Boat Cover
harworth
City/Region: Bemidji
State or Province: MN
PostPosted: Sun May 06, 2018 11:39 pm    Post subject: Boat Cover Reply with quote
I am ordering a boat cover for my C-22 from Angolo Canvas. My question is how other owners attach the cover? Snaps, draw string? Also does anyone have thoughts about mooring lines going through cover or under.
Harry
PostPosted: Mon May 07, 2018 10:15 am    Post subject: Reply with quote
I got my 22 cover from Angola canvas. I use it on the trailer with ropes going through the hem and tied to the trailer frame. I had to add a number of additional grommets to the hem for the ropes I needed.
When I ordered my cover I had Angola add to the sides of the cover. Their design only comes down to the rub rail. I had them add about 2' to the cover all the way around.
The cover I ordered has the integrated motor cover. This helps hold the sloped portion over the cockpit tight. However, IMO this puts some stress on the seam where the motor cover part attaches. I had them reinforce this seem.
Angola is easy to work with. I sent them pictures and dimensions of my boat so they could add reinforcing pads in the right places. After I first got the cover I wanted some changes, so I sent it back and they did the mods for a modest charge (mostly for additional fabric).
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Mon May 07, 2018 10:33 am    Post subject: Reply with quote
Mine is secured with bungees to the trailer. Its quick and easy
2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016
harworth
PostPosted: Mon May 07, 2018 12:08 pm    Post subject: Reply with quote
I will be using the cover primarily when boat is docked in marina.
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Mon May 07, 2018 12:47 pm    Post subject: Reply with quote
Just some random thoughts. The full boat cover from Angola is usually used when the boat is stored on a trailer. Most of the time at the dock a slant back mooring cover is used. That said, I have seen full covers on docked boats where the cover was held down by water filled gallon jugs suspended from the grommets.
MartyP
PostPosted: Mon May 07, 2018 2:42 pm    Post subject: Reply with quote
You could also install snaps above the rub strip.
PostPosted: Mon May 07, 2018 2:43 pm    Post subject: Reply with quote
I also have an Angola cover. I use 1/8" dacron line, and a taut line hitch to the trailer frame. For years on a number of boats slipped in the water, we made sand bags, which attached to the points where the straps or lines would tie the cover down. I would probably add a "common sense"--this is the turn the tab type of fasteners. To keep the cover in place just in case of a heavy wind.
My cover almost covers the accent stripe on both sides--I shift it slightly to the port side, thus fairly well protecting the accent stripe on the Southern side. I agree that ssobol's idea to add fabric to the side will give better protection. But with the boat in the water, you don't want the be near the water line..On my cover 6" more on each side would have been plenty.
PostPosted: Mon May 07, 2018 4:25 pm    Post subject: Reply with quote
I used several like this (different brand) and then bungees around the trailer. These grab the material and line at the bottom of the cover very well. The bungees have plastic ends not steel hooks. The cover came with webbing loops too, but I don't have much faith in their holding power.
https://www.amazon.com/Dirty-Gardener-Universal-Heavy-Locking/dp/B00B42H7Q8/ref=sr_1_31?ie=UTF8&qid=1525724506&sr=8-31&keywords=tarp+clamps+plastic
jack keifer
City/Region: Boise
State or Province: ID
Vessel Name: C-Squirt
Photos: C-Squirt
PostPosted: Sat May 12, 2018 12:12 am    Post subject: Boat cover Reply with quote
This is for Harworth. I have some photos of our setup. Problem is I am not familiar with posting. If you want to send me your email address, I will be glad to them to you. The cover we have on the 16 is the same one we had on our 22. We just had it cut down to fit the C-Squirt and it is secured the same way.
Jack
Previously 22 cruiser "Loafer's Paradise"
Now 16 cruiser "C-Squirt"
Page generation time: 0.0286s (PHP: 66% - SQL: 34%) - SQL queries: 22 - GZIP disabled - Debug on
