"It's too hot to live"
Goto page 1, 2, 3  Next
Snider
City/Region: Charleston
State or Province: SC
Vessel Name: Kestrel Dawn
Photos: Kestrel Dawn
PostPosted: Mon Jul 08, 2019 11:13 am    Post subject: "It's too hot to live" Reply with quote
"It's too hot to live" my 7 yo Saturday night while anchored out for the night in Edisto SC. I need to work on ventilation. I've been putting off these projects as there's just been other stuff to do, it's not my area of expertise and typically we've only anchored out when it's been cool. Really need to work on ventilation, screens and some fans.
I've been looking at all of the curtain pictures and like the ones I've seen with a teak strip mounted above the window and sunbrella that rolls up and stores there. Is there any off the shelf resources for this? I imagine I'll have to mount them myself and get someone to sew them for me.
Next I need to get screen coverings for the opening window, forward hatch and door. Also need to rig up something up so we can keep these open in the rain. It gets hot when it starts to rain and you have to mostly close everything.
Anyone recommend any resources for fan manufacturer? From my sailing days Hella was popular. Also any semi off the shelf curtain resources? Not sure I'm any good at sewing. Also thought about mounting a couple small hatches in the roof like I saw in one of the boats for sale, Need something that keeps water out though. Maybe a dorade vent up on the foredeck? I really hate drilling holes in the boat.
Any pictures or thoughts about the best place to install fans? I figure one or two in the v-berth and maybe two in the cabin?
Brandon
22ft Cruiser
Charleston SC
PostPosted: Mon Jul 08, 2019 12:22 pm    Post subject: Reply with quote
Kids...Laughing
Curtains: I just cut strips of wood, painted them to match the interior and glued them up with 5200. Then used plastic curtain tracks that are widely available on the internet. The curtains were custom made and I did not sew them. They were sewn by a fellow Cbrat's wife. She is a pro and the quality is A+. Pics in our album.
Window screens came with the boat. One for the door would increase the surface area, but we don't have one as the PNW generally does not get "hot".
alainP
City/Region: TUCSON
C-Dory Year: 2011
Vessel Name: deja la
PostPosted: Mon Jul 08, 2019 12:31 pm    Post subject: Reply with quote
Fans: Caframo 747
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Mon Jul 08, 2019 1:23 pm    Post subject: Reply with quote
Our new to us boat came with snap on blue sunbrella curtains, we roll them up and hold them with double side velcro straps. The previous owner in South Dakota heat sewed a white material on the outside that really reflects the sun.
Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG
PostPosted: Mon Jul 08, 2019 1:42 pm    Post subject: Reply with quote
My current 25 has wood strips affixed to the area above side and aft windows, The curtain material is slid into a track and when rolled up is head by small diameter shock cord, looped over a round head screw. The forward curtains have shock cord around the periphery, and go around "buttons" screwed to the window Frame All of my other C Dory have had the snap on Sunbrella curtains. remove one of the frame screws in the corners, and put a Male snap in its place. The threads are close enough.
Screens. Current boat has shock cord around periphery. I have used army surplus No see em net and hot glued velcro to the edges. The mating velcro is contact cemented to the window or hatch frame.
For the forward hatch, we use an Endless Breeze Fan
The fan is supported on 5/8" dowels which go across the hatch (we flattened the ends so it does not roll)
We have a cover which goes from under the eyebrow, over the foredeck, being held by eye bolts under the eyebrow, and pieces of 3/8" line to the bow pulpit. If it is really blowing, we take the forward end of this to the deck on each side of the pulpit (eye bolts) and to the forward cleat.
This allows both the forward opening window, and the hatch to be open, and protected from rain.
For the inside each bunk has outboard, at the aft end of the bunk: Caframo Maestro fans. These have a remote variable speed control as well as control for the red or white LED light which is in the center of the fan. The remote control is placed so it can be operated from outside the V berth, or by reaching overhead when you are lying down.
