smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Mon May 18, 2020 3:39 pm Post subject: Elbows, tees, and such connectors |
I'm making modifications to my fresh water system. I will be installing several of these fittings. The ones currently on the boat seem to be made of some sort of black plastic (PVC?). I have found some similar on Amazon that say they are made from "high strength PPSU (polyphenylsulfone)" (sounds brittle to me). I've read that one should use fittings made of nylon. I see that such fittings can be purchased from Defender.
Anyone know the pros and cons of these or other options. Bottom line.....what should I use? _________________ Sandy McKean
Purchased Tosca in 2014
Re-powered to Yammi 200 in 2015 |
Joined: 02 Nov 2003 Posts: 21380 City/Region: Pensacola
Posted: Mon May 18, 2020 3:47 pm Post subject: |
I have used mostly nylon fittings, but on occasion have used PVC. No reason not to use the (polyphenylsulfone)"--they are probably more chemical resistant...
Any of them should work as long as the size and thread pitch is proper. _________________ Bob Austin
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Mon May 18, 2020 4:58 pm Post subject: |
Thanks Bob.....I'll go with the PVC. I can buy a convenient assortment kit from Amazon. BTW, I should have been more specific....I just need those fittings with "shark bite" at all ends. No threads required.
P.S. Here's a tidbit that will not likely surprise anyone. While doing research on this topic, I found nylon fittings at both West Marine and Defender. A tee at WM = $3.99; same fitting at Defender = $0.79 . |
nmitch2859
Joined: 28 Apr 2013 Posts: 71 City/Region: virginiabeach
Vessel Name: Delfin
Photos: Delfin
Posted: Sun Jul 19, 2020 1:26 pm Post subject: |
Hi All, I did add a shore waterhose adapter to my water system. I can now use city water. I do live on my 25 and I got tired of having to fill the water tank. I did replace the : Y : fittings in the water system.I could not find them anywhere. I found them on the web. Be carefulel with the original hose. It may be brittle. I did use a marine brand water inlet fitting. My waterpump does have a check valve so The water does not go to the water tank. I have city water pressure. Works great for the shore and the sink.  _________________ Neal J |
