Solar Charging Battery Bank(s)
PostPosted: Mon Jul 16, 2018 5:41 pm    Post subject: Reply with quote
Well, Foggy, we do agree on that many will do fine with just a volt meter. But even in the 80's I had gone over to a digital volt meter, and managed a 1200 amp hour battery banks for about 100,000 ocean miles over 8 years, with just the digital volt meter. On the other hand, you are measuring the amps in and out with the Watt Wizard, so you do have modern technology, and are not a Luddite.
I find advancing technology one of the interesting challenges of boating. Currently, I am trying a liFePO4 battery of usable 110 amp hours, weight 29#, (and a fraction of the size of an 8D or two group 31's), for the Freezers/refrigerators, and with the Li battery technology the old "volt meter" is no longer valid. Victron Energy recommends a Peukert's exponent of 1.05 rather than the accepted 1.25 for lead acid batteries. I suspect that lead acid batteries (including AGM) will be a thing of the past in a few years.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Wed Jul 18, 2018 8:07 am    Post subject: Reply with quote
that away wrote:
SNIP To charge the engine battery from the solar system, you need only to parallel the two battery banks, This gives you one bank of 5 group 31 AGM batteries. SNIP
Seems simple, direct, a complete great answer to the post. Is it?
With 3 battery switches (start, parallel, house) does the above hold true regardless
of the ON/OFF status of the start and house bank switches? Then there are
ignition switches to consider...
Aye.
Grandpa used to say, "The more you know, the more you learn there is to know."
Grandma used to say, "Most of us don't know what we don't know."
PostPosted: Wed Jul 18, 2018 10:31 am    Post subject: Reply with quote
Solar (165W) properly wired to charge House bank only
To charge the generator, since they are all the same size and type, one only needs to connect the two battery banks together--that means parallel.. All other switches are extraneous to this goal.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Wed Jul 18, 2018 11:59 am    Post subject: Reply with quote
Thank you.
Aye.
PostPosted: Wed Jul 18, 2018 2:06 pm    Post subject: Reply with quote
Oops, "Generator" should be solar panels.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Wed Jul 18, 2018 7:19 pm    Post subject: Reply with quote
Oops = no harm done.
Aye.
Page generation time: 0.0396s (PHP: 62% - SQL: 38%) - SQL queries: 19 - GZIP disabled - Debug on
