Honda BF50 Stripped Spark Plug
ATPNW
City/Region: Covington
Vessel Name: Fellowship
Photos: Fellowship
PostPosted: Tue Apr 26, 2022 1:53 pm    Post subject: Honda BF50 Stripped Spark Plug Reply with quote
Well it looks like whoever changed or checked my spark plugs last jammed one back in and stripped the threads. This is the first time since I've owned the boat I've had to check them. Has anyone attempted to fix this before? I see there are a few tools I might be able to use such as a helicoil or re-thread kits. From some videos I've watched it looks moderately easy. Any advice you can shed or direction if this is more of a professional shop job?
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Tue Apr 26, 2022 2:05 pm    Post subject: Reply with quote
ATPNW,
Using a helicoil, or like product is relatively easy. I have repaired spark plug threads in many outboards, with very good results. My toolbox has about a dozen sizes, both metric and standard.
Now, the key to success is to follow the instructions to the letter and most importantly, all metal filings MUST be removed and not left in the cylinder. Removal of the filings it tricky, as they are aluminum and a magnetic tool will not remove them. I have had a few jobs, that I had to remove the cylinder head, to ensure that the filings did not remain behind...
Steve Baum
Homeport of Portsmouth, VA
ATPNW
Photos: Fellowship
PostPosted: Tue Apr 26, 2022 6:15 pm    Post subject: Reply with quote
Thanks for confirming my thoughts that its relatively easy, ill be sure to watch out for those shavings/burrs. Any suggestions on a kit? I see helicoil and time sert (time sert claims to hold up better). My plugs are NGK DR7EA, threads are 12mm and reach is 19mm/.75inch.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Apr 26, 2022 11:24 pm    Post subject: Reply with quote
I suspect it will be fine for a very long time after you repair the threads.
Knipet
City/Region: Orcas Island
Vessel Name: Pan-A-C'ya
Photos: Pan-A-C'ya
PostPosted: Tue Apr 26, 2022 11:39 pm    Post subject: Reply with quote
srbaum wrote:
ATPNW,
When using a helicoil, I've had great success with reducing the nozzle of my shop-vac down to a length of tubing that I can get into the spark plug hole.
Steve & Joanie
2021 Venture 23 "Pan-A-C'ya
Formerly C-Sharp - 2006 22 Cruiser
ATPNW
Photos: Fellowship
PostPosted: Wed Apr 27, 2022 11:56 am    Post subject: Reply with quote
Knipet wrote:
srbaum wrote:
ATPNW,
Thanks! I just bought an attachment that should allow me to do this.
Also, for any future member who comes across this. I spoke with a rep from Time Sert and for the Honda BF50 / NGK DR7EA plug they reccomended their M12x1.25 Spark Plug Thread Repair kit with Inserts p/n 4212-125
Safetythird
City/Region: Hopkinton
PostPosted: Wed Apr 27, 2022 3:48 pm    Post subject: Reply with quote
A properly installed helicoil is much stronger than the base metal it is threaded into.
You won't have any issues with one.
ATPNW
Photos: Fellowship
PostPosted: Mon May 02, 2022 8:24 pm    Post subject: Reply with quote
Well unfortunately the time-sert went in a little misaligned. The sert doesnt sit completely flush on the head by what looks like a thread or two. This causes the spark plug to be positioned off just enough that i cant get a thin wall 18mm socket over it. Contemplating my options here:
1.Remove time sert, and try to thread a new one in. This option seems low risk and also low reward. If my thread was off by one at the initial screwin, it would have given me troubles early on in the setting of the sert i would think.
2.Remove time sert. Take the step bit and try and tap new threads. My concern here is the step bit is the same diameter as the hole now and im only off by a little, so my margin of error is small.
3.Take it to a shop and see if they have any ideas how to fix it. Although my guess is that would entail a new head and a long wait.
srbaum
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon May 02, 2022 10:12 pm    Post subject: Reply with quote
A misaligned insert, will require a new head.
T.R. Bauer
PostPosted: Tue May 03, 2022 9:25 am    Post subject: Reply with quote
This doesn't sound good. Dang! I hope you don't have to get a new head.
ATPNW
Photos: Fellowship
PostPosted: Tue May 03, 2022 11:20 am    Post subject: Reply with quote
All may not be lost after all. I removed the little rubber boot inside the thin wall spark plug socket and was able to get a firm grip on the hex (I know this has risks). I can’t be certain but I didn’t hear/feel the porcelain touch the socket. Either way I plan to reinsert the boot once the plug frees up to be safe. Will hopefully fire her up later this afternoon when the time is more appropriate and then call it good.
PostPosted: Tue May 03, 2022 1:29 pm    Post subject: Reply with quote
With the misaligned insert, will the spark plug seat properly?
ATPNW
Photos: Fellowship
PostPosted: Tue May 03, 2022 1:43 pm    Post subject: Reply with quote
It looks to seat flush on the insert yes. I’ll double check before I fire it up.
T.R. Bauer
PostPosted: Tue May 03, 2022 10:51 pm    Post subject: Reply with quote
I suspect it's done and sounds like it worked out.
ATPNW
Photos: Fellowship
PostPosted: Tue May 03, 2022 10:55 pm    Post subject: Reply with quote
Yep all seems to be well after firing it up and running it for a bit. Thanks all for the help and suggestions!
Page generation time: 0.0565s (PHP: 50% - SQL: 50%) - SQL queries: 28 - GZIP disabled - Debug on