Also the port bulkhead of the V Berth area has been completely removed--much better air circulation. We run the fans almost every night--mostly on the lowest setting.
Then there is air conditioning!
Snider
PostPosted: Mon Jul 08, 2019 1:51 pm    Post subject: Light Reply with quote
Thanks Bob, that would possibly solve my lighting problem too. How bright is the light? I was planning on adding those dome white or red lights to replace the factory light anyway. What do you think, four to these for the 22? Two in the V, two in the cabin?
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Mon Jul 08, 2019 5:36 pm    Post subject: Reply with quote
Curtains and screens only restrict air flow and increase perceived heat.
Realize, heat is one thing and bugs are another.
If I had my drothers, I'd bug proof myself first, then deal with heat thus:
Sponge your exposed skin with water. Relax and allow Mother Nature to
do Her thing. A simple small fan helps immensely. A couple ice cubes in
a wash cloth on your forehead will make you a Believer.
The science: You're on a boat so you have water. Most boats have ice.
Evaporating water cools the surface it is on.
The above time proven BYT, before A/C. KISS.
Aye.
PS: Kindly inform your son it's going to get worse.
"I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Mon Jul 08, 2019 8:05 pm    Post subject: ac Reply with quote
Put in RV A/C on the roof get yourself a small genset and be done or use the 5000 btu wall-mart special and put it in the front window we've done both methods and the RV A/C is the best I should have done this 10 years ago when I bought the boat
although it takes a bigger genset 2000 watt vs a 1000 watt for window A/C
We live in SW Florida and it gets mighty hot and Humid down here so anytime we camp out AC is a must Good Luck in your decision
JIm
Snider
PostPosted: Mon Jul 08, 2019 8:51 pm    Post subject: Re: ac Reply with quote
JIm
I have a 2,200 watt portable generator. I've been thinking about the window unit. Where do you put the genny? I'm worried about CO. I could put it in the splash well or on the swim step, but still CO is a concern. One problem is during the summer here, as you know in FL is that we get showers a lot during the summer, eve throughout the night, which would make the generator use problematic anyway.
Snider
PostPosted: Mon Jul 08, 2019 9:07 pm    Post subject: Reply with quote
I agree with you on the bugs. Still have PTSD from sleeping aboard our small sailboat 10 years ago. I swear I still hear buzzing when I close my eyes on any boat, lol.
We're in salt water, not a fan of salt water baths. Could use the fresh water from the tank. I think we'll maximize ventilation and get some fans.
Aye.
PostPosted: Mon Jul 08, 2019 9:48 pm    Post subject: Reply with quote
Unfortunately in high humidity areas the Evaporative cooling method only makes it more humid....
As for the generator and CO. This is always a major concern. On the 22's we have put the generator on the swim step--on top of a plastic "milk" crate--both the crate and generator strapped with Bungee cords. On our 25, I have mounted it above the splash well, with generator exhaust pointed aft. It is on 3/4" thick Starboard, mounded on neoprene mounts, with bolts going directly into the generator. The Starboard is mounted with another piece of Starboard on a 1" SS tubing which goes across the splash well. The tubing, also keeps 2 gallon spare gas cans in place. The generator is " theft proof", since the starboard is bolted down at its forward edge. I also have a vinyl "Shelter Rite" cover for it.
As for the CO, I have 3 CO monitors in the boat. One at the same level as both of our heads, and one at the level of the helm persons's head. These have digital readouts, so we can check the levels. I have had more problems with other boat's exhaust than I have had with our generator. We tend to use the generator when at anchor, and usually the wind blows any exhaust aft, and clear of the boat.
I didn't mention our "second fan"--it is a Ryobi portable fan, and we use it either in the forward hatch, or elsewhere on the boat, if needed for cooling. It gets over 8 hours on the large batteries, and charges with a 30 minute charger, either from the inverter when the outboard is running, or generator /shore power. There is also a 12 volt charger available.
