How to wire a VSR to allow disabling for boat storage
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Wed Jul 14, 2021 2:56 pm    Post subject: How to wire a VSR to allow disabling for boat storage Reply with quote
I'm about to install a new BEP 716-Sq-140A-Dvsr cluster of switches and VSR. The VSR has a special loop of wire that can be cut (see image below) so that one can install a toggle switch which disables the VSR totally. I want to do this so that when the boat is in storage, and on my dual output charger, each battery will be charged independently according to the charger's absorption/float profile. To have the batteries independent, I need to have the VSR disabled. This on/off switch also provides the advantage of no amperage draw by the VSR when the boat is stored.
Looking at the diagram it seems to me I could connect the cut red wire directly to the engine side of the start battery switch instead of going thru a stand alone toggle switch. If I did that, it seems to me that the VSR would be enabled any time I have the start battery switch in the "on" position, and disabled if the start battery switch were in the "off" position. Since I must have the start battery switch on when I run the engine, and I always turn it off when the engine isn't running (except at anchor), this would give me what I want painlessly in the sense that the VSR would operate whenever the start battery switch was on, and not operate with the start battery switch off.
Can anyone see why this wouldn't work, or if there is some downside I've missed?
P.S. Another way to look at this setup is: I want the VSR to combine when the source of the charging current is the alternator, and to not combine if the source is my charger.
Sandy McKean
Purchased Tosca in 2014
PostPosted: Fri Jul 16, 2021 11:47 am    Post subject: Reply with quote
The manual states:
Optional Ignition Control/Storage Mode (red wire):
Cut end of the red looped wire ( end closest to red dotted “Start Batt Positive +” stud) where it joins the PCB/potting, connect the remain- ing tail to the ignition terminal on the engine ignition/start switch. With this feature selected the DVSR will only operate when the ignition key is in the “ON” position (i.e. engine running). With the ignition switch “OFF”, current draw of the DVSR will be zero Amps.
If I understand the way the cluster works, you should be good to go. The manual calls for either the ignition switch, or as you noted a toggle switch.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Fri Jul 16, 2021 1:39 pm    Post subject: Reply with quote
Well, my plan is to do something a bit different that either of the manufacturer options you mention. I don't plan to use either a toggle switch or wire the VSR to the ignition switch. That's why I am a bit unsure about my plan. It seems to me that wiring that red wire to the engine side of the starter battery switch accomplishes the same thing (which may be what you are implying), but perhaps there are other consequences that flow from doing it in this "non recommended" way that I am blind to.
Well, I'm just going to do it. I feel pretty confident that my plan will work. Getting operating power to the VSR via the engine side of the start battery switch allows me to keep the house and start batteries separate while charging in boat storage, and not have to worry about yet another switch. (The ignition option saves me that worry too, but I don't want to have to run a wire from the stern lazerette to the helm.)
Ferg
City/Region: Oak Island
Vessel Name: Here & Now
Photos: Here & Now
PostPosted: Fri Jul 16, 2021 2:53 pm    Post subject: Reply with quote
If you wire it to the engine side of the start battery, and the start battery has high enough residual voltage (from the last charge) to initiate paralleling, you’ll be using both banks to start the engine.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Fri Jul 16, 2021 3:35 pm    Post subject: Reply with quote
Ferg,
I think you are misunderstanding what I'm trying to do. I assume you understand that when you say "wire it to the engine side of the start battery" that is not what I'm doing. What I'm talking about correctly said is "wire it to the engine side of the start battery switch".
My scheme has nothing to do with wiring the large, high amp cables that come from the batteries to the switches, or from the switches to the distribution blocks or devices. I am only talking about how to connect the VSR to a source to supply the VSR's operating power. That operating power is supplied in the factory unit via that little red wire in the diagram above. I presume that in the factory version that red wire is connected to the posts coming from either or both the batteries. When I cut that little red wire, the VCR simply does not operate at all unless I supply a positive 12v connection. It is that operating power connection that I am talking about connecting to the engine side of the start battery switch.
The "problem" you mention would be true of any VSR installation.
Ferg
Photos: Here & Now
PostPosted: Fri Jul 16, 2021 4:09 pm    Post subject: Reply with quote
I did understand that’s what you meant Sandy. As you know, I did the switch, which completely isolates the VSR, and takes out any possibility of paralleling when starting the engine.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Tue Jul 20, 2021 5:01 pm    Post subject: Reply with quote
Just to close the loop on this thread.......
I ended up wiring the new 716 switch/VSR cluster as per the manufacturer's recommendations. Turns out there appears to be a great deal of misunderstanding regarding how a VSRs (ACRs) work, and especially how multi-output chargers work. I spent a lot of time researching and learned a lot. Bottom line was that a multi-output charger provides no benefit over a single output charger with a VSR. Once I understood that, the whole reason for why I wanted to do a modified install disappeared.
At some point I will likely post a new thread on C-Brats spelling out what I learned.....one of the biggest items is the common misconception (I certainly had it) that multi-output chargers use independent charge profiles for each output. Almost all the chargers out there do not do this....although their marketing text is designed to make you think so.
Page generation time: 0.0475s (PHP: 60% - SQL: 40%) - SQL queries: 20 - GZIP disabled - Debug on
