cleaning horribly dirty window tracks.. help
Jake B
Vessel Name: PLUS 3
Photos: PLUS 3
PostPosted: Tue Jun 12, 2012 1:10 am    Post subject: cleaning horribly dirty window tracks.. help Reply with quote
so I am going to attempt cleaning out the sliding window tracks this weekend on a boat that has been in storage since 98 and has not seen any type of cleaning since who knows when. I read on here about maintaining cleaning and lubing but anyone have any tips for some that are really bad they wont close all the way to lock or really slide open.
I am wanting to get them back to new but don't want to mess them up in the process. wasn't sure if there was a strong cleaner that would break it up or not.
thanks to anyone who has dealt with this in the past.
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Tue Jun 12, 2012 1:46 am    Post subject: Reply with quote
I bought an 89 C-Dory, that was neglected, and the window tracks were extremely dirty, the fabric was falling apart, and the drain hole plastic covers were falling off. I just washed and washed with a regular hose until most of the dirt washed out, and made new aluminum drain covers that I pop riveted over the holes. The windows themselves are not too good anymore, but I don't plan on replacing them -- they are actually "weathering" on the ground over edges, but they work. Wonder what replacing them all would cost??
bshillam
City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
PostPosted: Tue Jun 12, 2012 7:30 am    Post subject: stiff brush Reply with quote
A stiff plastic brush goes a long way. Something you can pick up in any auto parts or hardware store. Once cleaned I have heard liquid rollers works really well.
billtwymank
City/Region: Pinehurst - New Bern, NC
Vessel Name: Lady KC
Photos: Lady KC
PostPosted: Tue Jun 12, 2012 8:19 am    Post subject: Liquid Roller Reply with quote
We use liquid roller for boat trailer pads.......
and use it monthly
and the windows slide very easily.
I always run the hose full pressure in all the tracks
then when they are dry I spray liquid roller on
all front, top, bottom tracks..........
Bill & Karan
Lady KC
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Jun 12, 2012 10:41 am    Post subject: Reply with quote
Another endorsement for Liquid Roller. It works!
PostPosted: Tue Jun 12, 2012 11:10 am    Post subject: Reply with quote
Ours haven't sat for as long as yours, but we scrub with soapy water, flush with water, use some vinegar water (really helps with the salt spray), then let it dry. When dry, spray on Liquid Rollers (a Marykate product).
Jake B
Vessel Name: PLUS 3
Photos: PLUS 3
PostPosted: Tue Jun 12, 2012 1:38 pm    Post subject: Reply with quote
thanks for the replys, and looks like a good scrubbing and liquid rollers in what it needs. thanks again
Standas
City/Region: Poulsbo
C-Dory Year: 2013
Vessel Name: C -Time
Photos: C -Time
PostPosted: Wed Oct 13, 2021 11:16 pm    Post subject: Reply with quote
I went thru and replaced the rubber/mohair channel.it wasn’t to difficult I got the material at steel rubber products.
PostPosted: Thu Oct 14, 2021 1:11 am    Post subject: Reply with quote
SPAM ALERT
Vikka_51 post just above is spam.
PostPosted: Thu Oct 14, 2021 12:37 pm    Post subject: Reply with quote
start with 30 second cleaner from home depot or lowes. It is by far the best mold alge grit pollen cleaner. I use it a lot around the house and on the trucks rv boats and just about anything. It really breaks the bond of all the above and your boat. Works really well in cleaning bugs off rvs and trucks. Makes it a 10 min job.
Doug & Fran
City/Region: Calgary,
State or Province: AB
Vessel Name: Squirt Two
PostPosted: Wed Jul 26, 2023 12:14 am    Post subject: Reply with quote
We have a 2007 25', and the window sliders were almost impossible to move. I'd tried spraying with silicon lube, but hadn't done any cleaning first. Just spent some time with a bucket of water, a screwdriver, toothbrush and the water pick I use for cleaning my teeth. Worked quite well!
I should have closed the windows and hit them with the hose from the outside first, but I'm not that smart.
The combination of rubbing the flat bladed screw driver along the edges up against the glass and then in the 'groove' itself broke up the dirt etc., and gently pouring water into the 'groove' where the glass wasn't sitting and then using the toothbrush did a pretty good job of cleaning. I don't know how much of a difference the water pick made, but it fit nicely into the 'groove' and was handy for directing flow to clean out the drains etc.
Does anyone know of an attachment that I could screw onto the standard garden hose, that would have maybe a 1/4" diameter tubing outlet? It would allow more control over where the water was going. Thanks, Doug
Doug & Fran
Squirt Two
PostPosted: Wed Jul 26, 2023 7:20 pm    Post subject: Reply with quote
Go to the plumbing dept of your Home Depot. You will find a standard garden hose female fitting, and various reducers down to flare at 1/4, 3/16 or even 1/8" copper tubing. Problem may be how well to control the water pressure. You can put a standard RV pressure reducer in the series between the end of house male and female you have adapted to copper tubing. Be sure all of the threads match.
Donald Tyson
City/Region: Easton
Photos: Thistle
PostPosted: Wed Jul 26, 2023 9:11 pm    Post subject: Reply with quote
[attachment that I could screw onto the standard garden hose, that would have maybe a 1/4" diameter tubing outlet? It would allow more control over where the water was going. Thanks, Doug[/quote]
Like Thataway mentioned it needs to be "hose thread". They're available in most Ag or Farm stores such as Fleet and Tractor Supply. From experience I find that a ball valve and the 3/4 x 1/8 Hose barb is what you're after. If I can figure out how to post photos I'll show these parts to you.
Page generation time: 0.0303s (PHP: 76% - SQL: 24%) - SQL queries: 26 - GZIP disabled - Debug on