As to the light--Yes, I use the fan light as my primary reading light. All of my boat's lights have been converted to LED. I also have a complete system of only red LED's which I can switch on from the bunk for night time use. There is also a set of 3 red LED's in the cockpit. Each of the forward overhead lights has both red and white LED's, and two brightness levels.
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Mon Jul 08, 2019 9:53 pm    Post subject: window ac Reply with quote
Brandon,
We just completed a one-way ICW transit from JAX to Waca Weeche marina near Myrtle Beach, SC. Eileen read your post and said ‘oh my, how did he ever stand the heat?”
We found Charleston’s Harborage Marina very nice and the AC worked well.
We have two Honda 2000IU gensets for home hurricane prep, but to date would not use them on the engine bracket or elsewhere on the boat due to noise, vibration, heat, exhaust smell and CO worries despite a Marine CO and Lowes CO detector in our cabin. Maybe we will evolve on this issue, as Bob and many others have had great success using one.
Regarding screens, we recently had all four TomCat screens professionally re-done with no-see-um screen for under $100. A few weeks in the upper Everglades surrounded by mangroves and no see ums…worth it.
Regarding an aft door screen, the ‘as seen on TV’ magnet screens secured by Velcro tape on the sides of the aft door work fine, a $15 per year item.
Buy the $20 version for better magnets and better Velcro.
Regarding a front opening window screen, roll your own from ‘no see um’ screen with Velcro tape on the window sides and staple/glue Velcro on the screen. Expect 1-3 seasons from it. About $8.
Regarding 12v fans, ditto Caframo 747 for Capt and Nav seat. 5,000h motor, 5 yr warranty, point it anywhere, soft plastic blades stop rather than penetrating my head every time I do that.
Regarding large 12v fans, ditto Ventastic (we have three for the transom ‘wall of fans’).
Regarding a window AC, I regard our install of the LG 6kBTU a success (see my post), for $100 more than the well-tested and well regarded WM Artic Air you get 1,000 extra BTU for 260 rather than 150 CF, a remote control and the exact same wgt as the Artic Air (all other 6k units I researched were 56# and up rather than the 39# of the Artic Air). A bit tricky insulating the window without blocking an outflow vent very close to the enclosure , but a ridged Walmart pool noodle does well.
Regarding sunbrella window coverings, ditto substituting window frame screws for snaps and just using Velcro tape to secure the roll (as small as 1 inch with two rolling) rather than wood trim ‘housing’. She Who Must Be Obeyed was fine with this (surprised me). We leave the Velcro on the mouse fur, hilarious but we never misplace it.
Good luck and safe travels,
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Tue Jul 09, 2019 7:44 am    Post subject: ac Reply with quote
John I thought you had the 9200 Coleman AC Are you using a window one also ? Jim
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Tue Jul 09, 2019 7:58 am    Post subject: ac Reply with quote
John saw your other post Sorry your Coleman called it quits in the middle of Summer . Dr. Bob is right cut with a Dremel.
John you did get 10 years out of the AC unit that's pretty good I'm hoping for the same by then I might sell the boat Take care Jim
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Tue Jul 09, 2019 8:48 am    Post subject: Reply with quote
I cannot imagine using Sunbrella for window coverings as they transmit zero light. Our C-Dory came with snap-on window coverings made by Proctor Canvas in Duluth MN. I don't know the name of the fabric, but they are a light cream color and are translucent, so that one gets shade without total darkness. And they are very durable. I numbered each one of them to clock positions to facilitate their repeated placement. When we got the boat, because we normally anchor privately, we thought we would have no use for the coverings. But we have since learned they are invaluable to keep out, especially late day, sunshine.
Page 1 of 3
Page generation time: 0.0388s (PHP: 73% - SQL: 27%) - SQL queries: 28 - GZIP disabled - Debug on
