insulation
Nancy and Bud
City/Region: Nashville
State or Province: IL
Vessel Name: Emma Mae
Photos: Emma Mae
PostPosted: Sat Apr 11, 2020 4:42 pm    Post subject: insulation Reply with quote
We are insulating the sides of the v berth with foam and wood strips. We haven't decided yet what to do with the ceiling. Any suggestions?
"C-dory's are the 13th step in a 12 step program for sailors."Marc Grove, Wefings Marine
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sat Apr 11, 2020 6:40 pm    Post subject: Reply with quote
Tinker Toy,
Here is one solution...
This is ceiling tile material, with thin wood trim, to improve appearance.
http://www.c-brats.com/modules.php?full=1&set_albumName=Cape-Cruiser-26-Projects&id=Fan_Aft_Cabin&op=modload&name=gallery&file=index&include=view_photo.php
Steve Baum
Homeport of Portsmouth, VA
Peter & Judy
City/Region: Olds
State or Province: AB
Vessel Name: Mistaya
Photos: Mistaya
PostPosted: Sat Apr 11, 2020 7:16 pm    Post subject: Reply with quote
Tinker Toy,
One of this years projects is to insulate the roof and v-berth on my 22. I haven't decided on a material yet. Your roof looks great. Tell me more about the material and application.
Thank you
Peter & Judy Haase
Buffalo Horn Ranch
HMCB Mistaya
PostPosted: Sun Apr 12, 2020 1:17 pm    Post subject: Re: insulation Reply with quote
I'd like to hear more details on what you are doing.
Nancy and Bud
Photos: Emma Mae
PostPosted: Sun Apr 12, 2020 9:09 pm    Post subject: Reply with quote
I have closed cell foam that I will attach to the side walls. I have cut and planed them to .20" so they are flexible enough to bend to the curves of the hull. I will place vertical pieces every 2 feet, to these I will screw 1 1/2 wide pieces parallel to the vberth. The wood is cherry and has one coat of boiled linseed oil brushed on.
Will post photos while in progress.
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Mon Apr 27, 2020 4:10 pm    Post subject: Reply with quote
I used flex Form Marine Carpet, was really easy to install and worked great!
See link:
http://www.c-brats.com/modules.php?set_albumName=album1789&op=modload&name=gallery&file=index&include=view_album.php
Boatless for now but looking
Peter & Judy
City/Region: Olds
Photos: Mistaya
PostPosted: Tue Apr 28, 2020 12:38 pm    Post subject: Reply with quote
Thanks for the link. It look really good and I will look into it.
I also looked at your heater album and your system for fresh air return from the v-berth looks interesting. I am just getting ready to install a Wabaso heater and was trying to work out a system of getting more air circulation into the v-berth area by adding a heating duct under there. Our issue is not so much that it is too cold while sleeping, but that the moisture builds up under there and the bedding become damp. I am wondering how well this system works for you.
breausaw
Photos: Triple J
PostPosted: Tue Apr 28, 2020 3:35 pm    Post subject: Reply with quote
We virtually had no moisture accumulation in the v-birth other than a little underneath the memory foam mattresses; was going to put some of that Marine bedding mess underneath the mattresses but never got around to it.
The Wallace recommended an inside & outside air return. My idea with putting the inside air return all the way forward what's to draw air from the cabin up into the V birth, and it worked well enough.
The Flex Form was easy to install because it's stretched in both directions you just need to use the highest number spray adhesive you can find, spray booth Services wait for about 30 seconds and then just put it in place and press. I purchased through an upholstery shop locally not sure where he acquired it.
If I were able to convince the wife I would have placed it on the roof of the cabin I think it would quiet things down quite a bit when underway and of course add an insulating quality
By far the Delt T spray insulation was the bomb, on the 22 I sprayed it in the v-birth and the cabin, you could practically talk with a whisper when underway Plus moisture was eliminated totally amazing stuff. I applied a good latex semi-gloss over the whole thing. But man that was a lot of work masking everything off and spraying on multiple codes and it wasn't cheap.
Peter & Judy
City/Region: Olds
Photos: Mistaya
PostPosted: Tue Apr 28, 2020 3:56 pm    Post subject: Reply with quote
Jay,
Thanks for the tips on the insulation and heating. I am going to have a better look at my plans and begin sourcing materials. I also plan to insulate the cabin roof, as we get some dripping here as well. You have done some very nice modifications on your boat and thank you for posting your photos of your projects. It makes it easier for us to envision how we might do ours.
pcg
City/Region: Sherwood
Vessel Name: C-Quest
Photos: pcg
PostPosted: Tue Apr 28, 2020 11:28 pm    Post subject: Reply with quote
I haven't started on my insulation project yet, and still deciding what I'll do, but here's some links that I've collected...
