Wallas Louvered Vent?
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Thu Jun 27, 2019 5:04 pm    Post subject: Wallas Louvered Vent? Reply with quote
We finally bit the bullet and ordered a new Wallas today, not wanting to attempt to keep the old one functioning for another few years at great cost.
One thing I had never done with the old one was to install a 20 sq. in. louvered vent in our cabinetry as recommended. For those of you who have done this, can you recommend a specific vent model and placement position?
Thank you,
Allan on the MOOSE
PostPosted: Thu Jun 27, 2019 7:28 pm    Post subject: Reply with quote
Out of 4 Wallas, I had one with a vent cover. One came with a long narrow cover, One was open, and the other 2 had no vent--I added by drilling a 1 1/4" hole at each end and then using a saber saw to cut the straight line between the two holes 18" long.
On the ones with an "open vent", I put a 24" hand rail in front of them--something I have always done in front of a stove, to give a hand grip, and safety bar--also makes a great dishtowel rack. There is a fair amount of ventilation, from the area which is often open under the gunnel on the starboard side; but not 20 sq inches.
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Fri Jun 28, 2019 8:20 am    Post subject: Reply with quote
I ordered the vent from scan marine when I ordered some other accessories. Our boat never came with a Wallas, so I installed a used one.
Its mounted directly below the on the cabinet above the door, next to the wallas switch and below the wooden trim.
We have the molded fiberglass interior, and used some blue painters tape, and an ink pen. I made a cardboard template from the footprint of the vent and drew the lines on the blue tape. Than used a drill and a jig saw to carefully cut the hole. I'd already done the hole for the wallas itself in the reinforced area of the cabinet so the vent was a piece of cake.
2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016
PostPosted: Fri Jun 28, 2019 12:29 pm    Post subject: Reply with quote
Mine has no vent, and has worked great for 15 years. There is a cutout on the front of the cabinet, below the doors for a foot pump for the water. That is almost big enough.
MOOSE
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Fri Jun 28, 2019 12:39 pm    Post subject: Reply with quote
Thanks everyone for your comments. I found a vent that would fit perfectly above the cabinet doors, but continued to wonder why I would need one. At the back left corner of the cabinet, where a lot of the control cables pass through, there is a cut-out that is easily 36 sq. in. and has, like hardee, worked fine for 17 years at supplying air. I called Scan to talk with them about it and they agreed that, while perhaps not ideal, don't install anything unless I find a problem with overheating. I doubt I will.
And, Bob, I also added a two foot grab rail at the front of the cabinet and you're right, it's where we hang towels.
Again, thanks all for your thoughts.
Allan
PostPosted: Fri Jun 28, 2019 8:06 pm    Post subject: Reply with quote
There are a number of cutouts in the cabinet that let in air. There is the cable opening at the back, but also one at the front (where the cables go through to the helm. There is the hole for the foot pump, and some boats have finger holes in the cabinet doors instead of knobs for opening the doors. If you install the Wallis correctly there is also a slot at the back of the stove that is open as well.
PostPosted: Fri Jun 28, 2019 8:07 pm    Post subject: Reply with quote
There are a number of cutouts in the cabinet that let in air. There is the cable opening at the back, but also one at the front (where the cables go through to the helm). There is the hole for the foot pump, and some boats have finger holes in the cabinet doors instead of knobs for opening the doors. If you install the Wallis correctly there is also a slot at the back of the stove that is open as well.
Page generation time: 0.0322s (PHP: 62% - SQL: 38%) - SQL queries: 20 - GZIP disabled - Debug on
