The Other Nathan
Posted: Fri Aug 20, 2021 1:23 am Post subject: First Time Power Boater - needing advice on a 22 |
Greetings,
As a first time buyer, I am looking for advice for what to look for and consider when purchasing a used C-dory.
My name is Nathan and I have been a dinghy sailer most of my life. For a stint I owned a 20’ trailer sailer. I haven’t owned a power boat but for the past few years my wife and I have had a membership in a boat club that gives us access to runabouts, pontoons and fishing boats so I am familiar with the operation/handling of power craft. That said, I am a novice when it comes to the maintenance and/or systems that aren’t sail rigging related.
I have been lurking on the site for awhile and recently was in Superior, WI where by chance I saw my first C-Dory in person. It was on a trailer in the Ace Hardware lot. And seeing in person what I had been ogling at online for months flipped a switch in me. Fast forward a week, and that same boat was just posted to Craigslist. https://minneapolis.craigslist.org/hnp/boa/d/duluth-1996-dory-22/7368102869.html
The post is for a ‘96 22. The engine hours seem low (but again being new to this I am not sure how low is good or if hrs are easily forged). The gel coat is stated to be faded but not sure if that is an easy fix or not.
Anything about the mid-90s boats to consider? I am assuming the the stove may need servicing and soft spots are likely in the deck.
What is the serviceable life of these boats?
Does the price seem fair? It seems to be on the lighter side for equipment/upgrades. But it does look clean.
Any concerns with it not having electric trim tabs?
Also, the posting makes it seem that the seller is not familiar with the bot or hasn’t operated it. Any thoughts on that?
I am excited that this boat seems like a good fit, but want to make sure I am going in eyes wide open before pying to have it surveyed.
Hopeful to join the ‘family.’ Thanks for your thoughtful consideration,
Nathan
JonO
C-Dory Year: 2017
Vessel Name: Tremolo
Photos: JonO
Posted: Fri Aug 20, 2021 7:55 am Post subject: Been there, done that |
Hi Nathan,
I've just gone through this process.... mine was a long-distance deal which added some complexity and cost. These boats tend to sell fast, so you may want to move fast. If you're serious about it, try to lock up the boat with a down payment while you're doing due diligence. Getting a marine survey by a certified, qualified surveyor should answer many of your questions, identify flaws and give you some peace of mind. As for price, search the FSBO forum and archive and you'll see the range. If the seller was active in C-Brats, it makes obvious sense to check out photo galleries and posts.
There are many threads on how to buy a boat - you may get better results searching Google outside of the website than you do using the on-site search tool.
I noticed the sign in the background of one of the images - Northwest Outlet in Superior was a C-Dory dealer back in the day. Are they acting as an agent for the seller? If so, that might buy you additional peace of mind, as dealers use trust accounts to handle the transaction.
Hope this helps. Good luck! |
PaulNBriannaLynn
Joined: 26 Oct 2012 Posts: 757 City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
Posted: Fri Aug 20, 2021 9:36 am Post subject: |
That looks like a nice one at a good price to me. The mid 90s boats were really well built, they hadn't ramped up production to the mid 2000 levels, so the attention to detail was really good in those years. Those honda 40s were very robust and reliable. They had carburetors with small jets that have a tendency to get clogged up if let sit for a long time with fuel in them. Most c-dory owners with this engine set up drain the float bowls of fuel after use if theyre going to sit for a while, and never have any trouble.
You mentioned soft spots are likely in the deck? Are you sure about that? That is a more serious issue.... totally repairable, but expensive and/or time consuming depending on your ability to repair yourself. Being that the boat is in Michigan, with a lot of freeze/thaw cycles, I would be cautious about the floor and any potential water intrusion into the balsa core. I wouldn't automatically discount the boat for that, but would investigate before purchase any potential water in the floor.
The chalky appearance of the gel coat is typical with any used boat this age. You can polish that up with a number of products. I like 3M cleaning wax with polish. _________________ 2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016 |
clayhubler
Joined: 03 Aug 2019 Posts: 374 City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
Posted: Fri Aug 20, 2021 10:28 am Post subject: Re: First Time Power Boater - needing advice on a 22 |
The Other Nathan wrote: | soft spots are likely in the deck.
If there are any soft spots in the deck you want to keep looking. These boats are very strong and well built, so if the core has deteriorated to the point that the deck is actually soft or spongy, there is a BIG problem.
Check any areas that have screws penetrating into the floor very carefully. Gas tank hold downs and cabinets are the most common offenders. The transom also.
The price seems a little high to me. It needs new electronics, has no windlass, no trim tabs (which you will want), no heater, and original motors. Only one bilge pump. It does have a custom fuel tank ( I think). The condition of the trailer is hard to judge from the photos. I would still be interested in the boat as long as there are no core issues, but would try to get the seller to come down on price.
