my oil looks like a milkshake :(
Goto page 1, 2, 3, 4  Next
cmetzenberg
City/Region: Santa Barbara
Vessel Name: Kanaloa
Photos: Kanaloa
PostPosted: Sat Nov 16, 2019 6:48 pm    Post subject: my oil looks like a milkshake :( Reply with quote
So after my run in with Katie the shark my port engine (honda bf150 2007 700hrs) was running rough. Today I inspected it and found milkshake oil. I found water in the #4 cylinder. all cylinders had spark and injection. The compression readings were:
1-210
2-190
3-195
4-180
To me this points towards a blown head gasket. What do you all think? I just did a 700 hrs service, so the oil was brand new and so was the impeller.
https://photos.app.goo.gl/PbZMNPepb7XAqpT66
Conrad Metzenberg
07' Tomcat 255 "Kanaloa"
87' Boston Whaler Guardian 17 (BlackFlag, 03-14)
PostPosted: Sat Nov 16, 2019 7:57 pm    Post subject: Reply with quote
I would tend to agree. Sad
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Sat Nov 16, 2019 8:15 pm    Post subject: Reply with quote
Yup. Either head gasket or cracked or corroded/failed head
A Fishin C
Guest
PostPosted: Sat Nov 16, 2019 9:43 pm    Post subject: Reply with quote
happen to me twice once on a 50 yamaha 4 strk and once on a 115 merc 4 strk
both times a thermostat
digger
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Sat Nov 16, 2019 9:56 pm    Post subject: Reply with quote
A thermostat doesn’t impact only 1 cylinder. The thermostat will add condensate to the oil, but will not make 1 cylinder wet, nor make 1 spark plug a different color than the rest.
A Fishin C
Guest
PostPosted: Sat Nov 16, 2019 10:24 pm    Post subject: Reply with quote
i just had water in oil
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sat Nov 16, 2019 10:59 pm    Post subject: Re: my oil looks like a milkshake :( Reply with quote
1-210
2-190
3-195
4-180
Pretty big swing between #1 & #4 not a good sign. Head gasket is my guess.
cmetzenberg
Photos: Kanaloa
PostPosted: Sat Nov 16, 2019 11:12 pm    Post subject: Reply with quote
Head gasket would be the best case scenario at this point. While attempting to get boresights of the cylinder walls a mirror on the endoscope broke off and is in the #4 cylinder...eh, the heads are coming off anyways. I was hoping to get a look at the cylinder walls and see how they looked.
tsturm
Photos: JMR-TOO
PostPosted: Sun Nov 17, 2019 12:06 am    Post subject: Reply with quote
You will have a great view now! Wink
tsturm
Photos: JMR-TOO
PostPosted: Sun Nov 17, 2019 11:32 am    Post subject: Reply with quote
ck crank end play, be less work, 4 mounting bolts couple wires & cables.
cmetzenberg
Photos: Kanaloa
PostPosted: Mon Nov 18, 2019 7:09 pm    Post subject: Reply with quote
Well, I got the worst news; my headgasket wasn't the issue. The issue was the engine had overheated repetitively. I don't understand this as i rarely get overheat alarms. Every now and then kelp will fowl the intakes but you just backdown and it comes off.
Anyways, my port engine is toast and is now only good worth a few thousand in salvage parts. Anyone have any advice on an economical way to replace? I don't want to drop 13k on a new one.
PostPosted: Mon Nov 18, 2019 9:25 pm    Post subject: Reply with quote
Is it a counter rotating engine?
Look for a used engine. Probably more likely to find one in places rather than Calif. A rebuilt--be be careful, there are some unscrupulous rebuilders.
A new or rebuilt power head--keeping your lower unit.
Occasionally a fisherman may decide to repower, and go with a larger engine.
There are 2 Honda 150's for sale on E-bay currently.
Search Craig's list.
Find a "Scratch and dent" new motor--I got one for several thousand off--had a bent skeg and scratches/ cracks in the cowl . it had been on a new boat, and in delivery the engine had been backed into an obstruction, with cosmetic damage.
PostPosted: Mon Nov 18, 2019 10:22 pm    Post subject: Reply with quote
Conrad. Sorry to hear of your predicament. Not a mechanic here so take the others advice.
cmetzenberg
Photos: Kanaloa
PostPosted: Mon Nov 18, 2019 11:41 pm    Post subject: Reply with quote
Hi Bob,
I'm leaning towards getting a used engine and putting my lower unit on it to keep rotation. That's all I have to do right?
I'm really confused how the engine got this way. The mechanic says it was significantly overheated over long periods of time.
PostPosted: Tue Nov 19, 2019 12:07 am    Post subject: Reply with quote
I would be interested in learning how frequent overheat can put water in the crankcase. If it was hot enough to warp the head you would not have needed an overheat alarm to know it. And why would it only do it to the brand new oil and not the previous oil if it was a long term condition?
I am not doubting your mechanic, but genuinely interested in knowing. I learn stuff on here all the time and am always appreciative when I do.
Best of luck with the replacement.
Page 1 of 4
Page generation time: 0.0422s (PHP: 67% - SQL: 33%) - SQL queries: 26 - GZIP disabled - Debug on
