The BigO
Joined: 12 Aug 2021 Posts: 1 City/Region: Lake Superior, south shore
Vessel Name: C Munk
Posted: Thu Aug 12, 2021 9:10 am Post subject: New member and control panel ?? |
Hi All, third year owning our 22’ Cruiser on the south shore of Lake Superior. Great boat for Gitchee Gumee! Recently my control panel, all the rocker switches from horn to bile pump decided to quit working. I checked the two small fuses behind the panel and both were good. Rumors of some master fuse somewhere but it’s eluding me. Any clues? _________________ On the shores of Gitchee Gumee |
tsturm
Joined: 01 Nov 2003 Posts: 1164 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Thu Aug 12, 2021 10:19 am Post subject: Re: New member and control panel ?? |
The BigO wrote: | Hi All, third year owning our 22’ Cruiser on the south shore of Lake Superior. Great boat for Gitchee Gumee! Recently my control panel, all the rocker switches from horn to bile pump decided to quit working. I checked the two small fuses behind the panel and both were good. Rumors of some master fuse somewhere but it’s eluding me. Any clues? |
Start at battery's and work to panel  |
Joined: 02 Nov 2003 Posts: 21354 City/Region: Pensacola
Posted: Thu Aug 12, 2021 10:49 am Post subject: |
There us usually a 30 to 40 amp circuit breaker on the wire from the battery switch [(1,2, All, Off) or similar switch and a positive bus near by,] going to the the main console. They may have tripped.
There also may be corrosion on both positive and negative leads. This is a good time to take the wires off terminals, clean and put back on after cleaning. I usually spray with a corrosion blocking compound after this to decrease any corrosion. Often a negative lead problem will be missed. _________________ Bob Austin
