South of Heaven
Photos: Blue Water
Posted: Tue Aug 28, 2018 6:51 pm Post subject: |
OP: If you don't have an anchor drag alarm on your electronics then download an app on your phone.
If you don't then you won't get any sleep at all....Unless you're an old salt but I don't think you are since you posted this thread. LOL!
I like using moorings when at all possible! _________________ <><><> Jason <><><>
Joined: 27 Oct 2012 Posts: 3384 City/Region: SW Michigan
Posted: Tue Aug 28, 2018 8:12 pm Post subject: |
I don't use an anchor alarm because then for sure I would not get any sleep, just be waiting for it to go off.
I just make sure the anchor is set well and then go to sleep. I also don't anchor where there are large current shifts or large tidal swings. |
Posted: Tue Aug 28, 2018 9:28 pm Post subject: |
I have never used an anchor alarm. I have marked where the anchor was dropped when we got accurate GPS. I still take bearings on objects on shore, and record them, so I have references. (GPS makes this much better).
I set my anchor, with the boat's power in reverse, so I know it is well set. Some bottoms and holding grounds take several "Sets" to be sure that the anchor is properly set, and will not drag under conditions encountered.
I also always have a plan for alternate anchorages, or having to leave and "put to sea" if an anchorage becomes untenable. Don't be afraid to move at night--and have that move mapped out at least in your head, if it is necessary. Know what might happen, as the wind and waves (current also) shift, and if there is any risk for your boat.
I sleep well, but, I get up every couple of hours to check my bearings or GPS position and check the weather. Also to look and see how nearby boats are riding, and if there are any potential issues. _________________ Bob Austin
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2770 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Wed Aug 29, 2018 11:07 am Post subject: |
Bob, I get up several times as well. Age related , and I also check location bearings. _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
Kushtaka
Photos: Kushtaka
Posted: Thu Aug 30, 2018 8:43 pm Post subject: |
If the windlass is down I can haul my anchor from my pot puller in the cockpit. If I'm solo and without a motor to pull the anchor, I use the line running from my bow eye to my cockpit running through a regular 2" ring.
I drop my anchor from the cockpit, tie it to the ring at the desired scope, and let it go. It zips right up to the bow.
When it's time to pull I motor up and alongside it, let the ring come all the way aft, and then grab it. If I'm puling by hand I'll clip a buoy to the ring, run the free end of the rode through the ring (it would be easier with a anchoring ring that opens/closes, but I don't have one) and cleat it to the stern line, and motor the boat away and around the anchor. It comes right up, then I pull in the anchor by hand with the bulk of the weight on the float.
I use the same technique if I'm bringing the rode to the cockpit to haul up with the line hauler. |
Posted: Thu Aug 30, 2018 10:27 pm Post subject: |
[quote="South of Heaven" I like using moorings when at all possible![/quote]
The reason I don't like moorings is that you have no idea what the terminal tackle's condition is. Have the shackles and chains been regularly inspected and replaced? What type of "anchor" is there?
I have seen moorings give way during storms. I have also moved mooring blocks which were in the tons of weight.
I know that my anchoring gear is in first class condition, and what to expect of it. |
Posted: Thu Aug 30, 2018 11:10 pm Post subject: |
The nice thing about docks or shore ties, you don't have to worry about current, wind, anchor or mooring ball drag, anchor alarms or hourly position checks! Or standing on deck to drop or weigh anchor! (Of course, calm water is still preferred! ) Colby |
Posted: Fri Aug 31, 2018 12:10 pm Post subject: |
colbysmith wrote: | The nice thing about docks or shore ties, you don't have to worry about current, wind, anchor or mooring ball drag, anchor alarms or hourly position checks! Or standing on deck to drop or weigh anchor! (Of course, calm water is still preferred! ) Colby |
You just have to worry about the side of your boat getting beat up by banging against the dock caused by wind, waves, or wakes. There can also be issues with fixed docks and tidal changes.
One disadvantage with O/B engines is that they can be vulnerable to dock damage because they are a prominent protuberance at one end of the boat. In the mid Atlantic region, a large number of the docks are fixed and have short fingers. The usually requires backing into the slip if you want to be able to get on and off a boat as small as a C-Dory. If not tied carefully, this can put the motor(s) at risk of bashing against the dock. |
Posted: Fri Aug 31, 2018 12:30 pm Post subject: |
Quote: | You just have to worry about the side of your boat getting beat up by banging against the dock caused by wind, waves, or wakes. There can also be issues with fixed docks and tidal changes. |
No tidal changes in the Great Lakes! But I do agree about the wind and such. That's why I said calm water. If the wind and waves are that bad at night, I choose to be off the water. Colby |
Posted: Fri Aug 31, 2018 4:26 pm Post subject: |
colbysmith wrote: | Quote: | You just have to worry about the side of your boat getting beat up by banging against the dock caused by wind, waves, or wakes. There can also be issues with fixed docks and tidal changes. |
My boat got beat up at a dock in a developed area when we left it tied up for lunch once. Wakes from passing boats (while we were away) took the rub strip off my boat and off the dock where I was tied up. |
