Battery Choices
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Thu Dec 06, 2018 9:09 am    Post subject: Reply with quote
Foggy wrote:
I was surprised to learn for twin outboards (Honda 90s), each requires its own
starting battery. So that means 3 batteries for the redundant types since you'll
also need a house battery.
For twins on a 22CD, I'd put in 3 AGM Gr 27s and for larger 3 AGM 31s; all deep
cycle since they'll meet the engine battery specs for engines for these boats.
You can never have too much juice as thirst is a dangerous thing.
Aye.
Some may have been configured this way, but our 2003 with twin hondas was not. You could start both engines with the battery switch positioned in the #1 or #2 position. No requirement for this, its all in the wiring.
2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Thu Dec 06, 2018 1:22 pm    Post subject: Reply with quote
You can get away with walking on thin ice too, sometimes.
For the serious twin outboarder, a dedicated battery for each is the recommended
default. This was echoed by my dealer, his tech and the local Honda factory rep.
Plus, reading can help:
https://forums.iboats.com/forum/boat-repair-and-restoration/electrical-electronics-audio-and-trolling-motors/67683-ideal-battery-switch-setup-for-twin-outboards
https://www.westmarine.com/buy/marinco--battery-distribution-cluster-for-twin-outboard-engine-three-battery-banks--14152219
https://shop.pkys.com/Battery-layout-for-twin-engine-boats_b_36.html
Aye.
Snider
City/Region: Charleston
State or Province: SC
Vessel Name: Kestrel Dawn
Photos: Kestrel Dawn
PostPosted: Thu Dec 06, 2018 2:10 pm    Post subject: Down the rabbit hole Reply with quote
Down the rabbit hole.
It's funny how a weak battery that wouldn't start my Wallas lead to two AGM group 27's (from 24), an onboard charger, and now I'm looking at putting in a 30a shore power receptacle, 120v panel and an extra outlet, heck, may as well add an inverter as well, already have one I can install. Shocked
Brandon
22ft Cruiser
Charleston SC
PostPosted: Thu Dec 06, 2018 8:24 pm    Post subject: Reply with quote
Ref the LED (While we are spending your hard earned dollars). Either bulbsordedicated fixtures. In my current 25, the prior owner had converted all of the original fixtures to full bright and dim white LED, and full bright and dim Red LED. The LED bulbs are really cheap--but there is an infant mortality for the bulbs. Conversion is fairly easy, as long as you can solder. I have purchased 50 assorted color LED (warm white, cool white, red, blue, green--10 of each for $8.00 @ Amazon. Also 100 LED cool white for about $10 on Amazon. (I was using these for multiple lights inside each cabinet and in the storage under the V berth, and settees). Also put in aisle lighting and night lighting.
As for 110V system: There is a less expensive way than the panel. That is to get a battery charging inlet: I put these thru the starboard side aft bulkhead, under the gunnel. These take a standard 15 amp extension cord (the inlet is a recessed male 15 amp plug). Then I go to a fuse box, with a switch on the hot leg. (Motor start box from Home Depot)--and that is either hard wired to the battery charger, or to an outlet for the battery charger. Since I never used more that 15 amps, I also put in several outlets in the 22--under dinette seat and forward under galley outboard of the helm seat. All of the fittings for this cost less than $50 at Home Depot.
Photo of 110 V outlet, plug to guest battery charger, and fuse box/switch.
Photo of battery charger inlet under starboard gunnel:
Snider
PostPosted: Thu Dec 06, 2018 8:52 pm    Post subject: RED Lights Reply with quote
Hey Bob,
Thanks for the pictures, they are truly worth a thousand words.
I see what you did there, recessed male plug to breaker, then to receptacle for charger and to other receptacles? I like it.
I really like the red interior lights. Thats my ultimate goal, to install a fixture or two with a red/white switch, I think I could just wire these to the same "lights" breaker that the other two are wired to right? . The more I use and work on the boat the more comfortable I get with drilling a few small holes.
The hardware you screwed into the aft bulkhead in that picture, is it just screwed into the core or thru-bolted? If its screwed in, what length screw did you use?
My shore power and inverter comment was a little tongue and cheek. The shore power with an extra outlet or two is way down on the list, but I really am not in a hurry as I don't really need one right now.
As for the charger I'm going to mount, I did get a 15amp recessed male plug that has a female plug on the other end. I'll just plug the battery charger into that. My boat spends most time in the yard on the trailer when not in use, so I'll run an extension cord from an outside GFCI to the charger, the same way I do now for the dehumidifier. So I won't have a breaker right at the charger, I assume thats OK. If I need to plug in at a marina I have a 30a > 15a GFCI adapter.
https://www.amazon.com/gp/product/B009ANV81S/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Eventually it'll be easy to wire in a system like yours using the recessed plug I install, I could cut the plug off and wire it to a small breaker, or replace it with one that accepts wire to the back of it.
