Michael1
Joined: 06 Sep 2016 Posts: 7 City/Region: Friday Harbor
Posted: Wed Aug 09, 2017 4:02 pm Post subject: Stuck slider RESOLUTION |
I found the skinniest blade I have - a thin putty knife - and cleaned out the sides of the glass all around, and took off the end cap (easy). I could not get the blade in on either side of the handle. After everything was so loose that I could wiggle the window a little, it still would not slide, so I tapped lightly on the outside of the handle and it popped away from the channel. The primary problem was the metal-to-metal contact on the outside of the handle. _________________ Mona & Michael Rowe
Friday Harbor, WA |
Joined: 02 Nov 2003 Posts: 21469 City/Region: Pensacola
Posted: Wed Aug 09, 2017 5:18 pm Post subject: |
Michael,
I took the liberty of putting a copy of this post on the original thread you started so we could all know the outcome:
Original thread on stuck window _________________ Bob Austin
Michael1
Posted: Thu Aug 10, 2017 2:00 pm Post subject: |
Thank you. I don't know the protocol here |
Posted: Thu Aug 10, 2017 11:49 pm Post subject: |
Hey, stick around and you will pick it up. We are pretty easy going, and most are pretty willing to help out.
When you post in a thread, whether the one you started or another you are interested in following, you can click at the bottom of the posting window, in the box that says "Notify me when a reply is posted" and you can get an email notification when there is activity in the thread.
You can also go to "View posts since last visit" at the top of the home page and find everything that has posted since you were last logged on.
some do both, some do one or the other, some don't do.
It's up to you, but as Bob did, putting the solution into the thread that post the problem will b e helpful for someone down the road looking for the same situation you had.
SleepyC
