trebleplink
Joined: 21 Jan 2011 Posts: 15 City/Region: Bowling Green
State or Province: KY
Vessel Name: Cscape
Posted: Sun Nov 14, 2021 10:02 am Post subject: Honda gen location |
I'm adding a EU1000i (29 lb inverter generator) to my 16 cruiser (CPAP and some 500w DRY heat)
Considering noise and co2 safety, where is the best location? _________________ W4NEQ |
Joined: 27 Oct 2012 Posts: 3385 City/Region: SW Michigan
Posted: Sun Nov 14, 2021 12:14 pm Post subject: Re: Honda gen location |
trebleplink wrote: | I'm adding a EU1000i (29 lb inverter generator) to my 16 cruiser (CPAP and some 500w DRY heat)
Considering noise and co2 safety, where is the best location? |
Don't know about the 16, but on my 22 the Honda 1000 goes on a folding step stool (to elevate it) on the swim step. I added hold downs to the step and the generator and stool are secured with a ratchet strap.
Before deploying this setup, the stool and generator have a line secured to a cleat to prevent things being lost overboard during setup and retrieval.
Step stool is similar to this https://www.walmart.com/ip/Folding-Step-Stool/38437780
Haven't tried using the gen for heat, I use it to run a air conditioner. I have an external 3 gallon tank for the generator (easy conversion) for extended running.
I use a propane heater when it is cold. |
Joined: 02 Nov 2003 Posts: 20844 City/Region: Pensacola
Posted: Sun Nov 14, 2021 5:47 pm Post subject: |
On our 22, with put the generator on top of a milk crate, with a plywood board with detents for the generator feet, and blocks to keep the plywood centered on the crate. There were bungee cords holding the whole works in place.
The 16 without a sold bulkhead and door is more likely to leak CO forward. Be sure and have at least 3 CO monitors. One by pilots head, one by navigator's head and one where your head would rest when sleeping. _________________ Bob Austin
Posted: Sun Nov 14, 2021 11:17 pm Post subject: |
I would ensure that the exhaust is ducted out and over the gunnel or lowest part of the splashwell. Yes on the CO detectors as Bob said.
Another option for the CPAP is to go with 12 VDC battery power. There are several of us that do that in different ways. I personally use an old Respironics machine that has a direct 12vdc plug so I can run it directly from the boat battery via a Cig plug. That is a much more efficient use of 12V power that running it through an inverter. Running a gen set, seems over kill for a single CPAP. Maybe break even for 2 running at the same time. Or running CPAP and a fridge or your 500 watt heater should be good.
Another option is a portable power system like a Jackery
https://www.amazon.com/dp/B083KBKJ8Q?tag=highlightreviews-72025-20
OR
https://www.amazon.com/dp/B082TMBYR6?tag=highlightreviews-72025-20
more expensive but good power for 3+ night of average CPAP use --> moderate pressures for 6-7 hours use per night.
All the best,
SleepyC
trebleplink
Vessel Name: Cscape
Posted: Mon Nov 15, 2021 1:29 pm Post subject: |
Thanks folks - I was also thinking of a riser on the ladder seat, exhausting away from the boat.
I used to have two batteries and deploy 200 watts of solar panels to run various things, but now I have just one 100ah battery and a fixed mount 50 watt solar panel.
I used propane heat in the cold season, but it was impractical to leave it on all night, and it created a lot of humidity - everything was damp with the windows fogged.
The cpap is a System One that runs off of a 12 volt power supply. I suspect much of the energy draw is for the water heater, but it uses 1.1 amps at 120 vac, with a .55 power factor - about 75 true watts. That's about 5 or 6 amps at 12 volts. I don't see my solar powering it especially in cloudy weather. I'll place it on the table behind the helm to keep the intake high up - co2 sinks.
So. I made the jump to the small generator, which was a giant leap in available energy. AND I'm putting together a 120 vac electric heater that can be set to 600, 400, or 200 watts. I also have a switching 12 volt power supply that is good for up to 50 amps charging. ($30 on ebay) https://www.ebay.com/itm/165169753480
This is the quietest generator I've seen, and when lightly loaded, runs 6 hours on .55 gallons. I have a cap adapter that lets it suck fuel from one of my two 10 gallon tanks.
Chris
[/url] |
Posted: Mon Nov 15, 2021 10:29 pm Post subject: |
Chris, You are right about the power draw for teh heater on the CPAP. And you can use the CPAP without the heater turned on (with water in it) or you can use the unit dry, no water in the heater chamber. (That is how I use my PAP on the boat.) If you notice increased dryness, you can use a spray bottle of saline spray for nasal hydration. That will save you about half of your CPAP power draw.
SleepyC