And just because the motors are low hours doesn't mean there wont be any problems. Engines that sit have a tendency to suffer from carb problems. Or they may be fine, also. _________________ Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser |
Joined: 27 Oct 2012 Posts: 3581 City/Region: SW Michigan
Posted: Fri Aug 20, 2021 11:09 am Post subject: |
Dual axle trailer would also be nice.
If I didn't already have one, I'd be all over this one. Lots of opportunity to make it the way you want it. |
JonO
C-Dory Year: 2017
Photos: JonO
Posted: Fri Aug 20, 2021 11:13 am Post subject: |
If you can, climb in the boat... not only for a detailed inespection. Check the ceiling height. (I have the taller ceiling on my 22 and as someone over 6 feet tall consider that a necessity.)
A couple more tips:
Ask for service records.
A compression test and a sea trial will tell you a lot about the condition of the motors. |
oldguy83
Posted: Fri Aug 20, 2021 12:13 pm Post subject: |
I drive by this boat every day, stopped and looked at it thru the fence. No for sale sign. The boat was not their last couple days. Be glad to look at it for you if it's still around. I OWNED ONE FOR 10 YEARS. Jack. |
The Other Nathan
Posted: Fri Aug 20, 2021 3:49 pm Post subject: |
Thanks all for the tips and comments.
To clarify, I don’t know if it has a soft deck or not, but if it did that would be a concern to note.
It seems that the motors (more due to age than hours) may need some work depending on how they have been maintained /recently used but are a reliable motor when maintained properly.
The lack of winch, modern electronics, trim tabs and bimini/canvas would be additional/initial expenses I’d want to consider to increase the comfort and ease of operation.
The trailer is okay but could be upgraded to double axle and/or to have brakes.
There is a lot I like about this boat and it looks very clean but it also seems to be a blank slate that may take more money than I can currently allocate to customize to the level that most owners seem to enjoy.
I need to make sure the wife is fully on-board (which may take more work than I initially hoped) to prevent this boat from becoming my live-aboard.
@Jack thanks for the generous offer to check it out. Not quite ready to pull the trigger on this yet- I need to do some more research.
-Nathan |
The Other Nathan
@moderators, let me know if I out this in the wrong forum section. |
Joined: 02 Nov 2003 Posts: 21472 City/Region: Pensacola
Posted: Fri Aug 20, 2021 10:05 pm Post subject: |
From the photos, the boat seems to be in decent shape for the year. The gel coat should compound and polish out. I would look carefully around the transom drain.
If the boat was stored under a cover or inside during winter, this would be a plus. No trim tabs because of the twin 40's plus a large piece of Starboard to hold twin transducers for depth sounder.
The fuel tank is definitely after market--and probably holds a bit more than the stock boat.
A few years back, I might say the boat was over priced--but not in today's market. I would consider it a blank slate with the older Eagle sounder and GPS/plotter. If the boat has been around, and the seller is not familiar with the boat--make an offer lower than asking price....after you take the valuable precautions listed by posters above. _________________ Bob Austin
Posted: Fri Aug 20, 2021 11:43 pm Post subject: |
Yes, That tank sure looks aftermarket. Nice (and big) but it appears to be screwed into the cockpit sole (ouch -- so look there). The lack of trim tabs could be easily remedied since it has twins Permatrims on both would accomplish much of the advantage of trim tabs, at one third (or less), the cost and effort.
For me the low hours would be more of a concern than an advantage. NON-USE is worse than over use but the caveat there is how it was stored. Those will be carbureted engines, IF they were stored with gas in the carbs, especially untreated gas (and more especially if it has ethanol content in it) the carbs will need to be cleaned and rebuilt with new jets. If the carb bowls were drained dry when it was put away, them might be OK.
Looks to be a clean slate, and for that price, the upgrades will put it into a modern, and still economical state.
SleepyC
garyf
C-Dory Year: 1991
Vessel Name: C-Story
Photos: C-Story
Posted: Sat Aug 21, 2021 1:33 am Post subject: Re: First Time Power Boater - needing advice on a 22 |
The Other Nathan wrote: | I am assuming the the stove may need servicing |
Looks like the others covered most of the points fairly well, but I didn't see anyone mention the stove. That's an alcohol stove, I have the same one on my '91.
It's a super simple design, so not a whole lot to service really... just maybe some cleanup and maybe replace the fuel cannisters if it's been used a lot, but probably not even that. Not a lot to go wrong, really.
One drawback to alcohol stoves compared to other types of stoves is they don't have a super high heat output, so cooking might be a little slower than other fuels. The alcohol is safe though and not smelly like diesel (another option) or explosive like propane/butane. So far, it fits the bill OK for me, but I haven't used it heavily. Some people have portable grills that they can use out in the cockpit, so you have options. _________________ Gary Frerking
C-Story
'91 22 ft Cruiser
'08 Yamaha 90
KC3PO |
