Honda outboard fitting
cmetzenberg
City/Region: Santa Barbara
Vessel Name: Kanaloa
Photos: Kanaloa
PostPosted: Sun Aug 25, 2019 11:42 pm    Post subject: Honda outboard fitting Reply with quote
I'm not sure what this thing is called! I'm about to fashion a hose clamp to mine and some silicone. Anyone know the terminology for what this flange the rigging hose fits over? The one on the other engine is wobbly and loose.
[/img]https://photos.app.goo.gl/6hAKUR65xbejsaTR6[/list]
Conrad Metzenberg
07' Tomcat 255 "Kanaloa"
87' Boston Whaler Guardian 17 (BlackFlag, 03-14)
PostPosted: Mon Aug 26, 2019 2:38 am    Post subject: Reply with quote
Don't know which engine you have, but on my engine it is item 7 in this drawing.
https://www.boats.net/catalog/honda/outboard-by-year/2007-and-later/bf90dk0-lrta-vin-bbcj-1000001-to-bbcj-1099999/extension-case
PostPosted: Mon Aug 26, 2019 9:51 am    Post subject: Reply with quote
Some call this a "Rigging tube"--so a rigging tube flange--would be the terminology for the flange.
I have a shop manual for the Honda's--and can check that later in the day.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Aug 26, 2019 12:49 pm    Post subject: Reply with quote
Yes it is rigging tube which easy to find but the grommet is specific to outboards. The boat end is common part match to rigging tube diameter. When derigging, I suggest replacing the fuel hose inside the tube if hasn't been replaced recently just to be proactive
For Yamaha , go to https://www.simyamaha.com/RIGGING_COMPONENTS_s/1813.htm
Dr Bob will post the Honda info
Brent Barrett
BrentB
Photos: BrentB
PostPosted: Tue Aug 27, 2019 9:55 am    Post subject: Reply with quote
Is the flange bad? or tube needs to be threaded into flange?
cmetzenberg
Photos: Kanaloa
PostPosted: Wed Aug 28, 2019 10:01 am    Post subject: Reply with quote
on that engine the corrugated tube has become disconnected from the rigging tube that it should fit over. I see no threads of any sort. I'm going to silicone it and use a hose clamp
BrentB
Photos: BrentB
PostPosted: Wed Aug 28, 2019 12:51 pm    Post subject: Reply with quote
Rescue tape or other self fusing tape?
cmetzenberg
Photos: Kanaloa
PostPosted: Wed Aug 28, 2019 11:26 pm    Post subject: Reply with quote
On this fuel hose replacement, I've never done such. How often does this need to be done? My boat is covered so the hoses have very little UV exposure. I see not cracks or signs of deterioration.
BrentB
Photos: BrentB
PostPosted: Fri Aug 30, 2019 12:04 am    Post subject: Reply with quote
The fuel line is inside the rigging tube and a good time to replace it when derigging items from the motor side for new flange and tube, and inspect throttle cables and electrical wires. It takes a couple hours
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Fri Aug 30, 2019 12:20 pm    Post subject: Reply with quote
Rigging Grommet . Scoll down on page and find your grommet !
https://marine.honda.com/parts/accessories/categories/harnesses
Marc
Wefings Marine Website
Since 1909
Page generation time: 0.0398s (PHP: 63% - SQL: 37%) - SQL queries: 23 - GZIP disabled - Debug on
