mkendrick
Joined: 27 Jul 2011 Posts: 13 City/Region: White Stone
Vessel Name: Nickel 'N' Dymer
Photos: Nickel 'N' Dymer
Posted: Wed Jun 20, 2018 9:46 am Post subject: Cabin Water Drain System Problems |
3 hoses (2 of which are the hot water heater and shower) leading into the cabin water drain system’s plastic box have snapped/broken totally off the intake ports molded to the outside of the box, leaving some of the inlet ports inside the hose. Does any know where I can get a new box?
Does anyone know how this might have happened? The boat is winterized each year, and obviously we don’t use the hot water heater or shower or we would have discovered this issue sooner. Could cold weather cause this? Is this a common problem or am I just one of the not-so-lucky ones?
I have a picture but cannot remember how to download it onto CBrats. I can email it or text it if I have that information.
Thanks for help with this and past problems. Would really be lost without CBrats. _________________ Mickey and Beth Kendrick |
tsturm
Joined: 01 Nov 2003 Posts: 1165 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Wed Jun 20, 2018 9:54 am Post subject: Re: Cabin Water Drain System Problems |
mkendrick wrote: | Cabin Water Drain System Problems
Thanks for help with this and past problems. Would really be lost without CBrats. |
Shower box drain = West Marine
Need to put rv antifreeze in the shower drain also  |
Joined: 02 Nov 2003 Posts: 21380 City/Region: Pensacola
Posted: Wed Jun 20, 2018 10:34 am Post subject: |
There are multiple shower box drains--check google, and you will find Rule (original) Johnson, Seaflow, Atwood, Amarine etc. Be sure that the dimensions are the same as yours, or it will fit--start at $49...Be sure you get a gasket top unit, so no overflow. Also good to have a float switch to come one when the water is in the sump. You could also repair the box you have, by putting plastic thru hull fittings thru those holes, and "welding" or epoxy (G FlexI) the plastic. But I don't think it is worth it.
I prefer to get all water out of the system, but I also try and avoid freezing temps... _________________ Bob Austin
spuncopper
Joined: 02 Sep 2012 Posts: 196 City/Region: Camden/ Lake Wateree
State or Province: SC
Vessel Name: Sock Monkey
Photos: Sock Monkey
Posted: Wed Jun 20, 2018 7:00 pm Post subject: shower drain box |
Check with Defender Marine Outfitter out of Waterford Ct. 800-628-3336, www.defender.com. |
spuncopper
Photos: Sock Monkey
Oops, double post. Twitchy finger maybe?  |
