san juanderer
C-Dory Year: 1990
Posted: Fri Mar 30, 2018 4:12 pm Post subject: |
I installed the same brand in my present boat, but it was the 50 or 60 amp model. It has two presets for the flooded setting, I found that the resting float voltage ran a fair amount higher than the specification ( my memory was about 15.1 volts).
I used the "custom" setting ability to adjust the bulk and float settings. There was difference between digital display in the setting menu, and the actual output ( seems it was about .3 or .4 volts difference ).
Just check the output voltage that the presets are actually delivering.
Otherwise, it is a nice unit. _________________ Cdory 22 Angler
Rosborough RF246 (sold)
Commander 30 Sportfish (sold)
Olympic 26 XL (sold)
Glassply 19 (sold)
Olympic 23 (sold)
Bayliner 38 Motoryacht (sold)
Olympic 20 (sold)
Fiberform 16 (sold)
Olympic 18 (sold) |
Joined: 02 Nov 2003 Posts: 21504 City/Region: Pensacola
Posted: Fri Mar 30, 2018 6:56 pm Post subject: |
A float voltage of 15.1 would damage batteries in short order--sounds almost more like an equalization voltage. _________________ Bob Austin
alainP
C-Dory Year: 2011
Vessel Name: deja la
Posted: Fri Mar 30, 2018 7:35 pm Post subject: |
Is that in the water heater cabinet? The whole project did take way more time than anticipated when I installed mine. I also reworked the batteries, ACR and switch cabling at the same time. Lots of time laying on the deck but well worthit
so far. |
Avidmagnum12
Joined: 23 Mar 2013 Posts: 719 City/Region: Ocklawaha
C-Dory Year: 2011
Vessel Name: C-Otter
Photos: C-Otter
Posted: Fri Mar 30, 2018 7:36 pm Post subject: |
Thanks for the heads up.
My output voltage shown on the charger is the same as what is shown on my Balmer smart battery meter. The ProNautic has a 5 year guarantee. I think that I would arrange to have the unit repaired if it did not work correctly. Of course if it’s out of warranty....... you have a good work around.
All charged up...Tom _________________ Tom and Joyce Schulke
Avidmagnum12
C-Dory Year: 2011
Photos: C-Otter
Posted: Fri Mar 30, 2018 7:49 pm Post subject: |
Alain
Yes...it’s in the water heater cabinet. Did you put yours somewhere else? I did not put in an ARC.....yet. Need to save a few projects for the future.
Tom |
alainP
C-Dory Year: 2011
Posted: Sat Mar 31, 2018 12:01 pm Post subject: |
No, its in the same cabinet but I turned the water heater sideways and to the back to gain a little bit more of storage room. |
