C-Wolfe
Joined: 16 Sep 2020 Posts: 335 City/Region: Anchorage
Vessel Name: Valhalla
Photos: C-Wolfe
Posted: Tue Aug 30, 2022 8:09 pm Post subject: |
I give a couple call to Garmin and learn that any model will work with my unbalanced ram but I need to purchase, install and adjust a unbalanced valve kit to the 1.2 and 2 L pump, the 1L is plug and play, so that is what I got. I got the starter kit that includes pump, ECU, CCU, and nema 2k starter kit, no shadow drive or GHC and so far I’m not regretting it.
I installed it a couple weeks ago and it was pretty painless, I was out this weekend and got to set it up and give it a try. All I can say is wow, I’m loving it. _________________ Stephan
Sculpin; Drascombe Drifter 2005-2008 |
jkidd
Joined: 23 Oct 2006 Posts: 1668 City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
Posted: Tue Aug 30, 2022 8:36 pm Post subject: |
You should be able to turn the auto pilot data bar at the bottom of the screen so you don't have to give up half of your display. _________________ Jody Kidd
KE7WNG
Northern, Utah
C-Wolfe
Photos: C-Wolfe
Posted: Tue Aug 30, 2022 8:57 pm Post subject: |
jkidd wrote: | You should be able to turn the auto pilot data bar at the bottom of the screen so you don't have to give up half of your display. |
Thanks, not that I'm unhappy on how it is now but that will be nice, I know I still have a lot to learn.
I did the basic heading hold but was also able to create a track using auto guidance and have the autopilot follow it, it works pretty good. the only thing that I was not too keen on, and I'm sure I will find a work around, is that if you go off course while following a track for whatever reason, once you resume follow track, the auto pilot try to go back to the track as fast as possible and will make a sharp turn right away. Other then that, it work pretty smooth and I'm very happy with it. |
jkidd
Posted: Tue Aug 30, 2022 10:11 pm Post subject: |
Bar looks like this.
I usually manual steer back to the course manually and then turn it back on. |
C-Wolfe
Photos: C-Wolfe
Posted: Wed Aug 31, 2022 4:00 pm Post subject: |
jkidd, it looks like the bar is a feature available in the GPSMAP serie, not available in the echoMAP serie. I did play with it some more and was able to adjust the size of each split screen and it helps some. I'll keep fine tuning it over time but like I said before, I'm happy the way it is now.
