plane. However, I'd rather be working on the installation.
Did you ever get the pictures I sent you?
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Mon Mar 13, 2006 3:50 pm    Post subject: Reply with quote
I too bought a radome strut mount. Mine has a built in 5 degree tilt and it seems to work out extremely well, regardless of how I load the boat.
Don
Mary & Don Anderson
Brat #483
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Mon Mar 13, 2006 5:06 pm    Post subject: Reply with quote
George,
I have the Raymarine radar on Naknek as well.
I'd don't recall exactly how high the mounting bracket is, but probably about five inches. As far as I can tell there is no shim to change the angle; just bracket on the cabin top, and the radar antenna.
I have had no complaints whatsoever with the radar performance as installed. In fact, my recollection is that when in-the-soup we usually in a displacement cruise mode, hence no appreciable plane angle.
I think the only issue might be exactly where (ie. how far aft) the unit is mounted, but again I'd say it's simply back far enough as to avoid the downward sweep of the forward edge of the cabin roof. Did that make sense??
Casey
C-Dory Naknek
Les Lampman
Dealer
City/Region: Whidbey Island
PostPosted: Mon Mar 13, 2006 8:06 pm    Post subject: Reply with quote
Hi Geroge,
If you're calculating all this because it's part of the pleasure for you that's just great; it's part of what makes this boating thing so much fun for different folks.
However (to keep it simple), if you get a 5" Power Tower (now Seaview Power Mount; I typically use the 5" forward leaning Pathfinder (Raymarine) model) and mount it on the cabin top directly and then mount the radome on that you'll end up with a very nicely performing installation. At speed where you typically want a little more range for picking up distant objects the radar will be very close to level; when you drop down to slower speeds when "in the soup" or at night the radar then is slightly down getting the best returns on close in objects which is exactly what you want. Even at slow speed you're still near the middle of the 25-degree range and you'll still pick up objects quite well at distance (especially the big guys you'd like to stay away from!).
You can calculate all this very precisely but the reality is that on a small boat such as the CD22 just the load (fuel, water, passengers, etc), the use of engine trim (and/or trim tabs), and pitching from sea conditons can vary the angle far greater than the shimming angle you might incorporate. The radar scanner is meant to be pretty forgiving as they're used on small power boats and sailboats which (except under very ideal conditions) are never "level".
Les
www.marinautboats.com
DodgeRam
City/Region: Vancouver Isl. CANADA
Vessel Name: SeaRam
Photos: SeaRam
PostPosted: Mon Mar 13, 2006 8:32 pm    Post subject: Reply with quote
I got rid of all the formulas , I installed the radar on my arch, stood behind it and it looked good . Then I put the boat in the water ,did the radar set to factory specs , then proceeded checking what the screen was seeing . Worked 100%. Use it in good weather to practice , and it is working find.
Gary SEARAM
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Tue Mar 14, 2006 12:38 am    Post subject: Reply with quote
each 10% of tilt on a 5" base is 1/2" up or down.
or each degree is just a shade over 3/64 of an inch.
on edit
I meant each 1% of tilt is 3/64" not degree. percent and degree are different.
PostPosted: Tue Mar 14, 2006 8:13 am    Post subject: Reply with quote
I guess I've forgotten my Calculus of Variations....
What is "10% tilt"? is 100% tilt a full 360 degrees?
How much is that in furlongs per fortnight? Shocked Rolling Eyes
charlie
oldgrowth
Photos: C-Voyager
PostPosted: Tue Mar 14, 2006 1:58 pm    Post subject: Reply with quote
Percent is the amount of rise or decrease in a given distance
You have a 100% rise when the amount of rise is the same as the distance
a 100' rise in 100" is 100%
a 50' rise in 100' is 50%
a 10' rise in 100' is 10%
a 1’ rise in 100’ is 1%
a 100’ rise in 100’ is 45 degrees
a 50’ rise in 100’ is ½ of 45 or 22.5 degrees
a 10’ rise in 100’ is 10% of 45 or 4.5 degrees
a 1’ rise in 100’ is 1% of 45 or .45 degrees
using your 5” square
a 5’ rise in 5” is 100% (that does not mean one end is 5” higher than the other is. You would have to extend an imaginary line on the base so that it is 5” from the starting point on a horizontal line & 5" up at that point.)
a 2.5” rise in 5” is 50%
a .5” rise in 5” is 10%
a .05” rise in 5” is 1% (.05’ is just over 3/64 of an inch)
a 5” rise in 5” is 45 degrees
a 2.5” rise in 5” is ½ of 45 or 22.5 degrees
a .5 rise in 5” is 10% of 45 or 4.5 degrees
a .05” or just over 3/64” rise in 5” is 1% of 45 or .45 degrees
I think you can see the pattern here. Don’t need to know that fancy math to figure it out.
Wanderer
Photos: Wanderer
PostPosted: Tue Mar 14, 2006 2:59 pm    Post subject: Reply with quote
I thank each of you for taking the time to respond.
