Mystery Switch - any thoughts?
jep27
City/Region: New Haven
State or Province: VT
Vessel Name: Lunasa
Photos: Lunasa
PostPosted: Tue Sep 21, 2021 2:07 pm    Post subject: Mystery Switch - any thoughts? Reply with quote
Hey-
Earlier this summer, I stumbled into a switch on the aft port side of our cabin exterior wall. (Cape Cruiser 26'/2007).
Through trial/error, I can find nothing that this switch seems to activate or turn-off.. and I have no idea what the initial function may have been. Given that the wiring is between the walls, etc.. I can't really reverse engineer it.. but may well put this to good use.. if I knew what it was going to.
Any thoughts or theories?
Thanks-- Jeff
jep27
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Tue Sep 21, 2021 2:18 pm    Post subject: Reply with quote
Any sign of cockpit or exterior/docking light?
Stephan
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Tue Sep 21, 2021 3:19 pm    Post subject: Reply with quote
Whether or not the lights were ever installed, that switch (there might be on on the starboard side as well) is probably for a string of lights under the cockpit gunnels. It is designed to allow for turning on low lighting of the cockpit sole, especially when boarding the boat at night. You can reach the switch from the dock. I actually rarely used mine, but it was kind of cool. If you search the site you will find at least one other thread on this subject.
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
jep27
Vessel Name: Lunasa
Photos: Lunasa
PostPosted: Tue Sep 21, 2021 3:44 pm    Post subject: Reply with quote
Thanks.. and I'll review.
Yes, we have string lights under the cockpit gunnels.. and they seem to operate directly from the 'Deck Lights' main switch on the dashboard. Perhaps the localized switch option was by-passed by the previous owner.
Thanks.. and not sure quite what to do about any forward use.. since I'm not sure the discreet switch is that big a deal in our case.
Appreciate your inputs and, again, I'll try to find that other thread.
Jeff
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Tue Sep 21, 2021 4:45 pm    Post subject: Reply with quote
I have that switch on my 26. It allows you to turn on the LED lights, under the aft cockpit. The master light switch for these lights, is on the dash.
Steve Baum
Homeport of Portsmouth, VA
KevinMc
City/Region: Venice
Vessel Name: Sea~Dory~Able
PostPosted: Mon Dec 18, 2023 8:54 pm    Post subject: 2006 venture 23. Now "Sea~Dory~Able" Reply with quote
Ah.So you can board the boat at night from either side and access the light switch without leaving the lights on all the time! Smart thinking by the designer.
Page generation time: 0.0589s (PHP: 33% - SQL: 67%) - SQL queries: 19 - GZIP disabled - Debug on
