TmBates
State or Province: ID
Vessel Name: Serenity Now
Photos: Serenity Now
Posted: Sun Sep 11, 2022 4:47 pm Post subject: Best sealant for cockpit/cabin seam |
Hi, I'm looking for the preferred sealant for the seam between the cockpit and cabin on the 23 Venture. I know I've come across a thread on this before but can't find it again. I appreciate any suggestions on what worked best to get the old stuff out as well.
Thank you,
Tom _________________ Tom & Marina Bates
Serenity Now, 2007 CC 23 Venture April 2022 - |
Joined: 27 Oct 2012 Posts: 3580 City/Region: SW Michigan
Posted: Sun Sep 11, 2022 4:55 pm Post subject: Re: Best sealant for cockpit/cabin seam |
TmBates wrote: | Hi, I'm looking for the preferred sealant for the seam between the cockpit and cabin on the 23 Venture. I know I've come across a thread on this before but can't find it again. I appreciate any suggestions on what worked best to get the old stuff out as well.
Thank you,
Tom |
I used 3M 5200. |
Joined: 02 Nov 2003 Posts: 21469 City/Region: Pensacola
Posted: Sun Sep 11, 2022 9:46 pm Post subject: |
There are several boats which have that seam--including the C Dory 25 which has a "hatch" which can be removed to change out fuel tank.
I used 3m 4000. It should not yellow, and can be removed if necessary. Usually C Dory used a Bostec compound. It can be removed with the bent back handle of a file and judicious use of a heat gun. Then there are various solvents such as lacquer thinner. (I keep a selection of solvents including MEK, alcohol, lacquer thinner, acetone, etc on hand. _________________ Bob Austin
TmBates
Posted: Sun Sep 11, 2022 10:06 pm Post subject: Sealant |
Thank you both for sharing your knowledge. Tom |
