16 Cruiser Engine Possibility
ContagiousYJ
City/Region: Flaming Gorge
Vessel Name: C-Pup
Photos: C-Pup
PostPosted: Mon Jun 27, 2022 7:13 pm    Post subject: 16 Cruiser Engine Possibility Reply with quote
Hey all - I have a 2005 16 Cruiser (love her like crazy) and am considering repowering with a Honda 60.
Here are my thoughts - please tell me if I'm crazy! Smile
    - The tag inside my boat states Max engine rating of 55hp
    - 97% of my boating is on lakes above 6,000' elevation
    - Generally, an engine loses 3% of its rated power for every 1,000 feet of altitude.
    - This means I am losing at least 18% of my engines rated power
Based on this information, does this mean that if I were to repower at 60hp, and considering the power loss due to altitude, I would be within the safety rating of the transom?
Technically, I'd be pushing just under 50hp at 6,000'
Weight difference with a 60 is negligible
PostPosted: Mon Jun 27, 2022 10:04 pm    Post subject: Reply with quote
Should be no issues. You will run a different prop at the elevation of Flaming Gorge than at sea level. Generally 1" prop decrease per 1,000' after 3,000 feet, or 4" for Flaming Gorge..However since you are gong up in HP over the 40 that you may have now, probably half of the pitch would work best--or 2" reduction over what the boat would use as sea level prop.
ContagiousYJ
Vessel Name: C-Pup
Photos: C-Pup
PostPosted: Mon Jun 27, 2022 11:15 pm    Post subject: Reply with quote
Thank you, Bob - I have searched and read through enough posts in the forum to respect your knowledge and response!
I have not seen the pitch change numbers you listed above and find them to be very helpful!
From the Gorge to Yellowstone Lake, I tend to enjoy the higher elevations and think this approach will serve my little CD-16 well.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Jun 28, 2022 2:08 am    Post subject: Re: 16 Cruiser Engine Possibility Reply with quote
I have confidence it will be just fine.
ContagiousYJ
Vessel Name: C-Pup
Photos: C-Pup
PostPosted: Tue Jun 28, 2022 6:20 pm    Post subject: Reply with quote
Thank you - I think this approach will work out well!
K.C. Eldridge
C-Pup
2005 C-Dory 16 Cruiser (Jun. 2022 to Present)
2018 Super Air Nautique 210 (Aug. 2018 to Present)
1992 Bayliner 2452 Classic (Jul. 2012 to Present)
Home port: Manila, UT
Safetythird
City/Region: Hopkinton
PostPosted: Sun Jul 03, 2022 10:11 pm    Post subject: Reply with quote
Will your insurance still cover you if you have an accident while operating with a motor not rated for your vessel?
T.R. Bauer
PostPosted: Mon Jul 04, 2022 12:24 am    Post subject: Reply with quote
My agent told me they are on the hook for just about everything unless you're smuggling drugs from Columbia and doing something else illegal when I asked about repowering with twin 60s. I suppose this could vary by state as insurance often does.
ContagiousYJ
Vessel Name: C-Pup
Photos: C-Pup
PostPosted: Tue Jul 05, 2022 11:14 am    Post subject: Reply with quote
Definitely an interesting thing to consider - hadn't even thought of that!
Page generation time: 0.0488s (PHP: 42% - SQL: 58%) - SQL queries: 21 - GZIP disabled - Debug on
