What’s it like on lake powell lately?
Goto page 1, 2, 3  Next
easy does it
City/Region: Redmond
Vessel Name: Pura Vida
Photos: Easy Does It
PostPosted: Thu Jul 28, 2022 11:19 am    Post subject: What’s it like on lake powell lately? Reply with quote
Looked for pura vida for 5 years and then moved to St George to be a lake powell junkie, 2 short trips summer of 2020 and then a quad bypass. Moved to Oregon and Hawaii but still still need another fix. It seems to me there may be a huge upside here in terms of what we could see? Of course the facilities would be a big hassle and require major planning something I am not to good at but still I can’t seem to resist these voices in my head calling me back. Is October to late?
PostPosted: Thu Jul 28, 2022 1:16 pm    Post subject: Reply with quote
At this point no launch ramp is open. Dangling rope has not been open this year for fuel. Any launch/ retrieval is for houseboats or other vessels for repairs and by tractor/tractors.
The water level is at least 15 feet below the end of the lowest level useful ramp. Powell is being maintained slightly higher than Meadl because of needs for power generation.
The up stream lakes and resistors are at about 66%, but inflow to them is limited. They are being maintained to allow constant flow to Powell (which has risen some from its low, to facilitate power generation.
So forget launching currently at Powell. By Oct, that 15 feet may be available and launching available. The weather is beginning to cool off. There are often thunderstorms but we have enjoyed Powell in Oct. in the past. With the limited facilities--you probably would be limited to range because of fuel and water. Even if you were to carry extra fuel, and conserve water there will be some limitations. I suppose one could boil or use filters to allow the lake water to be potable. We have always used lake water for bathing, doing dishes, and cooking if boiling the food. That leaves only drinking and some re-constitutional use of water for dehydrated food. If. you are careful the 20 to 30 gallons could last a moth of 2 people.
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Thu Jul 28, 2022 5:51 pm    Post subject: Reply with quote
Water level is at 3536. Bullfrogs Executive ramp is open and good to 3525. Stateline auxiliary ramp on the south end is also open to 3525. As for Dangling Rope the facility’s have been takin to Bullfrog for dismantling current water level doesn’t work for a marina in that spot. Take extra fuel with you. Can’t tell you how fast they’ll drain off 10’ of water. Just have to watch the water data base.
http://lakepowell.water-data.com/
Jody Kidd
KE7WNG
Northern, Utah
easy does it
PostPosted: Fri Jul 29, 2022 7:44 am    Post subject: Post subject Reply with quote
Thank you and I’m sure with the CD22 there are many other places but for us the Lake Powell experience was like nothing we had even ever dreamed of and it is hard to give it up. I wonder for those who have been around for a while, will it come back or is it gone? I am starting to wish I had voted for Al Gore. Ha
Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
PostPosted: Mon Aug 01, 2022 1:06 pm    Post subject: Reply with quote
The predictions I have read say Powell is a goner. The dam was built by during an era of dam-building frenzy, based on a very short window of rainfall data, and even that was a questionable analysis.
Current boats:
1988 16' Angler - "E-fishn-C"
Also:
Peter & Judy
City/Region: Olds
State or Province: AB
Vessel Name: Mistaya
Photos: Mistaya
PostPosted: Mon Aug 01, 2022 1:41 pm    Post subject: Reply with quote
I too am glad that I had the opportunity boat on Lake Powell in my C-Dory in 2018 for two weeks and 10 days by canoe in 2007. I think it is likely that Lake Powell is effectively gone forever. There might be a year or two here now and then, but with long term effects of climate change beginning to hit home and even greater demand on the water in the SW, I think it's long term future is bleak.
I too wish you had voted for Al Gore.
Peter & Judy Haase
Buffalo Horn Ranch
HMCB Mistaya
PostPosted: Mon Aug 01, 2022 6:24 pm    Post subject: Reply with quote
From what I read on the Facebook group, it sounds like if you can get launched, there is still plenty of water to enjoy. But the only fuel facilities are going to be at the Page, Az end, and perhaps Bullfrog. No more Dangling Rope or anything in between. Another good place to follow is www.wayneswords.net. I haven't checked in there in a few weeks, but I'm sure there is conversation there about water levels. Colby
jkidd
PostPosted: Tue Aug 02, 2022 9:07 am    Post subject: Reply with quote
The lake is still 130 Miles long and 400 feet deep at the dam. It has gone up the last two days. With all the problems that the drought has caused it has always delivered the lower states water shares. So it is doing exactly what it was supposed to do. If they would force the lower states to take a reduction it would recover. The only reason it is still working is because the upper states don't use all of there shares. Personally I would like to see Lake Mead and Powell go low enough that they can't generate any electricity. It would be a fun experiment to watch how they deal with the rolling blackouts.
flrockytop
Vessel Name: The Last One (to date)
Photos: C-LOVER
PostPosted: Tue Aug 02, 2022 4:38 pm    Post subject: Reply with quote
Wonder about what they are going to do about charging all those electric cars? Will it be like a lotto or do you get one charge a month.
2007 22 Cruiser
Track Me HERE
NA4RR
Roger Rockwell
Pensacola, Fl
PostPosted: Tue Aug 02, 2022 5:24 pm    Post subject: Reply with quote
Since they need to supply the houses and other buildings in the region with power for AC most of the year, I'm guessing that the load from charging the relatively small number of electric vehicles doesn't really register. If most of the cars in the region were electric, it might make a difference.
Fairbro
City/Region: Prescott
Vessel Name: Minnie Swann
Photos: Minnie Swann
PostPosted: Wed Aug 03, 2022 7:24 pm    Post subject: Reply with quote
So, is there a lesson to be learned here? Man plans…God laughs, maybe? Every present has a price? Everyone Complains about the weather but shouldn’t do anything about it?
It's something in the water!
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Tue Aug 09, 2022 1:16 am    Post subject: Reply with quote
In this case I think there is a lesson. The mentality at the time of the dam building craze was.. well.. a "craze". I think greed and gang mentality were at play. There were two major mistakes: (a) They overlooked the need for good data and analysis - they only used rainfall data going back a short time and overlooked larger trends. And (b) even the analysis they did on the rainfall data they had was wrong. It has since been reviewed and found to have significant errors.
Probably because people in charge were fixated on profit, eager to "just build" without careful planning, and short-sighted.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Tue Aug 09, 2022 12:36 pm    Post subject: Reply with quote
Again, I opine:
Man is the most insane species.
He worships an invisible God
and slaughters a visible Nature…
without realizing that this Nature
he slaughters is the invisible God
he worships.
—Hubert Reeves, 1932 - , Fr Canadian Astrophysicist
Aye
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Aug 09, 2022 1:14 pm    Post subject: Reply with quote
"Civilization exists by geological consent, subject to change without notice.”
Will Durant
PostPosted: Tue Aug 09, 2022 2:00 pm    Post subject: Reply with quote
Wood Zeppelin, could you please elaborate on your statement? When was this "craze"? Who was behind the "Craze"? Who were "People in charge fixated on profit, just build, and short sighted."
How long a time was the "Rainfall data"? Only rainfall data? Why was the analysis wrong? Is that true today with the Gross Dam now under construction and others planned?
Thank you.
Page 1 of 3
Page generation time: 0.0513s (PHP: 72% - SQL: 28%) - SQL queries: 28 - GZIP disabled - Debug on
