Joined: 27 Oct 2012 Posts: 3581 City/Region: SW Michigan
Posted: Tue Dec 15, 2020 6:23 pm Post subject: |
colbysmith wrote: | I leave the batteries in my boat. However I also leave the shore power and charger on the whole time as well. |
Mine also stay on the boat over winter. They are charged before storage and recharged immediately when the boat is recovered from storage. While stored all loads are disconnected. |
Posted: Tue Dec 15, 2020 10:53 pm Post subject: |
ssobol wrote: | colbysmith wrote: | I leave the batteries in my boat. However I also leave the shore power and charger on the whole time as well. |
Mine stay on the boat and are hooked up continueally to a "BatteryMinder" which has some of the same properties as a batterytender, but also, it has the capability of doing desulfation (sp).
SleepyC  _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
BBlalock
Joined: 31 Jan 2017 Posts: 159 City/Region: Ocean/ICW
C-Dory Year: 2013
Vessel Name: Finale
Posted: Mon Dec 28, 2020 12:56 pm Post subject: |
Martin,
I am about 45 miles down the road from you. On Bogue Sound.
When I winterize I:
1. Run the pump to push the water out through all the outlets
2. Put 1 gal. of pink in the tank
3. Run pink to all the outlets
4. I then syphon the water heater dry. Garden hose attached to the valve.
5. Run pink to the water heater tank.
6. I leave all outlets in the open position.
So far so good except with my yesterday issue with losing power to my right side switch panel. _________________ Benton Blalock
'13 25' Cruiser "Finale"
'12 22' Fiesta pontoon(sold) |
tparrent
C-Dory Year: 2017
Vessel Name: Tomfoolery
Photos: tparrent (TBD)
Posted: Mon Dec 28, 2020 5:52 pm Post subject: |
After a full days work (I’m kinda “special” when it comes to maintenance), the winterize rion is done! Almost.
Forgot to do the wash down spigot. I’ll do that tomorrow. Holding tank macerator is inoperable so didnt do that. Not sure if I’m supposed to hit the bilge pumps.
I did successfully bypass the water heater. I’ll have to tell that story when I have a keyboard in front of me. Quite a tale.
Now I just have to clean up the mess I made while I was neatening up! _________________ Tom Parrent
2017 TomCat "Tomfoolery"
New Bern NC |
BBlalock
C-Dory Year: 2013
Vessel Name: Finale
Posted: Fri Jan 22, 2021 1:56 pm Post subject: |
BTW in my procedure to winterize I said 1 gal of pink. It'll take 2 or 3 to properly pink all but the cockpit washdown hot line. I will let the siphoning pull that water out while letting it be the vent for the heater siphon. |
