Joined: 30 Sep 2006 Posts: 4656 City/Region: Lake Stevens via Honolulu
Posted: Mon Oct 31, 2016 2:12 pm Post subject: |
Quote: | When I want hot water I turn the everything off and flip the switch for the water heater. |
Ditto. If we need to top off the batteries, we do the same with the battery charger. _________________ "We can go over there...behind the 'little one'....."
Posted: Mon Oct 31, 2016 2:19 pm Post subject: |
By the way, why do we say "hot water heater"? Doesn't a water heater end up with hot water? We're not heating hot water even hotter?
Boris |
Kushtaka
Photos: Kushtaka
Posted: Mon Oct 31, 2016 4:41 pm Post subject: |
journey on wrote: | By the way, why do we say "hot water heater"? Doesn't a water heater end up with hot water? We're not heating hot water even hotter?
Boris |
Let me check the MSDS Sheets! |
Joined: 02 Nov 2003 Posts: 20860 City/Region: Pensacola
Posted: Mon Oct 31, 2016 5:47 pm Post subject: |
Solar heat = Sun shower--far more efficient than any form a controller...! _________________ Bob Austin
Posted: Mon Oct 31, 2016 5:59 pm Post subject: |
Boris |
I continually argue about this same issue, with the Mrs. She calls it "tuna fish". What? Is not a tuna a FISH? We don't say beef cow. It's redundant. |
Jake
Posted: Tue Nov 01, 2016 8:13 am Post subject: |
localboy wrote: | journey on wrote: | By the way, why do we say "hot water heater"? Doesn't a water heater end up with hot water? We're not heating hot water even hotter?
Boris |
Beef cow, dairy cow, etc. |
Posted: Tue Nov 01, 2016 8:40 am Post subject: |
Jake wrote: | localboy wrote: | journey on wrote: | By the way, why do we say "hot water heater"? Doesn't a water heater end up with hot water? We're not heating hot water even hotter?
Boris |
Everyone know someone to take the steaks out of the freezer to UN Thaw? Yeah, me too
Sun shower even works on semi cloudy days.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Tue Nov 01, 2016 11:01 am Post subject: |
The common sun shower has a push/pull spray head on the end of the tube. You have to use both hands to use it. It's clumsy and you waste some of the water while fumbling with the spray head. When shampooing, it's like playing pin-the-tail-on-the-donkey. Plus, because it is gravity operated, I have to lay it on the cabin top and then get on my knees for a shower.
One solution is to buy additional hose, a connector, and a bulb pump like this:
https://www.walmart.com/ip/6-Tube-Siphon-Pump/39109763?wmlspartner=wlpa&selectedSellerId=795&adid=22222222227026953635&wl0=&wl1=g&wl2=c&wl3=56097132369&wl4=pla-88705505049&wl5=9033322&wl6=&wl7=&wl8=&wl9=pla&wl10=112562476&wl11=online&wl12=39109763&wl13=&veh=sem
With the right amount of tubing, the bag is on the cabin top, the bulb pump lays on the cockpit sole (when showering al fresco), the shower head is hung up high (usually a problem with the gravity feed system), and you step on the bulb when you want 4 oz. of water to squirt out of the shower head.
Do not make the mistake of telling the first mate how many squirts she gets. The system is miserly enough.
Mark |
South of Heaven
Photos: Blue Water
Posted: Tue Nov 01, 2016 11:08 am Post subject: |
Thanks for the all prompt responses guys! So in a nutshell I shouldn't be worried about it and just scale back my other draws. Great, that was easy. _________________ <><><> Jason <><><>
kaelc
Vessel Name: Island Magic
Photos: Stil-Afloat
CC Rider
Joined: 19 Nov 2013 Posts: 157 City/Region: Tsawwassen
Vessel Name: CC Rider
Photos: CC Rider
Posted: Tue Jan 04, 2022 5:09 pm Post subject: |
I mean no dis-respect, but this reads to me that you need a generator that matches or is greater than the current rating of the charger. This simply isn't true.
Providing one is discussing the 120VAC output of the generator (as some gens have a 12V limited output as well), a 17A rated generator can easily power a 20 amp or more 12V battery charger.
A 20A, 12V charger (~250 watts) will theoretically draw a little more than 2 amps of 120 VAC power.
My Mastervolt 3-leg 25A charger draws (according to spec) about 450 watts or about 4 amps from the 120VAC source. I can run it all day long with my Honda 1000 generator. Even with other loads on the 120VAC power (fridge, computer, etc.). _________________ MMSI#: 316033635 |
Posted: Tue Jan 04, 2022 7:15 pm Post subject: |
Apples and oranges--the Honda is 2000 watts 110 V AC (realistically about 16 amps on long run). The newer Honda 2200 has another amp out put on 110 V AC--but has other features, such as run the carburetor "Almost" dry--still should be drained for long term storage.
The Battery charger is XX amps 12 vlots DC. The input amp draw of the battery charger is only going to be a few amps. Agree with CC Rider. |
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Wed Jan 05, 2022 3:45 pm Post subject: |
Quote: | ....the Honda is 2000 watts 110 V AC..... |
Bob, I'm not bothering to do this post to "correct" you, but rather to simply share something I learned about 5 years ago. It is quite simple, but it sort of "blew my mind" since I had been saying 110v for over 60 years.
These days almost everywhere in the USA, residential line voltage is 120v. True, decades ago it was 110v, but no longer. The interesting part of this is: why this is so. Back when I was born in the 1940s, voltage in your home was 110v. But as demand for electricity continued to grow, electric utilities needed to generate more watts to satisfy power demands. The most straight forward way to increase watts (power) is to increase the amperage flow; however, by then too much supply side wiring was at its max capacity; so the utilities solved the problem for a while by increasing the home delivered voltage to 115v.....voila, more watts. Later they did it again for the same reasons and raised the "standard" home voltage to today's 120V. Old guys like me and Bob still tend to say 110v because that's what we grew up with. Also, it is not hard to find stickers on appliances and such that still say 115v. I don't know if all of the USA is on the 120v standard or not. Maybe there are still pockets that operate at 110v or 115v, but I assume that would make interconnecting to other power grids problematical.
Is this important? No, but it is interesting I think. The one case where using 110 vs 120 is important is in calculations like this thread is discussing. For example, the Honda 2000 operates at 120v not 110v so the available amps from a Honda 2000 generator is somewhat less than a calculation at 110v would indicate. _________________ Sandy McKean
Purchased Tosca in 2014
Re-powered to Yammi 200 in 2015 |
Posted: Wed Jan 05, 2022 3:49 pm Post subject: |
Yep we answer questions with common expressions and in the World it is 110/120 vs 220/240 Alterating current.
My father was and EE and table talk was power grid and voltages. We had out current graphed at home. My grid currently is 137.4 volts (may not be true RMS.)
But in fact it does vary a fair amount. |
Posted: Wed Jan 05, 2022 7:42 pm Post subject: |
Sandy, Thanks for clearing that up. I have often wondered what the deal was with the 110/120 bit. Now I know. Learn something new here every day.
SleepyC