Most answers seem to fall in two catagories: it depends…, and doesn’t matter. Both are probably (real-world) good answers. For the record, I did notice that no one answered the question. Les has the experience to know what works. Me, I have no experience so I have to rely on thinking about it.
My thinking produced these results: Most of the time when I need the radar, I will not be on a plane – no dip needed. Sometimes, I will be on a plane and using the radar for monitoring converging vessels. While the +/- 12.5 degrees may be all I need, I see no harm and maybe a small benefit in building in a little dip. I plan to dip 5 degrees.
With respect to the “fancy math”, I think raising the radome 0.4374 inches five inches from the pivot point will give me 5 degrees. Exclamation Question Anyone?
Dave said,
Dave, I admit to sometimes taking an, I think, to 9 decimal places. I don't know about percent of rise but with respect to angles, I think:
a 50’ rise in 100’ is 26.57 degrees
a 10’ rise in 100’ is 5.71 degrees
a 1’ rise in 100’ is 0.57 degrees
Wanderer
Photos: Wanderer
PostPosted: Tue Mar 14, 2006 3:12 pm    Post subject: Reply with quote
I'm thinking of installing the radome so that I can carry my dinghy inflated and upside down with the bow forward of the radar.
Three issues come to mind: Will it work, will the signal damage the dinghy and if I move the radome back to allow room aft of the light pole for the tube will I have positioned it too far aft?
Les Lampman
Dealer
PostPosted: Tue Mar 14, 2006 4:17 pm    Post subject: Reply with quote
Hi George,
I'll selectively answer your questions because I really don't know where my scientific calculator is (or remember how to use it!).
You won't see the bow rail on the radar.
It never hurts to optimize things; I just wanted to make sure you were doing it out of your desire to be persnickety about it and not because if you didn't you thought your radar might not work.
I believe that the most difficult thing is determining what you think level is (fore and aft). If you believe that the cabin top represents "level" then the easiest thing to do is to purchase a 5-degree radar mounting wedge (there are a couple available in the West Marine catalog). If the cabin top isn't level then I'd get one of those angle gauges from the home building center hold it at whatever angle you determine is appropriate and mark your wedge base material. Seems easier then the math! Smile
To the best of my knowledge the radar won't hurt the dinghy (I've just never heard anyone mentioning the possibility including the radar reps and lots of dinghies are near radar transmissions), and the dinghy won't interfere with the radar unless the motor plate (if there is one) ends up at the same level as the scanner.
The Power Tower is mounted on the flat portion of the cabin top; not on the sloping section just aft of the anchor light (just making sure!). Moving the dome back far enough to allow tube space will not cause problems for the radar.
The full length of the cabin top (from tip of visor to the rear overhang) is about 8 feet. The anchor light is 12" behind the forward edge of the visor and leans back at 15-degrees; this leaves roughly 6.5 feet of dingy storage space with the anchor light in place.
This is exactly the situation that lead to the development of the radar arches we designed. Once radar became all but standard I fought the conflicting space requirement (anchor light, radar and dinghy) continuously. I don't "push" any particular solution; it's for each person to decide what works for them but here are my thoughts on the arch...
1) The extra money you'll have to spend is the difference between the arch and the Power Tower.
2) With the arch in place the full 8 feet of cabin top is available for the dinghy since the forward anchor light base is no longer used; and you don't have to wrestle the dinghy over/past GPS, VHF antennas and such (they can move to the arch).
3) The arch makes a fantastic hand hold coming out of the cockpit onto the side decks. The cabin top handrails end up under the dinghy and that initial transition from bulkhead handgrip to the cabin top handrail under the dinghy can be a bit awkward. The arch is postioned so that you grab it before exiting the cockpit and you never let go on your way to the side deck.
4) The arch provides lots of places to attach rod holders, a radar reflector (it's sort of one on its own), a satellite radio antenna and so on.
I'm not against Power Tower mounts; I've done many and they work and look well...but they do create a bit of an issue for dinghy storage though not insurmountable.
Bluecrab
City/Region: Chestertown, Maryland's Eastern Shore
Vessel Name: Lizzie Ann
Photos: Lizzie Ann
PostPosted: Tue Mar 14, 2006 5:07 pm    Post subject: Reply with quote
George, I don't know about the angle issue - all I can tell you is that I mounted mine on the 5" Power Tower as Les has suggested and it seems to work just fine without shims. Great performance at speed and at rest. Don't kow if it could be improved by fidgeting with the angle a bit, but I've left well enough alone.
Are you all going to be at the Eastern Shore gathering this year? Hope to see you!
Lizzie Ann
oldgrowth
Photos: C-Voyager
PostPosted: Tue Mar 14, 2006 5:49 pm    Post subject: Reply with quote
George & Penny - You are right about degrees. I was wrong. Guess I had better go back and relearn that fancy math. The smaller the angle the smaller the change per degree. While the larger the angle the greater the change per degree. Percent stays constant.
Page generation time: 0.1225s (PHP: 34% - SQL: 66%) - SQL queries: 28 - GZIP disabled - Debug on
