Motor Well Drain
Rhodesmj
City/Region: Hudson
Vessel Name: Creek Runner
PostPosted: Sat Jul 10, 2021 11:14 am    Post subject: Motor Well Drain Reply with quote
I have a 2006 25 ft CDory Cruiser. The motor well has a single drain thru the transom wall, located at least an inch above the floor of the motor well. It doesnt drain the well effectively and leaves standing water that get slimey.
Any suggestions?
MarcRhodes
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sat Jul 10, 2021 11:47 am    Post subject: Reply with quote
The answer is to install one in the correct location.
PostPosted: Sat Jul 10, 2021 12:05 pm    Post subject: Reply with quote
Haven't noticed a problem with my splashwell drain except sometimes when the boat has a list due to loading. The drain is to one side.
The sump drain on the other hand was too high. Left an inch or so of water in the sump. I added a new drain lower down that properly drains the sump.
PostPosted: Sat Jul 10, 2021 12:45 pm    Post subject: Reply with quote
On Journey On a 2005 C-Dory, the motor well has 2 drains, one at each end of the motor well. They are installed ~1/2 above the bottom of the well, so that the well is never drained completely.
The factory installed those drains as low as they could. There's a brass ring swaged through the hole and I think that the swaging tool wouldn't allow the drains to be any lower.
So , one can live with it or one can correct the problem. Instead of lowering the holes I raised the floor of the motor well. I made a tapered redwood insert to fit in the motor well with the top just at the lower hole edge. Slathered 5200 on the underside and the edges and fastened it down with #10 sheet metal screws. Finally after the 5200 dried, painted all over with epoxy paint.
It's worked well for the last decade. No water in the well and it's still deep enough to do what motor wells do.
alainP
City/Region: TUCSON
C-Dory Year: 2011
Vessel Name: deja la
PostPosted: Sat Jul 10, 2021 1:13 pm    Post subject: Reply with quote
I have the same situation, half inch or so.
Keeping a big sponge handy makes quick work of what can'r drain
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
I solve the problem with a $1.29 sponge. Wink
Sandy McKean
Purchased Tosca in 2014
PostPosted: Sat Jul 10, 2021 5:11 pm    Post subject: Reply with quote
Sandy, I solved it the same way, 'cept I got my sponge at the "Dollar Store" Wink Cool
T.R. Bauer
PostPosted: Sat Jul 10, 2021 5:51 pm    Post subject: Reply with quote
Pretty sure he would have figured that one out without posting Smile
PostPosted: Sat Jul 10, 2021 6:29 pm    Post subject: Reply with quote
Dollar store water toy. Suck out what you can. Sponge out the remainder.
PostPosted: Sat Jul 10, 2021 6:32 pm    Post subject: Reply with quote
I have one or two of those cheap sponges, but I just got tired of mopping it out after every trip or washdown. Now it empties itself through the magic of gravity.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sat Jul 10, 2021 6:39 pm    Post subject: Re: Motor Well Drain Reply with quote
Any suggestions?
I solved my single splashwell drain with a hole saw & a little fiberglass & resin Thumbs Up
One on either side of the splashwell, at the bottom so all the water drains out Wink
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Sun Jul 11, 2021 10:24 am    Post subject: Reply with quote
I also had that situation on my old 25. I would just have to wipe it with a towel every time
<><><> Jason <><><>
Page generation time: 0.0566s (PHP: 49% - SQL: 51%) - SQL queries: 25 - GZIP disabled - Debug on