As for spending money you got that right, I dropped quite a few Benjamin's this week on batteries and chargers, especially when you add in the camper, lol. Some people have vacation homes, we have a boat and camper. I still need to upgrade my VHF for safety reasons, and eventually get a plotter. It's worth it, we love this boat!
Snider
PostPosted: Sat Dec 15, 2018 2:39 pm    Post subject: Thanks Reply with quote
Thanks everyone, I got my charger mounted, my new batteries in and hooked up. I put it under the sink on the aft side of the bulkhead right behind the helms seat. It seemed a little sturdier to mount it there and in more unusable space just inside the sink drain. I also mounted a 15 amp recessed male receptacle under the starboard side gunnel where Bob pictured above. I really just need two outlets, one for the charger and one for a dehumidifier so I'm thinking about getting a mountable 3 outlet power strip with a breaker that I can mount beside the charger.
Something like this.
https://www.amazon.com/gp/product/B000F99CJG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
anchorout
City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
PostPosted: Sat Dec 15, 2018 10:10 pm    Post subject: Sams agms Reply with quote
I pulled up the SAMS site to checkout their AGMs. The reviews were awful. Think I'll stick with my Interstates.
PostPosted: Sun Dec 16, 2018 12:15 am    Post subject: Reply with quote
Foggy Said: (some stuff clipped)
"I was surprised to learn for twin outboards (Honda 90s), each requires its own
also need a house battery."
Well, for the last 14 years, my twins have each had their own battery, ( a Group 29). Yes, but those 2 batteries are the only ones. No house battery, just careful management via cheap and easy volt meter and manual use of the 1-2-Both and Off switch.
BTW, Anchorout, min have been Interstates Deep Cycle the whole time.
PostPosted: Sun Dec 16, 2018 6:42 pm    Post subject: Re: Sams agms Reply with quote
4.2 average stars with only 28 reviews is awful? One gets mostly complaints on internet reviews. I have had outstanding results with why Sam's AGM group 31 marine batteries. They are made by East Penn.
We must live on different planets!
Interstate batteries are also excellent batteries.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sun Dec 16, 2018 7:25 pm    Post subject: Reply with quote
Dr. Bob,
I too have purchased batteries for my last 5 boats from Sams. My 22 (that will soon be for sale) has AGM's from Sams and my new (to me) 26 will get Sam's AGM's when the existing batteries show a hint of low voltage.
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Mon Dec 17, 2018 1:12 am    Post subject: Reply with quote
I've used East Penn's MK brand AGM / gel cell batteries on electric handicap scooters for years
and there's no comparison with some of the cheaper band alternatives,
particularly some of the foreign stuff (Chinese).
East Penn also markets batteries under several other names in the US.
I'd give them 5 stars any day! Star Star Star Star Star
anchorout
Photos: EZ DUZIT
PostPosted: Wed Dec 19, 2018 1:21 pm    Post subject: group 29 Reply with quote
FYIO: A group 29 house battery will fit crossways inside the front of the transom stb locker, allowing a smaller, starter battery to the rear. I use the space between the gas tanks to fit an auxillary 12 gallon tank on long trips. Anyone have a different setup in this locker?
PostPosted: Wed Dec 19, 2018 2:57 pm    Post subject: Reply with quote
I have a group 24 starting battery in the starboard lazarette and a group 27 house battery in the port side. Both situated parallel to the gunnels.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Wed Dec 19, 2018 3:34 pm    Post subject: Reply with quote
Harvey (nothing clipped),
Glad you can get by on your twin engine boat with using only your two starting
batteries, voltmeter and fiddling with your battery switch.
Guess you're not one of "the redundant types".
Aye.
When Grandpa used to say, "If two is good, three is better",
he was referring martinis before dinner...
PostPosted: Fri Dec 21, 2018 1:19 pm    Post subject: Reply with quote
Aye.
Foggy,
Oh But I Love Redundancy. Twin engines, Multiple VHF's, extra antennae, double extra PFD's, duel plotters, Tandem axle trailer, 2 anchors, multiple flashlights, 2 spot lights, add on infanitum......
to wit. I can start and run both engines on either of my batteries.
AND, I like the idea of a spare 12 gallon tank, just hate the extra weight so far aft.
Page 4 of 5
Page generation time: 0.1321s (PHP: 37% - SQL: 63%) - SQL queries: 28 - GZIP disabled - Debug on
