help me diagnos a fuel leak!?
Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
PostPosted: Sun Aug 23, 2020 11:29 pm    Post subject: help me diagnos a fuel leak!? Reply with quote
I have a suzuki 4hp kicker with internal tank. It runs pretty well, but when I'm out trolling for about 30mins or more, it starts to (a) act like it's not getting enough gas and partially or fully stall and (b) leak gas. I'm usually too focused on fishing to mess with it, so I shut it down for awhile. After is cools, it seems to work again, until it gets fully warm again.
Any ideas what's wrong?
Current boats:
1988 16' Angler - "E-fishn-C"
Also:
SnowTexan
City/Region: Carlton
Vessel Name: Miss Maria
Photos: Miss Maria
PostPosted: Mon Aug 24, 2020 12:17 am    Post subject: Reply with quote
Howdy Zepp,
Where is the fuel leaking? Does the motor fire up easily after sitting for a night? Could be a lot of things but before tearing into anything major I’d start with an inspection of the cheapest and most accessible parts that can stall a motor or leak: gas cap, fuel lines, filters and connections. If you are blowing fuel from the carb, then time to clean that puppy out. If still no luck, I yield the floor to my mechanical betters. They are many and wise in this forum.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Aug 24, 2020 6:28 am    Post subject: Reply with quote
James,
Sounds like the carburetor is the problem. I was testing a 2.5 Yamaha last week and it did the very same thing.
To make repairs, I removed the carburetor, disassembled it completely, placed in in an ultrasonic cleaning tank, flushed it with water, blew it dry with air, reassembled and problem was solved.
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Mon Aug 24, 2020 11:11 am    Post subject: Reply with quote
I agree with Steve, the most likely place is a stuck float valve--and a good cleaning of the carb will take care of that. When you have the cowl off you can inspect the fuel Ines and filter under the cowl.
Do it now--not later
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Tue Aug 25, 2020 12:53 am    Post subject: Reply with quote
thanks guys!
Yeah, the float seems to make sense. I figure when it warms up something goes wrong, it floods too much gas, the carb sputters and the excess is leaking out.
Will tear into it soon!
Page generation time: 0.0331s (PHP: 59% - SQL: 41%) - SQL queries: 18 - GZIP disabled - Debug on
