23 Venture Story Link!
Goto page 1, 2, 3, 4, 5  Next
markwright
C-Dory Factory Representative
City/Region: Bellingham/NW
Photos: C-Dory Factory
PostPosted: Wed Dec 09, 2020 6:24 pm    Post subject: 23 Venture Story Link! Reply with quote
Thanks to a tip from a good friend, I figured a way to include just the pictures of the 23 Venture Alone!!
Enjoy the Story!
http://www.c-brats.com/modules.php?set_albumName=23-venture-Story&op=modload&name=gallery&file=index&include=view_album.php
Mark Wright
C Dory Facebook
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Wed Dec 09, 2020 7:23 pm    Post subject: Reply with quote
Mark,
The link to the story does not work.
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Wed Dec 09, 2020 8:46 pm    Post subject: Reply with quote
Good evening, Mark. Thanks for the story!
I think I got your links and albums all in line with what you were after. I renamed the sub album containing the story pictures as 23 Venture Story and changed the link in your original post on the story (this one) to go to the right spot.
If that all seems to be working for you I can delete this thread so the discussion - along with the Oohs & Ahs - will all be in one spot.
PostPosted: Wed Dec 09, 2020 9:32 pm    Post subject: Reply with quote
Attention!
The album or photo that you were attempting to view either does not exist, or requires user privileges that you do not possess. Log in and try again.
PostPosted: Wed Dec 09, 2020 11:18 pm    Post subject: Reply with quote
Hey Tyboo Mike, I just tried your link, which took me back to the original story thread, and then linked on Mark's photo link, and it smoothly took me to the Venture story. So I think you did a great job in fixing it! I'm all for deleting this thread now, if the OP is happy with what you did. Colby
PostPosted: Wed Dec 09, 2020 11:31 pm    Post subject: Reply with quote
IGNORE ME, I USED THE ORIGINAL LINK, NOT THE SHORT LINK. iT WORKED LIKE COLBY SAID.
NEED TO TAKE OUT MARKS ORIGINAL LONG LINK.
HARVEY
SLEEPYC Moon
markwright
PostPosted: Thu Dec 10, 2020 5:45 pm    Post subject: Thanks for you Help! Brats helping a Big Brat! Reply with quote
Thanks a lot guys. I am still a novice with the C-Brat photo platform. Clearly it dupes me! I will keep adding pictures to the 23 Venture Story Link as I can!
Appreciate all the help!
markwright
PostPosted: Thu Dec 10, 2020 6:30 pm    Post subject: Update Dec. 10th Reply with quote
Hello Brats! Here is an update on the 23 Venture! Today the aft are in the hull is getting prepared to 'Marry Up" the Hull and the deck Monday!
Hoping this link gets you to the right pictures!
PostPosted: Fri Dec 11, 2020 1:47 am    Post subject: Reply with quote
Nice, Mark, It is working. Looks great.
Thanks to Tyboo too.
markwright
PostPosted: Mon Dec 14, 2020 7:00 pm    Post subject: Monday Dec. 14th "Married Up" Reply with quote
Here is the boat as it is assembled into one unit prior to heading over to the assembly shop to get all the small parts glassed in!
markwright
PostPosted: Wed Dec 16, 2020 3:41 pm    Post subject: Update on the Story December 16 Reply with quote
Here are some new Pictures of the boat out of the Mold!!
Knipet
City/Region: Orcas Island
Vessel Name: Pan-A-C'ya
Photos: Pan-A-C'ya
PostPosted: Wed Dec 16, 2020 5:18 pm    Post subject: Reply with quote
Hey Mark,
Is that by chance the Venture 23 that is being build for me? Marty at Master Marine just sent me some photos of my build. Is this one and the same?
- Steve Pettyjohn
Steve & Joanie
2021 Venture 23 "Pan-A-C'ya
Formerly C-Sharp - 2006 22 Cruiser
PostPosted: Wed Dec 16, 2020 9:56 pm    Post subject: Reply with quote
Mark,
Thank you for annotating the photos. Boat looks great!
Are you doing the lamination with the mold on its side?
Are you using resin infusion technology?
Are you using vacuum bagging when the core and inner layer is applied?
For those who do not know, C Dory is one of the few companies who keep the hull and deck in the molds when the hull to deck joint is glassed together. This makes the strongest hull and hull to deck joint. Other builders may use "glue" adhesives, pop rivets or an "H" section of aluminum to attach the hull to the deck--and it is done out of the molds.
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Thu Dec 17, 2020 12:40 am    Post subject: Reply with quote
I did not know this Bob. Credit goes to NMI because this adds labor costs to the build. With the glass strengthening this joint it would also reduce flexing which causes leaks. Makes me appreciate my C-Dory even more.
Gary F
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Thu Dec 17, 2020 10:24 am    Post subject: Reply with quote
Mark thanks for the story the picture where the rear deck is being glassed in looks like that would be an air tight compartment is there any structure supports under that? Is the 22 done the same way?
Jody Kidd
KE7WNG
Northern, Utah
Page 1 of 5
Page generation time: 0.0467s (PHP: 64% - SQL: 36%) - SQL queries: 28 - GZIP disabled - Debug on