http://sanjuansufficiency.com/how-to-insulate-a-sailboat-part-1/
http://sanjuansufficiency.com/insulating-a-boat-hull-part-2/
http://sanjuansufficiency.com/boat-insulation-part-3/
http://www.c-brats.com/viewtopic.php?t=28256&highlight=
https://www.youtube.com/watch?v=6-DfBIgthbg
Prodex Total 10M
https://www.insulation4less.com/images/file/10M%20Plus%20Prodex%20Technical%20Brochure%20I4Less%202-2018%202a%20opcion%5B1%5D.pdf
Armaflex Armacell
http://www.armacell.us/products/aparmaflexaparmaflexfs/
Headliner
https://www.sailrite.com/HullBlanket-Headliner-Hull-Liner-Carpet-Type-Ivory-M93-72?gclid=EAIaIQobChMI39nghPXj4AIVVR6tBh32xgCmEAQYBCABEgI0ePD_BwE
https://www.youtube.com/watch?v=i-JNv8lZH_s
https://www.thevirtualboatyard.com/2009/02/installing-insulation-in-your-boats.html
http://www.oceannavigator.com/October-2010/Controlling-condensation-belowdecks/
https://www.practical-sailor.com/issues/44_1/features/Dirt-cheap-Winter-Insulation-for-Liveaboards_12340-1.html
https://forums.sailboatowners.com/index.php?threads/hull-insulation-in-a-solid-fiberglass-boat.71410/
http://www.trawlerforum.com/forums/s32/how-insulate-fiberglass-hull-warmth-condensation-10160.html
http://coatingsolution.com/marine-2/
Paul
PostPosted: Wed Apr 29, 2020 7:18 pm    Post subject: Reply with quote
Have just been using the cheap back packing pads for our 25 forward cabin. Not got to the ceiling yet--maybe some time during this lock down...I probably will put some Sunbrella or more resistant material over the pads eventually.
For our Cal 46, we put a PVC expanded foam headliner material glued onto 1/8" thick deerskins for the pannel. We screwed teak battens over the joints so the panels were easy to take down. Behind the panels, we glued on "fish blanket" which was available in almost every fishery supply or hardware store in AK. Some areas I finished out with the lightweight covering material used on airplane inside hulls--it was surplus at the McDonald Douglas store...Don't know if Boeing has anything like that as a surplus?
PostPosted: Wed Apr 29, 2020 8:48 pm    Post subject: Reply with quote
Boeing used to have a large surplus store in Kent, WA (or maybe Auburn). It was a neat place to go. You could get all kinds of interesting stuff. They used to get new deliveries from the various Boeing facilities on Mondays. On Tuesday morning before they opened there'd be a long line of people waiting to get in to get first dibs on the "new" stuff.
When I worked at BCA, you could hardly throw anything away. It all had to be sent to Surplus so they could decide what to resell and what to pitch out.
Boeing closed the Surplus store over 10 years ago. Probably because there were a lot of people that worked there and it was cost cutting time ('bout the time they moved HQ to Chicago).
WeekiTiki
City/Region: Weeki Wachee
Vessel Name: Just Cruisin'
Photos: WeekiTiki
PostPosted: Thu Apr 30, 2020 9:45 am    Post subject: Reply with quote
Once again
I recommend Bedrug
it's 3/4 inch foam that's made to withstand the elements
of being in the back of your truck
It's sold in six foot widths and you have to buy at least ten linear feet
The raw material is not corrugated like what would go in your truck
Used it on the floor in my 22
Way nice for only $2/sf
Weeki Wachee
WeekiTiki
Photos: WeekiTiki
PostPosted: Thu Apr 30, 2020 10:59 am    Post subject: Reply with quote
Bedrug is like I said "way nice" for only $2 per square foot
No need for the plastic slats holding the fuel cells in place
This material is rigid and 3/4 inch thick and
Great on your feet and knees
For ceiling it also comes in 1/4 inch thickness
Fish guts and blood wash right off
May very well line the cabin with it next
Made a paper pattern of the floor and
then cut the Bedrug with large scissors to fit
Nancy and Bud
Photos: Emma Mae
PostPosted: Mon May 04, 2020 1:14 pm    Post subject: Reply with quote
Finally making some progress. Used double sided carpet tape and covered the walls with closed cell foam. Then installed vertical boards to which the horizontal boards are attached. Will be a total of 12 boards 1 1/2" wide spaced 1/2 inch apart. Planned them to .20 inches thick so they would have some bend to them. One coat of boiled linseed oil on all wood.
Wood is cherry.
Photos here http://www.c-brats.com/modules.php?set_albumName=Tinker-Toy&op=modload&name=gallery&file=index&include=view_album.php
Page generation time: 0.0467s (PHP: 70% - SQL: 30%) - SQL queries: 28 - GZIP disabled - Debug on
